Silly belt-pulley question...
DaveKamp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Topic: Silly belt-pulley question...
    Posted: 19 May 2010 at 2:23am
Hi All-
I'll admit- I'm a total moron when it comes to AC belt pulley systems.  I've got a WD here that I'm trying to bring back to life... I've checked out every control linkage to make sure everything moves and operates as expected... but the belt-pulley confounds me... I've looked this thing over closely, and I've checked my IM manual, and find no method to engage or disengage the belt pulley.  It spins free, like it's disengaged... seems to me that when I attempt to spin it, it should only spin free if the clutch and transmission are both disengaged...
What's the secret here- is there an engagement mechanism hiding in here?
Nathan (SD) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nathan (SD) Quote  Post ReplyReply Direct Link To This Post Posted: 19 May 2010 at 2:29am
You need to loosen the bolt on top of the cast housing and push the pulley into the tractor to engage it and then reset the bolt. The pulley will then spin anytime the clutch is engaged.
JoeM(GA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeM(GA) Quote  Post ReplyReply Direct Link To This Post Posted: 19 May 2010 at 5:03am
see if this helps any
Allis Express North Georgia
41 WC,48 UC Cane,7-G's,
Ford 345C TLB
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 19 May 2010 at 6:39am
DO NOT Attempt this while the tractor is running.There should be a chisel mark on the frame rail to line up with a mark on the belt pulley housing. They might be painted over.
Edited by CTuckerNWIL - 19 May 2010 at 6:42am
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 19 May 2010 at 6:54am
Thanks guys- I suspected it wasn't pushed in far enough, but had no documentation to support it.
Yeah- I won't do it while running... I don't trust the clutch release that much, and the result would be really hard on those gears... and my arms.  I'm guessing that checking gear lash while it's running would be kinda difficult, too.
David Grubb View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote David Grubb Quote  Post ReplyReply Direct Link To This Post Posted: 19 May 2010 at 11:10am
Maybe I missed it in the instructions but the pulley should have no more than 1/8" end play between the frame and pulley rim when you find the correct hole for the set screw.
Dave
Bill Long View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill Long Quote  Post ReplyReply Direct Link To This Post Posted: 19 May 2010 at 3:31pm
If I recall there are a series of holes around the pulley housing that are a little closer each That gives an adjustment so the gear backlash can be adjusted to a reasonable amount.
The WC came with a belt pulley standard.  When the WD was developed it was noted that belt pulleys were not used that much, thereby a belt pulley was not standard equipment on the WD but an option.  However, it was the same as a WC pulley.
Good Luck!
Bill Long
ps:  Be sure to study the directions above closely.
