Gleaner K Lift Trouble
TNtrapper View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TNtrapper Quote  Post ReplyReply Direct Link To This Post Topic: Gleaner K Lift Trouble
    Posted: 13 Jun 2016 at 8:58pm
Im having trouble with the K hydraulics. Its an early model K with the hydraulic can on top of the pump. I went to take the corn head off today to get ready for wheat and the header will only lift up a couple inches and stops. You can wait a couple seconds and try again and it will lift a couple more inches and stop again. The power steering still works good and when you try to lift you can hear the pump pull the engine. I changed the filter and a leaking lock out valve and still the same thing. The reservoir is full.I did notice that when I pulled the filter element that there was hardly any fluid leaking out while the filter was out. Is there a screen or filter in the reservior that could be starving the pump? I am stumped......Confused
Life is simpler when you plow around the stump.
Live simply, love generously, care deeply, speak kindly, and leave the rest to God
Dans 7080 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dans 7080 Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jun 2016 at 9:01pm
Check your belt tension on the pump. I had an F2 do the same thing.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jun 2016 at 10:27pm
If it has a safety shutoff on hydraulic cylinder, it could be shut off. Like Dan's said belt has got to be tight.     MACK
allisrutledge View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote allisrutledge Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jun 2016 at 1:36pm
It was the belt on mine . Put a new one on and it has worked for a year now.  Scott
Post Options Post Options   Thanks (0) Thanks(0)   Quote TNtrapper Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jun 2016 at 5:10pm
I will sure try the belt. I've kinda got side tracked today working on a roof. As always I picked the hottest day to fool with roof work. Lol.. I'm getting back to the K in the am and will put a belt on and see what happens. I've went over everything else I can think of. Sure hope the pump hasn't decided to take a dump.
