WD 45 Starter issues
Steve Bright View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve Bright Quote  Post ReplyReply Direct Link To This Post Topic: WD 45 Starter issues
    Posted: 09 Jul 2016 at 8:18am
I have my dad's 1955 WD 45, New starter, new wiring harness, new generator and voltage regulator, new switch and battery. Pull the tractor 2 feet, runs and charges like a champ.
But it will not start with the starter, feels like it drags and turns over slow. Is the flywheel bad? Any ideas are welcome, been fighting this for a few years now.
Stan IL&TN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stan IL&TN Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jul 2016 at 9:37am
First thing I would check is the ignition timing. I would also remove tHe spark plugs and see how easy it turns by hand and then by starter. You may also want to put the old starter back in and try that also.
1957 WD45 dad's first AC
1968 one-seventy
1956 F40 Ferguson
DougS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougS Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jul 2016 at 9:56am
Tell us more. Is it a 6 volt battery? What kind of battery cables?
Don(MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jul 2016 at 10:02am
To look at the flywheel ring-gear remove the lower clutch housing cover plate (the big one not just the little two bolt cover) with it off you can see haft the flywheel ring gear at a time. The ring gear will where in four places around it. Look at the size batt cables, they need to be 1 gauge or bigger and don't use the clamp-on ends. check the ground end, is it clean and tight? Then check the starter drive gear and count the teeth. Load test the batt.
Like Stan said check the timing and how tight the engine is.
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jul 2016 at 11:26am
Distributor centrifugal advance stuck advanced will nearly stall the best starter, cables, and battery. Its not a rare condition. Comes from retard springs rusted off, or cam rusted to the main shaft because its not been lubricated. The advance needs a couple drops of crankcase oil per year into the felt in the center of the cam shaft under the distributor rotor. With the engine not running you can take off the distributor cap and should be able to turn the rotor in the direction it runs and feel the springs going to work and then when you release the rotor it must snap back to the retarded position. If not its time for lubrication and digging down into the advance mechanism under the points plate.
On a 6 volt system, voltage drop in the starter cables is critical and the 4 gauge cables at the wallyworld kiosk are much too small when the starter draws 350 or 400 amps. The only limitation on starter cable size is affording the copper and being able to bend it to fit the space available. 00 is a good size.Last I checked NAPA stores carried cables that size with ends applied.
Gerald J.
Fred in Pa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fred in Pa Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jul 2016 at 12:04pm
What are you calling new starter, rebuilt ,reman , etc.
Edited by Fred in Pa - 09 Jul 2016 at 12:06pm
nonetheless ,still dead.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve Bright Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jul 2016 at 6:06pm
OK, it is 6 volt, I want to keep it that way, Rebuilt starter, Now it will start when the engine is cold, drive around and let the engine temp get up to normal, shut it off and you will need to pull tractor to start until it is completely cold again, then it will start, Battery cables are from NAPA with ends made on the cable.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jul 2016 at 7:35pm
First thing I would do is do a draw test on the Battery and see what condition that is in. A low cell on a 6V Battery will loose a lot of power. Next, I would clean all cable connections, making sure the Battery cables are like Don said, at least 1 gauge or a little larger. If all that checks out good, then its time to find out what the rebuilder did to the Starter motor. Some "rebuilt" Starters are nothin' but new bearings, bushings, and a set of brushes. Were the field coils tested? Com plate in excellent shape? Armature replaced? All these things need to be looked into to see what the rebuilder did. If that Starter is right, it should spin that engine over anytime and everytime. Hot or cold.....
Steve@B&B
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jul 2016 at 9:05pm
The battery posts in a 6 volt  system need to be cleaned until the contact surfaces shine about twice a year. Been that way for me for the last 62 years.
Gerald J.
Orange Blood View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orange Blood Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jul 2016 at 9:09pm
If it starts good cold, but not hot, something besides battery cables is wrong, I think
How hot is your starter when the engine is hot?  It really shouldn't be any different, than when cold.
What weight oil are you running?
Still in use:
LeonR2013 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LeonR2013 Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jul 2016 at 10:52pm
After running and the armature gets hot from the engine they will act just like yours. Check the draw on the battery when cold and then when hot. If there's a lot of difference I'd say the armature is bad. Let us know.
