b brakes question
Ronnie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ronnie Quote  Post ReplyReply Direct Link To This Post Topic: b brakes question
    Posted: 08 Jul 2016 at 6:50am
I just replaced the brakes on my b.
And it has little to none stoping power going backwards.
Going forwards it stops great .
Is this the way these tractors are.
Or did I do something wrong.
Thoughts please.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jul 2016 at 6:52am
Pretty much the nature of the beast. Don't ever depend on stopping anything but the weight of the tractor on level ground.
Rick View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rick Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jul 2016 at 6:56am
What type of material was it...like a gray material? That stuff is crap. I have something that will stop you, for sure, but it isn't junk material, therefore it costs more. The difference is between daylight and dark with stopping the tractor. Interested, send me a message or email me at: rickinmo@socket.net .   Rick
Eric B View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eric B Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jul 2016 at 12:40pm
My grandfather's 1955 B model - the brakes would hold a good size load of hay at stand still uphill.
Rick View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rick Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jul 2016 at 12:57pm
They use cheap material any more, I've dealt with a lot of it in the industry. I use the woven material with the brass in it like they used a long time ago. Good stuff and will stop you on a dime and holds good. In fact, most everyone I deal with wants that type material on their brakes, so I stopped using the cheap stuff.   Rick
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ronnie Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jul 2016 at 1:50pm
See the problem is that the brakes will not grab going backwards but If I go forwards I can slide the tires.
The new pads are Gray they came from my local ac dealer.
Could they need broke in?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ronnie Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jul 2016 at 1:51pm
Rick send me a pm with pricing please
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ronnie Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jul 2016 at 1:53pm
O. By the way that is just the tractor that I'm trying to stop nothing hooked to it
Hubnut View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hubnut Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jul 2016 at 2:22pm
Ronnie,
One thing I learned after installing new bands was to tighten them up snug with the adjuster.  Then, drive the tractor and mash the HECK out of the brake pedal (one at a time).  Mash and hold.  Let the tractor drag it a little.  Then readjust the band with the adjuster.  This helps to shape the band to form to the drum.  I do it in both directions.  Try this out.   I'm not discouraging you from buying from Rick.  I get all my stuff from him.  Good prices and excellent workmanship.
Steve
1940 B "Lucy"
1941 B w/ Woods L59 "Flavia"
1942 B w/ finish mower "Dick"
1941 C w/ 3-point "Maggie"
1947 C SFW w/ L306 "Trixie"
1972 314H
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ronnie Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jul 2016 at 4:40pm
Thanks for the info hubnut
