Need a B speedi sleeve
CrestonM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Topic: Need a B speedi sleeve
    Posted: 07 Jul 2016 at 6:11pm
for the front crankshaft seal. I called Napa and they said they couldn't get the speedi-sleeves or the rubber lip seal anymore. Any help appreciated!
Thanks!
Dick L View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jul 2016 at 7:34pm
I will call my local NAPA tomorrow and see what they say. It has been most likely seven years since I bought one from NAPA but would be surprised if they didn't carry them in stock. They have started not having as much as they did in stock but when I call they deliver the items to me the next morning.
On another note, before I knew of speedy sleeves I would take a Dremal cutting disk and clean the spiral then fill it with JBWeld steel. I then filed it down leaving it slightly high and using a strip of emery cloth sand it all smooth. It worked as good as the speedy sleeve. It does add a day to the rebuild waiting for the JBWeld to cure before sanding smooth.
When I am working on a project I hate having to stop. It is just to hard for me to get back on that project. I like the speedy sleeves or any needed parts to be on hand before I start such of a project.
I have ten year old projects that I needed to order parts and after the parts came in they are still in the area of the project I think.Wink
Sandy Lake will have the seals in stock.
Edited by Dick L - 07 Jul 2016 at 7:35pm
Hubnut View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hubnut Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jul 2016 at 8:00pm
Dick,
I was afraid to chime in before, but I used the JB Weld method on two my tractors.  Haven't had a leak yet.
Steve
1940 B "Lucy"
1941 B w/ Woods L59 "Flavia"
1942 B w/ finish mower "Dick"
1941 C w/ 3-point "Maggie"
1947 C SFW w/ L306 "Trixie"
1972 314H
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jul 2016 at 8:48pm
Thanks, both of you guys! Dick, you're my "right hand man" when it comes to anything B/C/CA related! You always seem to have the right answer at the right time!
I know what you mean about not wanting to continue a project after waiting for the parts to come in! That happened to me a few times already, with different projects. I might try the JB weld method. It seems like it would be cheaper to do that than the speedi-sleeve. I don't mind the delay in waiting for the JB weld to dry. Usually what I do, to keep me interested in my project at hand, is to have 2-3 projects going on at once. Right now, I'm building my B engine, a homemade "putt-putt bike", and making a bolt-on 3pt hitch for my SC disk so I can use it with my 8N. By having several projects, I can work on one for a few days, then skip to another, and so forth. This way I have some variety, and don't get burned out by doing the same project every day for several weeks. Wink
sparky View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote sparky Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jul 2016 at 10:09pm
I get my speedy sleeves at O'Reillys. If I remember correctly they were the National brand.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jul 2016 at 10:22pm
Ok, so I did a google search and there's about 50 different kinds of JB Weld. Which do I need? I was thinking this....
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hubnut Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jul 2016 at 10:38am
Creston,
That won't work.  Buy the stuff in the tubes.  It flows better and will fill the gaps.
Steve
1940 B "Lucy"
1972 314H
CAL(KS) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jul 2016 at 11:00am
creston, on the last post about this I posted the CR part # and the dimention chart matching it.  whats the issue?  if napa cant cross that CR # you need a new NAPA
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jul 2016 at 11:30am
Originally posted by Hubnut Hubnut wrote:
Creston,
Steve
I don't know why it wouldn't work. This is 2 tubes that have to be mixed to use and is made for many uses including steel.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jul 2016 at 11:35am
I'm not sure. I gave them the number, and they said they can no longer get them. I know the guy behind the counter well, his dad and he farm about 1/2 mile away from us, so he's not the average citybot kid behind the counter.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jul 2016 at 11:36am
Creston,
Steve
The link I posted doesn't show 2 tubes, only one. He must be talking about something else?
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jul 2016 at 12:01pm
the sleeve is 99149 CR, SKF and NATIONAL all the same number.  NAPA # is 99149 also.    all over the net.  O'reilly lists it for 65 mustang with same part # and 3 yr warranty
DougS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougS Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jul 2016 at 1:31pm
Correct me, but don't you need a slightly larger seal when you use a Speedy Sleeve?
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jul 2016 at 1:36pm
yes the sleeve and correct seal come together
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jul 2016 at 2:55pm
I'll take those numbers to Napa and see what they have to say. Thanks!
