Fluid Or Concrete Ballast?
AaronSEIA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AaronSEIA Quote  Post ReplyReply Direct Link To This Post Topic: Fluid Or Concrete Ballast?
    Posted: 09 Jun 2016 at 6:53pm
Needing to fix a bad rim on my D17.  Have thought about not putting fluid back in them.  I'm in desperate need of counter weight in the winter, but could make a weight with a 55 gallon drum full of concrete.  Math says the drum would weigh around 800-900 lbs.  16.9 75% full of fluid are around 700 lbs each.  Would maybe have an issue if I were moving snow with my blade, but I haven't done that in several years.  Tractor does about 75% loader work.
AaronSEIA
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jun 2016 at 7:00pm
Fluid in the tires will be easier on the axles and bearings. And be better for lateral stability. On the other hand the drum of concrete will be further from the front axle and so have a longer lever arm so will do a pretty good job. Parking the drum is easier than getting the liquid out of the tires but gets in the way of using implements behind the tractor with the loader attached.
Either will probably work good enough.
Gerald J.
Play Farmer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Play Farmer Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jun 2016 at 8:27pm
I looked at doing used antifreeze in my 7000. Local bone yard had it for $1.00/gallon.
I ended up filling them with water and will drain them before winter. Obviously that won't work in your case, so maybe the antifreeze is the best option.
zulawski87 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote zulawski87 Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jun 2016 at 5:54am
I bought beet juice. Weight in the tire where you want it and won't rust out my rim. Kinda spendy tho.
Dan73 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dan73 Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jun 2016 at 6:14am
Would a set of wheel weights get you enough weight? My d17 has the pie weights on it they are 300 lbs per side. I don't use it in the winter or have a loader on it but she will pull like crazy I have used way too big equipment behind her and she doesn't seem to mind. Well ok the drawbar bends down when I pull the 930 jd moco but that is a monster way too big really.   Just need to get the case 5240 transmission fixed so my d17 doesn't hat to do that job.....
Allis dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis dave Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jun 2016 at 6:47am
I good amount of weight is pretty important with a loader. I would go back with fluid again. Pretty annoying when you just spin when trying to push snow because you're too light back there.
