How much will a D14 pull
baverwolf View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote baverwolf Quote  Post ReplyReply Direct Link To This Post Topic: How much will a D14 pull
    Posted: 17 Jul 2016 at 6:33pm
Hey guys! I have a ? for all the gurus. I have a 12x20 lofted storage shed on skids that I need to move about 25 feet to pour a small foundation for it to sit on and then pull it back into place. I know approximately how much it weighs and was curious as to how much a D14 will pull? On know that depends on a lot of variables. My D14 has new 14.9-26 tires, rear segment weights and no fluid in the tires. Ground is dry undisturbed dirt. I have much larger tractors I could pull this with, but they are tied up several miles away with haying equipment. Just curious if my D14 might be able to get the job done...or if I should just wait for a bigger tractor??
Thanks!
Ben
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jul 2016 at 6:42pm
So what is the approximate weight???
GregLawlerMinn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GregLawlerMinn Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jul 2016 at 6:48pm
A properly weighted D14 will pull a 3X16 plow thru heavy soil
CrestonM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jul 2016 at 6:49pm
 Allis's can do anything! Lol
Ray54 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ray54 Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jul 2016 at 7:05pm
You can figure all day and not know for sure,so just do it. If not you need to go get a bigger tractor.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jul 2016 at 7:15pm
Put some round pipes under it, and you can prolly park the D-14, set the brakes, and winch it that far, with a come-a-long...
Dave H View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave H Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jul 2016 at 7:52pm
Why don't you just hook that hog up and give it a pull.
What I did with my JD today.  Wink
oldways View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote oldways Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jul 2016 at 9:39pm
I think it'll pull it. I drug one for a buddy once across his yard. Used a little 25 HP new Holland no problem.
Alex09(WI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alex09(WI) Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jul 2016 at 10:13pm
It will move the building, go in first gear, low range. Put as much weight on the rear tires as possible. On dry hard dirt you should pull it, but you might need to scrounge duals to be sure. I would guess it would pull 6000 to 8000lbs on skids over flat hard ground (with a lot of weight)
www.awtractor.com
A&W TRACTOR 920-598-1287
Post Options Post Options   Thanks (0) Thanks(0)   Quote oldways Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jul 2016 at 10:16pm
I forgot the one I pulled was full of filing cabinets and they were full of papers.
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jul 2016 at 10:19pm
The Nebraska Tractor Test report will show how much it will pull with the drawbar, with lots of weights on the tires. I don't know if the track was paved or not the time of the D14 test.
Gerald J.
DougS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougS Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jul 2016 at 10:30pm
Hook up to it now and try to move it 3 or 4 feet. That will give you an idea. Use a substantial log chain as snapping log chains have killed tractor operators.
Post Options Post Options   Thanks (0) Thanks(0)   Quote baverwolf Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jul 2016 at 10:57pm
Well, I guess I'll give it a go. Shed weighs approximately 6200lbs. Ill let you know how it turns out.
shameless (ne) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless (ne) Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jul 2016 at 11:44pm
my pickup would prolly pull it, so your tractor sures as heck should!
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jul 2016 at 6:10am
It'll pull it no problem BUT
1) use cut down hydro poles  to roll it along, if not available, strips of well oiled plywood or 2by8s under the sill plates will do. The quest is to cut down friction. heck even watering the grass/gravel will help.  Think like Moses did moving big stones....
2) put heavy carpets on chain between D-14 and shed. This will prevent busted chain from damaging anyone.
3) Do NOT allow anyone to be near the chain ! Only 'safe' place is in front of D-14 or behind shed.
I've used 'Troy' to pull my 7000# forklift a few times, the key is being able to 'roll' the load NOT drag it!
Jay