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jul 2016 at 5:29pm
It IS 2 tubes side by side, When you squeeze out equal amounts, you have to mix because it is an epoxy.
 Look at it closer. http://cdn.shopify.com/s/files/1/0411/5921/products/8267_SteelStik.jpg?v=1418307632
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jul 2016 at 5:33pm
Nope, the sleeve is very thin and rubber seals have room to stretch. BTDT although some may sell a different seal for them.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jul 2016 at 6:12pm
You can get most any size of speedy sleeve from McMaster-Carr.  I had a idler chew into a stub axle, on the U/C of my ASV RC-30 loader, left a groove about 1/4"-5/16" deep.  Used 2 coats of straight JB weld, The stuff any hardware store sells.  First coat, I put in the groove, sanded it down, with a strip of emory cloth, then put a second coat on, with the sleeve installation.  3-4 years ago, still running good, today...
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jul 2016 at 8:43pm
Just for the record I have one new stick and a half stick in my tool box. The package at the link has only one stick. I slice off the amount I want to use and mix it between my thumb and finger until the center of the stick is mixed well with the outside. It is a thick putty. I use it on a crack on one of my C radiators. I force it in and it sets up quickly. It falls off after a while and I reapply. I would not use it on the crankshaft. The JBWeld in the tubes will run until it sets up, the putty will not run as it is thick. I have also used the stick on small dints rather than mix up bondo. The stick has a round foil seal that I put back on after slicing off what I need to keep it from hardening in the plastic tube for storage.
CALEBnOK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CALEBnOK Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jul 2016 at 8:32pm
Creston. Seal Co here in okc. Can get ANY SEAL OR SPEEDY SLEEVE! Half the price any where else. All you need is to measure or a number to cross reference.
Bill Long View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill Long Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jul 2016 at 9:17pm
Creston,  Do not lose faith.  Get that B - my favorite - running,
You have some outstanding advice from some of the best mechanics I have never met but wish I could.
Let us know how it goes
Good Luck!
Bill Long
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jul 2016 at 9:39pm
Good Luck!
Bill Long
Will do Bill!
My B ties with my 8N for favorite. If the B had 3pt hitch, it WOULD be the favorite! Big smile
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jul 2016 at 9:45pm
Also, Dick, have you had any problems with the seals leaking after you use JB Weld to fill in the grooves? I was told over time they will begin leaking again, as the epoxy won't hold up for long.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jul 2016 at 8:06am
No problems.  The seal lip does not ride on the JB Weld in the spiral. To wear into the JB Weld it would have to wear a groove into the steel. Just wrap a thread around the crankshaft over the grooves where the lip would ride to see for your self.
I used a speedy sleeve on the C I mow with and it leaks. I must have damaged the seal when I installed it.  As I buy another jug of oil I say I should put the new seal on this thing one of these days.  At least the fronts not going to rust.Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jul 2016 at 8:38am
Thanks.
Now the next question...Is there any place I can order just a shim pack for the crank bearings? Seems every site I check sells them in an overhaul kit only.
ac45dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac45dave Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jul 2016 at 9:05am
power max lists them. at the bottom of each bearing list is shim kit numbers. should be able to get them separate from the overhaul kit.            http://www.powermaxparts.com/DEMO/AC-125-A.html
Edited by ac45dave - 10 Jul 2016 at 9:07am
Gary in Texas View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary in Texas Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jul 2016 at 3:54am
Try calling Brenda, at Sandy Lake Imp. for the shims.
She is good at that kind of stuff.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jul 2016 at 8:14am
Ok, I tried the JB weld method, and now have the spiral filled in and sanded smooth.
Now I need the lip seal part number. I've called 2 Napa stores and neither say they can't get an Allis-Chalmers B front crankshaft lip seal. If anyone has the part number, I would greatly appreciate it!
Thanks!
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac45dave Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jul 2016 at 9:03am
these are the numbers from my napa prolink page,early and late production.both are available but would have to be ordered.        FPG 14443 late     FPG 15162 early
Edited by ac45dave - 12 Jul 2016 at 9:06am
Allis dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis dave Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jul 2016 at 11:11am
I bought a reliance shim pack for my WD45. Instead of a "laminate" shim pack, it came as single .010 shims. I would order from Sandy lake so you get the actual laminate shim pack so you can peel off layers to get the correct tolerance.
I ended up just making some shims at work from .005, .004, and .003 shim stock.
