Allis B or C tractor hydraulics |
| Author | |||
davh
Topic: Allis B or C tractor hydraulicsPosted: 06 Jul 2016 at 7:02am |
Will the WD or WD 45 hydraulic pump fit on a B or C tractor? I know the WD pump is 4 piston and the B and C is 2, just wondering if it works.
| Sponsored Links | |||
PaulB
Joined: 12 Sep 2009 Location: Rocky Ridge Md Points: 5192 |
Posted: 06 Jul 2016 at 8:30am |
NO. The only upgrade that can be made to work is to change to a CA PTO unit along with the CA pump.
davh
Posted: 06 Jul 2016 at 9:06am |
Is the CA unit worth the change? Isn't it a 2 piston pump also?
1953CA
Joined: 01 Jan 2011 Location: Burlington, WA Points: 505 |
Posted: 06 Jul 2016 at 9:39am |
No, the B/C are two piston pumps.
The CA pump is a 4 piston pump which is the same pump on the WD/WD-45, so yes a pto unit swap on a B/C will get you the pump your asking about. |
1945 AllisCletrac / 1948 "B" / 1953 "CA" / 1955 "WD-45" / 1963 "D-15 Series II"
"No Air Support without Ground Support" |
CTuckerNWIL
Joined: 11 Sep 2009 Location: NW Illinois Points: 22825 |
Posted: 06 Jul 2016 at 3:13pm |
A CA pump would have to have the CA PTO shaft to make the CA pump work.
70232903
davh
Posted: 07 Jul 2016 at 1:04pm |
Any thoughts on whether to change to the 4 piston CA pump or to go with a front drive pump for live hydraulics? Wondering if it wouldn't be more cost effective, I do not have access to the CA unit and what I find by the time I get it will be a fairly expensive project.
CAL(KS)
Joined: 18 Sep 2009 Location: Chapman, KS Points: 3804 |
Posted: 07 Jul 2016 at 1:35pm |
a front mounted pump will yield live power and higher flow to match modern hydraulic equipment. while it may cost a little more to build a complete new system you will have a better system and more versatility in the end, however depending on your needs it may not be necessary. cost effective route is replace with a different b/c pump
Dad- WD, D17D, D19D, RT100A, 7020, 7080,7580, 2-8550's, 2-S77, HD15 |
Scuzzy
Joined: 19 Oct 2014 Location: Metamora Il. Points: 20 |
Posted: 23 Jul 2016 at 2:57pm |
What is involved in swapping a C PTO Unit onto a B-Anything going to Fall out when I take it apart? Scuzzy
Bill Long
Joined: 12 Sep 2009 Location: Bel Air, MD Points: 4556 |
Posted: 23 Jul 2016 at 4:00pm |
The B-C PTO units are the same. However, the first B - C PTO units had a 1/8 " pto spline and no opening for a hyd pump. Check that carefully. Since I think most of the PTO implements require the larger PTO shaft 1 3/8" I would look for that
Also, if you remove the PTO from a tractor be certain to get the gear on the PTO drive shaft off the tractor with the Snap Ring. If you are removing the PTO from a B-C you should have a rear end cover. All B's and C's came with a cover on the end of the differential housing Could be hard to find. If you have a B thanks and take good care of my favorite. Good Luck! Bill Long |
Scuzzy
Posted: 23 Jul 2016 at 5:45pm |
Hello Bill, I have a 39 B that I want Hydraulics on and bought a fairly complete C with the Hydraulic Pump on it, my B has the same PTO Unit with a Belt Lully and PTO shaft but as You know-No Hole to mount the Pump to the Housing so I want to change Unit for Unit-Hydraulic Pump on B and not on C. Another Question I have is that my B is Hand Brakes and C is Foot Brakes, can I switch and use the Foot Pedals and Linkage to the Brake Bands on my B or do I have to replace them. Just read some place that the latter Bands were Bigger and had to Hog Out around them on my B to have clearance to fit? Thanks Bill! I Appreciate Your Help and fast Response! Scuzzy scuzzy@mtco.com
Bill Long
Posted: 23 Jul 2016 at 10:12pm |
The C being a two row tractor has a wider rear end than the B. Therefore, while the RH foot brake may fit the LH would probably not - the difference in the width of the rear. If I recall correctly - I am away from home and my library - the brakes bands are the same.
Check e-bay. They have people who part out tractors there and you may well find the foot brakes you want. I was on there today and I believe at that time they had foot brakes and linkages. In you search put "Allis Chalmers B - parts" and it will come up. Good Luck! Bill Long ps: If you have a PTO on your B now you may well be able to use the existing gear on the PTO drive shaft.
SteveC(NS)
Joined: 12 Oct 2009 Location: Nova Scotia Points: 663 |
Posted: 24 Jul 2016 at 7:11am |
davh, I have mounted a front pump to my B, however I can't remember how to post a pic from my pics on this site. If you're interested PM me your e-mail address and I'll send you
pics and answer any questions
Bill Long
Posted: 24 Jul 2016 at 3:19pm |
Thinking back the foot brakes from the C may fit the B. I believe the driver area is the same width so the linkage and brackets may well fit.
You know I am answering questions that I never thought I would hear. Guess after 77 years you do things that you never believed would happen. Quite frankly, I really thought that I would not be still actively involved talking about still operating tractors from the years I sold them. Thanks to all who keep a name alive that I really thought would have been long forgotten by now. Good Luck! Bill Long
