Oil filer question |
Lonn
Joined: 16 Sep 2009 Location: Назарово,Russia Points: 29819 |
Topic: Oil filer questionPosted: 20 Jun 2016 at 8:50pm |
I have a couple cases of Cenex filters that say CO442/PH2850 on the box. Looks like the 237000 Allis or PH8A Fram filters. The Fram filter PH2850 was replaced by the PH8A with the only difference I can see is that the earlier filter (PH2850) has a higher burst pressure and a Bypass valve psi of 30 vs about 12 psi in the PH8A. I don't know what the specs are for the Allis 237000. I'd like to use these up on the D19 and D17 and the older Ford pickups we have if I can.
Also if the Cenex CO442/PH2850 can be used on those engines, the next question is.......... and I have heard of people doing this in a pinch...... can I use those filters in our 190 and 180 tractors in place of the larger diameter OEM filter? Just change the filter more often like every 50 hours and stick to the 100 hour oil change? Truth is I have about 5 cases of these filters and one case of Baldwin B2 filters. The B2 is more in line with the Fram PH8A specs but IMO much better quality. I came to inherit these filters from my FIL when he retired from his garage business in 2008 and they have been sitting on the shelf since. I also have several relatives that could also use these filters. Between all my relatives there must be about 75 Allis tractors or more and many could use these filters hopefully. Thanks PS I also have one case of Cenex CO103/PH7 filters that I think can be used as the hydraulic filter for 190/180 tractors. Same questions goes for those. |
Wink I am a Russian Bot |
David G.
Joined: 21 Feb 2012 Location: W Nebraska Points: 1738 |
Posted: 20 Jun 2016 at 10:23pm |
Interesting topic Lonn. I kinda had wondered about this myself. The other day I changed the oil in one of my 175's (diesel) and decided to use a motorcraft FL1-A filter I had laying around. Curious to see some input....
DougS
Posted: 21 Jun 2016 at 2:01pm |
Generally the bypass pressure won't matter unless you are running a high viscosity oil on a cold morning. A good reason to run the proper viscosity oil for your particular climate.
Brian Jasper co. Ia
Joined: 11 Sep 2009 Location: Prairie City Ia Points: 10508 |
Posted: 21 Jun 2016 at 2:39pm |
Cut open the Fram filter, then cut open a Wix or Motorcraft (Purolator) filter. Let your eyes tell you which one you want.
(No Fram for me) |
Lonn
Posted: 21 Jun 2016 at 8:23pm |
I'm not so sure these are actually Fram built filters at all but I was going to do just that Brian. Years ago we did that in mechanics school and Fram was absolutely the worst built using cardboard end caps and a lot less pleated filter media. But according to the specs I found, the older Fram filters are built to take a much higher burst pressure than the later PH8A.
Who makes AGCO filters these days? I think they used to be Wix. I'm going to open up a used AGCO 70237000 filter and a used Balwin B2. I'm pretty confident the Baldwin is a good filter. |
Lonn
Posted: 26 Jun 2016 at 8:52pm |
Well I didn't have a Fram PH8A filter to take apart. The only other filter I have in that category is an AGCO but the D17 isn't ready for a change yet.
I did take apart one of the new CO-442/PH2850 filters......... here's what I found,sorry no pics...... It has 50 pleats of filter media, a leaf spring behind the element when you pulled the element out, metal caps on both ends, the pleat ends were glued together, a nice rubber seal between element and base plate with 6 holes in base plate, 5 of which were about 1/4" and 1 at slightly bigger than 9/32". I did take apart an AGCO 74037047 (filter for 426 7000 series). It had 49 pleats, coil spring, metal caps, metal crimped pleat ends, hard plastic tapered seal between base plate and element. 8 holes about 9/32" diameter. NAPA 1795 for 426.... 55 pleats, coil spring, metal caps, glued pleat ends, same hard plastic seal as AGCO, and 6 holes about 5/16". Fram PH3689 for 426..... 55 pleats, leaf spring, metal caps, metal crimp on pleat ends, flat cardboard type seal, 8 holes 1/4". ........................... Then 180/190 301 filters. Fleet Guard LF682.... 64 pleats, coil spring, metal caps, metal crimp on pleat ends, nice large diameter rubber seal diameter of element (other seals on filters above were smaller. 8 holes 5/16". Baldwin BT267.... 91 pleats! coil spring, metal caps, metal crimped pleat ends, large rubber seal along with the same type hard plastic tapered seal as AGCO & NAPA, 8 holes 5/16". .................... Then a NAPA 1796 (short filter used on 200 with 301 and can be used on 426-7000 series) 80 pleats, coil spring, metal caps, glued pleat ends, same hard plastic seal as other NAPA 1795, 6 holes 5/16". After all that (I should have put that info in a better format to read) I really only want to know if the Cenex CO-442/PH2850 is as good or better than AGCO's filter so if anyone has a used one and the time to take one apart, I'm all ears. BTW the Baldwin filter I took apart is hard to beat as far as I can see. |
DougS
Posted: 26 Jun 2016 at 8:59pm |
The filter media makes a big difference too. Synthetic media is far better than paper at trapping fines.
