5015
AllisandGleaner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AllisandGleaner Quote  Post ReplyReply Direct Link To This Post Topic: 5015
    Posted: 19 Jun 2016 at 4:34pm
Looking to buy a 5015 with a belly mower and I wanted to know the transmission gear speeds anyone know what the speeds are thanks.
irlbeck A-C'S View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote irlbeck A-C'S Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jun 2016 at 5:38pm
It can go slow, real slow, and really really slow.LoL
Tires can adjust the speeds a little.
It appears top speed is 7.7 mph and goes down to a snails pace.
B,C,CA,(2)WC's,(4)WD's,(2) WD45'S, 45Diesel, (2)D12'S Series 2, D12 Hiclear,(2)D12 Series 3, HD3, D17NF (3)D17 Series 4 Diesels, M-100 Grader,8550,A few Lawn tractors lots of other AC stuff
Gary Burnett View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jun 2016 at 8:19pm
They can go very slow,I have a MF 220 which is about the same as the AC 5030 and don't use the lowest range even when I run the rototiller with it.Handy tractors down side
is there is No parts support.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AllisandGleaner Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jun 2016 at 8:41pm
Thanks looks like 2nd in high is the mowing speed
GARY(OH/IN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GARY(OH/IN) Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jun 2016 at 10:55pm
Yes 2nd in high at about 2500 RPM is what I run 2 different 4' bush hogs and a 5' finish mower if your grass isn't too heavy.
I have a manual for the 1582 3 blade 54" belly mower. Some mouse damage on front lower left cover, doesn't effect info. $5+ $2 postage.
timac5015 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote timac5015 Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jul 2018 at 9:50pm
why wont my 5015 start right up with new battery still needs a jump
I think the ccamps is 585   but I hit the glow plugs 5-7 seconds then nothing not even a click charged by truck it will eventually start right up and sound like a Porsche functions great when running I use it in the snow with 6 ft blade and cylinder lift but I got to be able to depend on it how long should block heater be on before planned use?
great forum any advice thanx guys
Post Options Post Options   Thanks (0) Thanks(0)   Quote timac5015 Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jul 2018 at 9:51pm
AM I NOT GIVING THE PLUGS ENOUGH TIME TO HEAT?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jul 2018 at 4:38am
If it is like most Japanese tractors of that era, I think the pre-heat time is 30-45 seconds.  Also check the buss bar, that connects the gp's together. it sometimes gets loose, on the gp's, and doesn't connect...
