Model 160 brush mower - HELP |
Shirbon
Topic: Model 160 brush mower - HELPPosted: 03 Jun 2016 at 5:42pm |
DiyDave
Joined: 11 Sep 2009 Location: Gambrills, MD Points: 55288 |
Posted: 03 Jun 2016 at 5:46pm |
Its an over-running clutch, allows the blades to spin down, without the drive shaft turning. Take it apart, and see if the 2 pins are stuck, or the springs are rusty and/or broken. If you need parts, Sandy Lake can get them to you in a day or 3...
TimNearFortWorth
Posted: 03 Jun 2016 at 7:15pm |
If "pins" are sheared, cut down some bolts that fit while still allowing it to ratchet when pto shaft turned backwards by hand. Springs need to be good as mentioned so the pins are kept engaged. Just don't go with too hard a bolt stock if you make your own pins and you may need to keep the large adjustment glad snug enough to keep everything mated up right. Tough little cutter, if gear box kept up with grease/oil and grease fittings at base are not forgotten.
Shirbon
Posted: 03 Jun 2016 at 8:00pm |
Ok, so that tells me there should be a pin or bolt through it. The holes in front and rear plates are obvious but the center plate is hard to tell. What appears to be sheared off doesn't look like it really line up with the other holes and looks like it may be impossible to drive it out, looks like maybe only 1 pin/bolt in it though I'm not sure. Any way to get a picture or a manual that shows/tells me more about it and making adjustments etc ? Otherwise may not be the easiest for me to figure out what to do. Thanks.
Shirbon
Posted: 03 Jun 2016 at 8:04pm |
If the springs engage the pins, do the pins go all the way through all the plates ?, sounds a bit confusing to me.
TimNearFortWorth
Posted: 03 Jun 2016 at 9:15pm |
PM me with your e-mail so I can get your address; found a spare manual for that cutter while sorting through my A-C manuals today and can send it to you.
Tracy Martin TN
Joined: 11 Sep 2009 Location: Gallatin,TN Points: 10936 |
Posted: 03 Jun 2016 at 11:10pm |
Shirbon
Posted: 04 Jun 2016 at 7:27am |
Ok timnearfort worth, I pm you, see if I did it right.
Shirbon
Posted: 11 Jun 2016 at 10:53am |
Still looking for a manual, or a picture, or more help
Pat the Plumber CIL
Joined: 11 Sep 2009 Location: Springfield,Il Points: 4988 |
Posted: 11 Jun 2016 at 12:56pm |
I will see if I can get a picture of my over running clutch tonight when I get home. Can you post any pics. My over running clutch doesn't have plates. There is a spring loaded slip clutch right before the over running clutch
1964 D-17 SIV 3 Pt.WF,1964 D-15 Ser II 3pt.WF ,1960 D-17 SI NF,1956 WD 45 WF. |
Shirbon
Posted: 12 Jun 2016 at 7:04pm |
Try to send a photo but probably won't work for me
Steve Bright
Joined: 14 Sep 2009 Location: Martinsville, I Points: 2107 |
Posted: 12 Jun 2016 at 7:08pm |
First spray the spring area with WD 40, several times, peck on the cast area around the area to see if the springs are rusted and stuck in the holes
Shirbon
Posted: 12 Jun 2016 at 7:10pm |
TimNear FortWorth, read your msg the other day tried to pm you don't know it you received it. I'm still interested in a manual or a picture or more help in any way. Thanks
Brian Jasper co. Ia
Joined: 11 Sep 2009 Location: Prairie City Ia Points: 10508 |
Posted: 12 Jun 2016 at 8:46pm |
I bought new pins and springs for the overrun clutch from Sandy Lake. You can go online to agcopartsbooks.com and view the parts breakdown as a guest viewer.
I did find that on my 160 the slip clutch isn't what is shown in the parts breakdown. Mine actually has a friction clutch where the parts breakdown shows a spring loaded setup. |
Shirbon
Posted: 13 Jun 2016 at 8:33am |
Yeah, not sure mine has springs if it does I don't know where they are located, though it has hole in frontand rear plates but doesn look like it has holes in middle plate for a pin or bolt. That's why I'm trying to find a picture or a manual or something that will show me what it all looks like. Thanks
CTuckerNWIL
Joined: 11 Sep 2009 Location: NW Illinois Points: 22825 |
Posted: 13 Jun 2016 at 9:11am |
If it is a spring loaded slip clutch, there wouldn't be any holes in the middle plate. The 2 outside plates would be bolted with spring pressure trying to pull them together. The middle plate would be squeezed between them making friction the only connection to the gearbox from the PTO shaft.
The front plate would be connected to the PTO shaft and the middle plate connected to the gearbox input. |
TimNearFortWorth
Posted: 13 Jun 2016 at 10:33am |
Sirbon,
Have responded to PM's and e-mails, including e-mail response sent today. Super busy and do not live on-line. If you would have included your address in any of the messages, you would have a nice manual in your hands by now . . . . . |
Shirbon
Posted: 13 Jun 2016 at 9:49pm |
If it has springs where are they coated, on the pin/bolt, somewhere in the clutch discs, I have no picture to go by. The diagram on account parts book is not large enough or clear enough to really tell
Shirbon
Posted: 13 Jun 2016 at 9:51pm |
Where are springs located if it has springs ? Agcopartsbook doesn't really show it clearly
