what type of dozer blade for 7000 series
DIESEL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DIESEL Quote  Post ReplyReply Direct Link To This Post Topic: what type of dozer blade for 7000 series
    Posted: 04 Jul 2016 at 2:01am
I have a 10 foot Otter dozer blade on a 766 IH. I thought I could make new mounts for it to fit my 7010 but I think it might be easier to just find a different blade. What do you guy's have mounted on your 7000's?
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jul 2016 at 7:01am
If you need a dozer, buy a dozer. Don't abuse your tractor trying to use it as a dozer .   MACK
SHAMELESS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SHAMELESS Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jul 2016 at 7:28am
X2
Ross D. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ross D. Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jul 2016 at 9:04am
Good morning.   What does a 'Otter Blade' look like?    Ross.
truckerfarmer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote truckerfarmer Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jul 2016 at 9:11am
Guys, I'm thinking he uses it for silage.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DIESEL Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jul 2016 at 9:48am
I don't use the blade like a real dozer,use it mostly to clean a path in the snow to feed cow's on dry ground, and clear my road off in the winter. Only real abuse the tractor gets is having to leave the heated shop when it's cold out.
An Otter dozer blade is just a lighter made dozer than say a John Deere or Dagleman. They are really popular here in the sandhills of Nebraska because we have such a high water table, light enough that your front tires won't sink in the ground.
http://www.bigiron.com/photos/20150520/otterdozerblade_3_003.jpg
bigal121892 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bigal121892 Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jul 2016 at 9:56am
On  our 7 & and 8000 series tractors, we had Leon, Degelman, and Gnuse. It is tough to beat the Degelman or the Gnuse dozers. I didn't care for the Leon, as the blade didn't lift very high, and it was easy to get hung up. The nice thing about the Leon, is that since it mounts to the front axle, and the drawbar, all you had to do was swap drawbars, to move it to another tractor. Having said that, I still wouldn't buy another one. If mounting to a 4WD, then the Degleman, is the only choice.
Roger (NE) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Roger (NE) Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jul 2016 at 4:50pm
Contact Otter's Inc in Clayton, KS. They may have mounts for your 7000 on hand and if not can make them. Had them modify one of their blades with John Deere mounts to fit my tractor several years ago. Very reasonable prices and they were great to work with!
