groundhogs
screwloose View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote screwloose Quote  Post ReplyReply Direct Link To This Post Topic: groundhogs
    Posted: 01 Jul 2016 at 6:03pm
I've taken care of 9 and have 8 more that I know of to go on the first 10 acres out of 95.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jul 2016 at 6:08pm
Cook em up like squirrel, Supposed to be GOOD eatin Big smile
Post Options Post Options   Thanks (0) Thanks(0)   Quote screwloose Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jul 2016 at 6:28pm
Yeah they are related to squirrels, wait I hate squirrel stew. I could never get used to seeing that rat size carcass floating around in the stew. YUCK
Randy WI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Randy WI Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jul 2016 at 6:31pm
Young ones are best and remove all of the fat we roasted ours and they were pretty good. Randy
DougS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougS Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jul 2016 at 6:43pm
Easy to catch. All you need to do is put salt on their tails.
Dan73 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dan73 Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jul 2016 at 6:49pm
Never heard that one what does it do? My grandfather always said just brake their nose and they will bleed to death I always figured he wanted to know if we would run around chasing them with a hoe.
EPALLIS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote EPALLIS Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jul 2016 at 9:32pm
Ground hog traps and bleach is what keeps them down the best.... My 2 cents.
Auntwayne View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Auntwayne Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jul 2016 at 9:55pm
      22.250 works quite swell. Have never been able to eat any since there is nothing left.
Dad always said," If you have one boy, you have a man. If you have two boys, you have two boys". "ALLIS EXPRESS"
SHAMELESS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SHAMELESS Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jul 2016 at 9:59pm
tannerite
427435 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 427435 Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jul 2016 at 10:36pm
Some people call them wood chucks.  They can sure do a number on vegetable garden!!
We've got houses around us so a rifle is out.  Twelve gauge works fine, however.   Wink
Mark
GTH-L Simplicity
Dave Everett View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave Everett Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jul 2016 at 8:29am
I knew a guy in PA used a riding mower, they used to hunker down then he got em. 30. cal carbine works quite well also if you surprise em
alleyyooper View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote alleyyooper Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jul 2016 at 8:34am
We call them whistle pigs, 22 mag or 22 hornet with a bit more range. Very good eating since they are vegans.
MARTY'S WHISTLE PIG DELIGHT
1 young groundhog
3 apples, halved
1 can sliced pineapple
Salt & Pepper
Clean groundhog thoroughly, leaving whole. Parboil until meat is beginning to get tender. Remove and stuff with apples. Garnish with salt and pepper all over the groundhog and then place in brown 'n bag. Cook at 300 degrees until "WHISTLER" is browned.
Whistle pig Stew
1 woodchuck
2 onions, sliced
1/2 cup celery, sliced
Flour
Vinegar and water
Salt and pepper
Cloves
Clean woodchuck; remove glands; cut into serving pieces. Soak overnight in a solution of equal parts of water and vinegar with addition of one sliced onion and a little salt. Drain, wash, and wipe. Parboil 20 minutes, drain, and cover with fresh boiling water. Add one sliced onion, celery, a few cloves, and salt and pepper to taste. Cook until tender; thicken gravy with flour.
Al
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jul 2016 at 9:05am
 Never had squirrel stew, yuck. Clean it quarter it and boil it till tender. A pressure cooker works well for the old tough ones. Skim off the scum that rises as you boil it and once tender, take it out and fry it in some butter.
 I soak em overnight at least, in some vinegar salt water before boiling.
Stan R View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stan R Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jul 2016 at 1:55pm
We call them woodchucks out here. But I remember we used to get them in the hay fields. My father had a friend that worked for the Railroad, and he would give us railroad flares. Light one up, shove it in the hole as deep as possible, and fill their hole with dirt and level it out. Kept them under control. Not sure why we don't have them anymore-- coyotes and fox population is way up now so maybe that is keeping them out of the hayfields?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dan73 Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jul 2016 at 8:00pm
Foxes will get the small ones female foxes will even get the big ones some of the female foxes are pretty big. I had alot of them here but them the foxes can back and now you only see a few around the house.
GARY(OH/IN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GARY(OH/IN) Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jul 2016 at 11:11pm
After you all get those ground hogs stewed up the best way to serve them is out in the back yard to the dogs.
This page was generated in 0.227 seconds.
