WC steering u-joint
littlemarv View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote littlemarv Quote  Post ReplyReply Direct Link To This Post Topic: WC steering u-joint
    Posted: 03 Jun 2016 at 12:35am
Does anyone have a good number for the steering shaft U-joint on a WC or WD (probably the same?)
Something I can go to Napa and cross, hopefully?
Thanks in advance.
The mechanic always wins.
TomMN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TomMN Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jun 2016 at 8:43am
A few of the vendors on here have them.  Steiner has them as well:
http://www.steinertractor.com/ABC167-universal-steering-joints-repair-kit
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jun 2016 at 9:01am
I bought one for my WC, don't remember where I got it from, but it was physically bigger around. One day looking thru my scrap pile, I saw some salvaged parts from a 60 All Crop combine. The same U joint was right there in front of be except I had to drill the cross holes for the pin. The combine has a key slot and a set screw.
Post Options Post Options   Thanks (0) Thanks(0)   Quote littlemarv Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jun 2016 at 10:31pm
Turns out the u-joint I been putting in Ford and Sterling heavy trucks for years is a close match. I just had to file a tiny bit off each ear to gain just a sliver of clearance to slide the snap rings in.
Here is a picture of the box, in case the part numbers mean anything to anybody.
