Agco paint/ hardener question
7060 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 7060 Quote  Post ReplyReply Direct Link To This Post Topic: Agco paint/ hardener question
    Posted: 06 Jul 2016 at 5:56pm
I am getting ready to paint a 7030 and am using Agco paint. I'm wanting to buy the hardener for it, but is it an alkyd enamel or acrylic? I can't remember what I used last time I went through this and I can find any posts on it. What kind of hardener and thinner does everyone use with it? I'm thinking I used Valspar Renew hardener and either laquer thinner or naphtha thinner, but wasn't sure.
Ryan Renko View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ryan Renko Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jul 2016 at 8:19pm
I am about 90% sure Agcos paint is enamel. Hopefully someone else will chime in! Ryan
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jul 2016 at 8:58pm
AGCO paint is indeed enamel.
CrestonM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jul 2016 at 9:37pm
This will really show my stupidity, but I thought all paint was enamel? Can someone explain in simple-man's terms?
Thanks!
7060 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 7060 Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jul 2016 at 9:40pm
After searching google for over an hour I finally typed the right thing in and I don't even remember what it was, but found a link to all of Agco's paint tech sheets, plus the part numbers for all of the paint colors. Here it is incase someone else needs to know.
http://www.rudolphbrosinc.com/partsguides/agcopartspaintguide.pdf
Also I won't know until I actually spray it and compare, but DuPont RS562 looks to be almost an exact match to Agco's maroon paint in the rattle cans.
Edited by 7060 - 06 Jul 2016 at 9:51pm
BenGiBoy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BenGiBoy Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jul 2016 at 7:36am
'39 Model B
Tractors are cheaper than girls, remember that!
Play Farmer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Play Farmer Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jul 2016 at 8:01am
wildcat2 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wildcat2 Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jul 2016 at 8:12am
Last time I bought some Agco paint I also got some hardener with it.   It is Valspar renew low voc hardener, number REN4001.  The can says 8 parts paint 1 part hardener.  Just painted some wheel weights and it worked every well.   I also used the appropriate reducer.
Acdiesel View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Acdiesel Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jul 2016 at 10:53am
I'M CURRENTLY USING AGCO PAINT AND THINNING WITH ACETONE AND USING VALSPAR HARDENER AND ITS LOOKING PRETTY GOOD.
DAN
D19 Diesel,D17 Diesel SER.3
2-D14, 2-D15 SER.II WF/NF
D15 SER.2 DIESEL
D12 SER.I, D10 Ser.II
2-720'S D21 Ser. II
Gmc,caterpillar
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jul 2016 at 1:19pm
enamel reducer or acetone will work as a thinner.  I would NOT use laqueer thinner. That is for laqueer paints or cleanup.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jul 2016 at 1:57pm
What combination is bad for your lungs?
ac45dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac45dave Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jul 2016 at 2:06pm
Stan IL&TN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stan IL&TN Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jul 2016 at 2:51pm
I believe anything with harder or activator in it is bad news and should only use it with a fresh air source or if you like to take a chance you can use it outside and stay upwind of the overspray.
1957 WD45 dad's first AC
1968 one-seventy
1956 F40 Ferguson
Toscani NE SD View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Toscani NE SD Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jul 2016 at 7:10pm
I will answer the question, its alkyd. not acrylic.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Play Farmer Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jul 2016 at 8:54pm
All of them, some worse than others. If you're painting just wear a mask, your family will thank you.
