D15 hydraulic problem
breedman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote breedman Quote  Post ReplyReply Direct Link To This Post Topic: D15 hydraulic problem
    Posted: 18 Jun 2016 at 10:13pm
I'm looking to buy a D15 but it has a hydraulic problem.When you start up the tractor the rams automatically rise and will not come down unless you push  the ball in on the remote and theres a noise in by the transmission on the left side that goes away when you push in the clutch.Is this going to be an expensive fix or can anyone tell me what they think the problem is ? Thanks in advance
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jun 2016 at 10:35pm
I suspect the hydraulic issue could just an adjustment of the traction booster linkage.  Is the noise in the transmission or torque tube?  Chances are it is nothing major, but I am not there and cannot hear it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote breedman Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jun 2016 at 10:42pm
The gentleman that has the tractor said the hyd problem and the transmission noise all happened at the same time 2 days ago when he started it up.You can feel the knocking noise on that side plate on the left side of the tranny.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jun 2016 at 12:13am
Traction booster linkage holding spool in or pivot stuck at valve.    MACK
Wendell(OK/TX) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Wendell(OK/TX) Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jun 2016 at 1:15am
What Mack said. I don't remember if the traction booster lever being all the way up will do that or not but I know if the linkage is jammed it will. The noise is probably the pump running full pressure against the checkvalve.
Post Options Post Options   Thanks (0) Thanks(0)   Quote breedman Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jun 2016 at 3:10am
Thanks guys,is there a way to unjam the linkage or fix the problem? I messed with the traction booster lever and it didnt make a difference where it was positioned so I put it all the way down where he said it always was.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jun 2016 at 5:59am
Sounds like a great way to get it for a LOWER price !  A dealer might want $1500 to look and fix, others will know. AFTER you buy, drain all the oil,clean the sump and pump,add fresh oil and it may work fine...if not, you'll have to open up the  pump and clean the internals.
If rest of tractor is OK... I'd buy at a 'good' price.
Jay
Post Options Post Options   Thanks (0) Thanks(0)   Quote breedman Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jun 2016 at 9:01am
I went over and looked at the tractor again this morning and its a 1962 series 1 model and all the external linkages are working freely.Could that big rod in front of the snap coupler have something to do with it ? Does that stick sometimes ?
copyrite1972 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote copyrite1972 Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jun 2016 at 5:11pm
I had issues with my snap coupler linkage getting stuck under my D15. I sprayed it down with WD-40, and pulled my trailer around the place a few times (The draw bar attaches to the snap coupler), and that seemed to do the trick.
D15 Series II
Post Options Post Options   Thanks (0) Thanks(0)   Quote breedman Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jun 2016 at 7:00pm
Did you have to take the pan off the bottom of the pump to spray it down because everything looks to be internal ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote copyrite1972 Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jun 2016 at 9:20pm
No, there is a big rod, and spring that is part of the snap coupler. My rod was stuck in the "Extended" position.
D15 Series II
Post Options Post Options   Thanks (0) Thanks(0)   Quote breedman Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jun 2016 at 10:01pm
Ok,great I will try lubing that up  tomorrow and pull my heavy disc around for ahwile. I bought it today so it surely is worth a try.Thanks everyone for the info
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jun 2016 at 8:08am
If traction booster linkage is adjusted right and nothing stuck, you will only feel pressure on lever at the upper two notched on lever.   MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote breedman Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jun 2016 at 9:28pm
Mack,where is the TB linkage holding spool ? I lubed everthing up down by the TB tonight and hooked it up to my heavy disc and dragged that around thinking it would free something up but it didnt. And if that isnt it where would the pivot stuck at valve be located ?
