Paint Issues
Matt MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Matt MN Quote  Post ReplyReply Direct Link To This Post Topic: Paint Issues
    Posted: 26 Jun 2016 at 9:51pm
I am painting an allis wagon gear and a barge box, the primer went on great, but now I have put on the first coat of paint, everything sprayed great, layed down great, But it has been 3 days now and it is not dry. I have now put it outside in the sun but it does not seem to help.
I used a Polyurethane enamel paint and thinned it out with xylol, Did I do something wrong?   It has been very humid here lately I am thinking that isn't helping.
I still have to do more painting, I am wondering what I can add to help speed up the drying time? Maybe putting a hardener in with it? Or find a faster drying reducer?
screwloose View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote screwloose Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jun 2016 at 4:10am
Enamel takes a long time to cure/dry. Hardner will help. My 190xtd was repainted I'm guessing in the 80's. When I was prepping the sheet metal the paint under the decals was still soft to the point I could almost scrape the paint off with a putty knife.
Don't know if it pertains to enamel paint or not but automotive paint can dry in the air before it even hits the surface your painting if you use a reducer that's too fast. Plus the reducer has to be compatible with the paint your using.
You might just have to use hardner and be patient. I used enamel and hardner for my tractor and you could handle the parts the next day if you were gentle. I would say it was cured/dry in about 2 weeks to a month, roughly.
Post Options Post Options   Thanks (0) Thanks(0)   Quote screwloose Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jun 2016 at 4:12am
I meant to say, my tractor was repainted in the 80's and was still soft under the decals when I stripped and repainted it in 2015.
Play Farmer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Play Farmer Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jun 2016 at 5:13am
With urethane enamel you have to use a harder. Without it I have no idea how long it will take to dry or how durable it will be when you're done. This one sounds like a big Oops.
Just out of curiosity, what did the directions say?
Edited by Play Farmer - 27 Jun 2016 at 5:14am
desertjoe View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote desertjoe Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jun 2016 at 5:26am
  Hey Matt,,,as a rule,,,,,Polyurethane paints are a two component system, consisting of the topcoat AND a hardner that is required for the paint to harden. I don't think your paint without the hardner is going to set up enough to give you any kind of longivity, and prolly will have to be removed and start over. I know that ain't what you wanted to hear,,,,,
B26240 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote B26240 Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jun 2016 at 6:08am
Matt; PF and Joe are right you must use hardner with that type of paint otherwise you have nothing. I am no expert on painting so when a project comes up I go to the paint store and explain what I am painting and go by there recommendations. On tractors there is also a third step in the process and that is to use a sealer on top of the primer before finish coat. When all goes right you should be able to handle painted items in a couple of hours. Not sure what you should do now.     Mark
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jun 2016 at 7:28am
I feel for you Matt.  I just learned a few things that I never knew.   I'm glad that I didn't start my painting job yet.  Now I have a lot better insight as to the correct way to do it.  Another GOOD day.....I learned something!
Post Options Post Options   Thanks (0) Thanks(0)   Quote desertjoe Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jun 2016 at 9:37am
  Dang Matt,,,I feel for you, Guy,,,, but tomorrows another day,,,Clap
 Since it lookin like you gonna have to start over on your project,,,,and I DID miss the point on the primer,,Thanks Mark,,,,You should always use the Primer/Sealer Vs the primer then paint. Reason is that not all primers are created equal and some DO NOT "seal" the underlying old paint from the new paint goin on. Example is shootin a light colored paint over some old red paint that only has regular primer on it...The old red paint under that primer will most of the time "bleed thru" and will show up on your light colored paint,,,,!!!!!!!,,,,,,,but let's get you headed in the right direction.
  Actually,,I find most Primer/Sealers are cheaper than regular primers, although,,most have short "re-coat times" ,,,meaning,,you have to spray more P/S or the paint within a certain time frame,,or item will HAVE to "set" till primer is cured,,,then be re-sanded or scuffed before you can shoot more P/S or the actual paint. Keep that little tidbit in mind when you get ready to spray.
   I have no clue what XYLOL  is,,, but again, the urethanes being a 2 part system also require a special thinner or reducer to thin the paint for required viscosity and you should use what the paint mfgr. recommends. These dang paints nowadays cost TOO dang much to not use the right components to get  your equipment done right the first time.
  Hope this helps you and don't hesitate to ask more questions. Joe r
Edited by desertjoe - 27 Jun 2016 at 9:38am
SHAMELESS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SHAMELESS Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jun 2016 at 10:11am
and ya'll laugh at us rattle canners! lol
Post Options Post Options   Thanks (0) Thanks(0)   Quote Matt MN Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jun 2016 at 11:59am
Well, yeah Live and learn right...
Here is the short story of the paint.. I got 5 gallons of it for free... Just trying to use it.
As far as directions there is nothing on the pail. I talked to a friend of mine that owns a body shop and he was not too familiar with it but said it will dry but might take 5-7 days.   The next batch i am going to get some hardener and try that.
It has been really humid here lately so I am guessing that might effect it as well.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Play Farmer Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jun 2016 at 12:40pm
It sure looks good in the pictures.
Can you post of picture of the can, or let us know what brand of paint it is, or any other information you can post. Maybe someone can offer specific information on what you're spraying.