Lonn
Posted: 26 Jun 2016 at 9:05pm |
The only new filter I took apart was the Cenex. The rest are used and black with dirty oil. I have no idea as to what the Cenex has for media but so far I'm inclined to say the filter seems better than I thought it would be.
Edited by Lonn - 26 Jun 2016 at 9:06pm |
Play Farmer
Posted: 27 Jun 2016 at 5:29am |
Is that still true today? I'm not saying it is or it isn't, I'm asking. I'm just thinking if they were still junk, in today's world, they'd have a hard time staying in business. |
DougS
Posted: 27 Jun 2016 at 6:07am |
The filter is going to meet "minimum manufacturer's specifications." You can go with that. As for what is junk? How would the average person know? Advertisements do not give you the technical specifications. Most people subscribe to the theory of "it's advertised a lot, therefor it must be good." What would you rather use: A filter that removes dirt down to 40 microns or a filter that removes down to 20 microns of dirt? You'll never find this in an advertisement. Certainly not in a Fram advertisement. |
Gerald J.
Joined: 12 Sep 2009 Location: Hamilton Co, IA Points: 5636 |
Posted: 27 Jun 2016 at 9:13am |
In 1980 I bought a VW pickup (factory modified Rabbit assembled in the USA). I found the factory filter drain back valve failed at about half the oil change interval. In those days the Fram drain back valve lasted a full oil change interval. Since then the quality of Fram has gone down and their drain back valve failed early the last one I used and then the online tale of filter quality puts them bad. I've not taken any apart but the Delco that fit my most recent VW Golf seemed to do fine and the Motorcraft I used on my Fords haven't shown an external problem even when occasionally extending the oil change interval to 10K miles.
Gerald J. |
Play Farmer
Posted: 27 Jun 2016 at 10:26am |
Back when I changed my own oil I used Fram with no issues. Now I have my local Ford dealer do it - I came to the conclusion I wasn't saving a nickle vs what they were doing it for, so let them do it.
On my tractors I do those changes. I'm using Fleetguards on the 7000 & Massey, Motorcraft on my D17.
David G.
Posted: 27 Jun 2016 at 10:35am |
This is just my opinion, but if Fram wasn't sold at Walmart where the average Joe comes to buy oil and filters, it would be hard times for the company. Since Fram does advertise alot and makes their filters sound good, the average shade tree mechanic succumbs to the advertising and convenience of buying oil and filter while buying shampoo, light bulbs, tater chips, etc.....
HD6GTOM
Posted: 27 Jun 2016 at 1:19pm |
Lon when I was in the fuel/oil business in the 1970\1980's it was recommended any filter over 10 years old be discarded. Use your oun judgement.
bauerd44
Silver Level Access
Joined: 11 Sep 2009 Location: Wentzville, MO Points: 350 |
Posted: 27 Jun 2016 at 3:06pm |
David G posted.....The other day I changed the oil in one of my 175's (diesel) and decided
some input....
I have been running Motorcraft FL-1A in my 175 both on the motor oil and the hydraulic oil for 20+ years and have no complaints. I figure if they are good enough for my Ferds, they will work in my AC's. Dale |
Missouri Allis-Chalmers Club
CA Allis, 175 Allis, 185 Allis |
Lonn
Posted: 27 Jun 2016 at 3:12pm |
Play Farmer
Posted: 27 Jun 2016 at 7:30pm |
Thats the filter I run on my D17.
LeonR2013
Joined: 01 Jan 2013 Location: Fulton, Mo Points: 3500 |
Posted: 27 Jun 2016 at 11:07pm |
One thing I've seen with Fram filters. A motor will use oil with them and not with other good filters.
Lonn
Posted: 28 Jun 2016 at 6:59am |
So who makes the Cenex Filter I'm looking at? I just can't find that out by internet searches it seems.
Oh by the way, none of the used filters I took apart seemed to show any failure. I thought maybe the glued pleats would come apart over time but none of these with glued pleat had. |
Tbone95
Joined: 31 Aug 2012 Location: Michigan Points: 12421 |
Posted: 28 Jun 2016 at 7:16am |
Any explanation of that? |
Tbone95
Posted: 28 Jun 2016 at 7:17am |
I could see the glue drying / breaking down... |
Tbone95
Posted: 28 Jun 2016 at 7:18am |
Exactly! Why are they still in business building "junk"? Because they're cheap, and that's what the majority of the people buy! |
Tbone95
Posted: 28 Jun 2016 at 7:20am |
I used to get a kick out John Force being the spokesman for Fram filters. Seriously? Your engine has to last 5 seconds! Hahaha...then you're going to rebuild it!
I spent a summer assembling filters for AC (as in AC Delco). My God, what a crappy job!!!!!!!!!!! |
DougS
Posted: 28 Jun 2016 at 9:13am |
Truth of the matter is: Why would you bother putting an oil filter on a dragster? Edit: The same can be said for that K&N air filter commercial where they have the car stirring around in the dust. It doesn't prove anything to me. Edited by DougS - 28 Jun 2016 at 9:15am |
Tbone95
Posted: 28 Jun 2016 at 9:19am |
Exactly. |
