Final Drive Questions WD45
Jeff(WD45-SATX-TN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jeff(WD45-SATX-TN) Quote  Post ReplyReply Direct Link To This Post Topic: Final Drive Questions WD45
    Posted: 17 May 2010 at 9:45am
I got my 45 up on blocks in the rear, removed the tires, and started the process of cleaning. Made sure the final drive pan fill plugs would move. For grins I went to pull one and see if I could sample the fluid. Well, pulled the plug and fluid ran out big time. How could the level be higher than the fill plug? Could there be so much thick grime in the bottm that the level rose? Maybe water displacing the fluid? It was a weird greenish yellow color. Panning to pull both pans, clean, check, and then seal back up. Just looking for advise.
Thank Jeff
1954 WD45 NF "Iron Tater"
Dave(inMA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave(inMA) Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2010 at 10:36am
Jeff, that's an interesting dilemma! Could be draining into the finals from somewhere above.... brake housings? Differential?
WC, CA, D14, WD45
Rfdeere View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rfdeere Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2010 at 2:49pm
   I'm guessing water ?
http://www.rumelyallis.com
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jeff(WD45-SATX-TN) Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2010 at 3:03pm
Randy...
So how would water get in? Through the brake covers and down the drive axel tubes? Seems if water got in somewhere, you would see a leak in the same spot?
Kevin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kevin Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2010 at 4:04pm
looks like the axles seals and pinion caps are wet with oil.. water might enter here.. also check the bull gear cap make sure its sealed good..looks like to me if the differential is leaking oil it would drain underneath the tractor.could they have been filled on unlevel ground??
B26240 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote B26240 Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2010 at 7:03pm
If you use one of those hand pumps that go in a 5gal. bucket the tube end is large enough to fill the hole. With it its possible to overfill the housing if you get the plug in fast enough.
Chalmersbob View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chalmersbob Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2010 at 8:50pm
There is a hole in the final drive that will alow water to get in if it sits outside in the rain.
I had a wd that was the same way. I thought that the axel seals were bad, but when I dropped the pans they were full of water. Bob