On a side note, it can't be the same type of urethane enamel I spray, not enough orange on everything else in the garage. LOL
LeonR2013 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LeonR2013 Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jun 2016 at 3:53pm
Play Farmer, jar loose from some of that cash you've hid out in a jar and buy you a Sata. You won't be using as much paint. Another reason to use a sealer is that it prevents die back. That's where your paint job looks beautiful, nice and shiny, and then in a few weeks turns dull and no amount of polish and elbow grease will make it shine again.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Play Farmer Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jun 2016 at 7:28pm
Leon,
I always seal everything before the paint goes down. My problem is I just can't get comfortable with an HVLP gun...yet. I've tried it a few times, I always end up going back to old reliable. I don't paint very often, so I don't get much practice. Maybe someday.
I'd like to think my tractor painting projects were over, but I'd only be kidding myself.
A buddy of mine just bought a Sata, he says it's just an amazing gun.
Edited by Play Farmer - 27 Jun 2016 at 7:29pm
Bill_MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill_MN Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jun 2016 at 8:45pm
Acrylic urethane and hardener is like mixing the two parts of JB weld, without the hardener or "activator" as it's often called, the chemical reaction that causes the paint to stick and cure doesn't happen. You'll have to strip and start over.
firecowallis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote firecowallis Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jun 2016 at 8:49pm
POLYURETHANE PAINT  NEED THE ACTIVATOR IN IT TO DRY  SORRY TO SAY ONLY WAY TO FIX IS A SAND BLASTER OR STRIPPER AND START OVER  IT SUCKS BUT IVE BEEN PAINTING CARS AND TRACTORS FOR  YEARS LIKE THE OLD DUPONT CANCER CAUSING IMRON FOLLOW MIXING INSTRUCTIONS AND THINNER RECOMMENDATIONS IT  COSTLY   BUT PAINTS ARE MIXED A CERTAIN WAY AND SOME DONT PLAY WELL TOGETHER  LIKE LA CURE AND ENAMELS    RAISING UP ON EACH OTHER  JUST LIKE DRUGS IN THE BODY  SOME PLAY WELL SOME DONT
allis g 7045 200 wd45 wd45d c ca 6080 u
Post Options Post Options   Thanks (0) Thanks(0)   Quote firecowallis Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jun 2016 at 8:52pm
IF U HAVE A GOOD CLEAN TIP RATTLE CANS DO A GREAT JOB WE USE THE TROW A WAY 3M TIPS ON OUR GUN JUST BHAVE TO KNOW WHEN ITS TIME FOR A NEW TIP AND  CHANGE THEM OUT
Toscani NE SD View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Toscani NE SD Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jun 2016 at 8:56pm
oh boy...xylol is not for urethane paints, I don't even know what to tell you but you have to remove that paint and start over.
Post Options Post Options   Thanks (0) Thanks(0)   Quote LeonR2013 Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jun 2016 at 10:49pm
Some times when I read something like this I'll get a brain fxxt and all kinds of things come up I was wondering if a person would spray areal thin coat of hardiner on the paint if that would penetrate far enough to work? Has anyone tried it? I'll have to admit that I've tried some real off the wall stuff. Sometimes they worked  and I thought, boy how about that, and then other times they didn't and I'd tried to hide it before someone saw it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote LeonR2013 Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jun 2016 at 10:52pm
Say Shameless, does this pay my dues for this year for the misfit club? LOL
Butch(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Butch(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jun 2016 at 6:53am
There is a more than good chance that if you place any ole hardener in it and any ole amount  with any ole reducer that you will be doing over for the third time. How has lady luck been treating you lately??
All paint manufacturers have their "P" (product data) sheets on line where you can find out the proper ingredients and proper ratios. Also you need some PPE if your going to spray hardened paint. Been a while since I preached my warning on this subject but think a little wont hurt you? I have a dear friend who would love to tell you his story, and how he almost died after believing "a little bit wont hurt ya"
Post Options Post Options   Thanks (0) Thanks(0)   Quote desertjoe Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jun 2016 at 5:12pm
    Good Point Butch,,,,!!  those Isocyanates in the polyurethane paints are like that skull and crossbones= Bad Chit,,,!!! That stuff can and Has killed people that breathed the vapors in. In some instances,,,,it has left men unable to "be" with their wives and girlfriends,,,,,,!!!!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote LeonR2013 Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jun 2016 at 7:43pm
And that's a fact!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jun 2016 at 8:49pm
Several years ago. I cleaned up a back blade and got some Ford gray from TSC. For some reason I did not get their thinner. I used something else and it took about 3 weeks for it to dry! just was never right.
Richardmo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Richardmo Quote  Post ReplyReply Direct Link To This Post Posted: 06 Aug 2016 at 7:42am
Matt,
What ever happen did the paint dry?
Post Options Post Options   Thanks (0) Thanks(0)   Quote LeonR2013 Quote  Post ReplyReply Direct Link To This Post Posted: 06 Aug 2016 at 8:56am
I was wondering if a person took a real high pressure power washer with soap if they might be able just to peal that paint right off?. I washed the deck and I had to be careful or it would peal the wood, so why not this soft paint? That's the reason for the soap and plenty of it.
