190 XT cold air intake conversion
PA Luke View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote PA Luke Quote  Post ReplyReply Direct Link To This Post Topic: 190 XT cold air intake conversion
    Posted: 31 May 2016 at 11:17am
My XT currently has the box type air box in the front.  Would I see any HP increase if I convert to the cold air, through the hood, style?  Anyone ever do this?
Thanks!
CAL(KS) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 31 May 2016 at 11:59am
doubt you could ever quantify any benefits other than less dust into the air filter, as its already in front of the radiator heat.  does yours not have a precleaner and pipe through the hood?
Post Options Post Options   Thanks (1) Thanks(1)   Quote PA Luke Quote  Post ReplyReply Direct Link To This Post Posted: 31 May 2016 at 12:19pm
Nothing through the hood.  Just the canister in front of radiator.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 31 May 2016 at 12:28pm
The air intake pre-cleaner above the hood in dusty conditions usually helps a bunch in the air cleaner needing less attention. The temp of the air is the same for the engine to breathe.
Post Options Post Options   Thanks (0) Thanks(0)   Quote PA Luke Quote  Post ReplyReply Direct Link To This Post Posted: 31 May 2016 at 12:32pm
Okay, thanks.  I was under the impression that the, above the hood, air cleaner replaced the one under the hood.  I didn't know it was a pre-cleaner for the filter.  Thanks again!
DougS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougS Quote  Post ReplyReply Direct Link To This Post Posted: 31 May 2016 at 12:48pm
The air is already going to be plenty hot once it goes through the turbo, regardless of intake temperature at the filter. You get bang for your buck if you can figure out how to install an intercooler.
grinder220 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote grinder220 Quote  Post ReplyReply Direct Link To This Post Posted: 31 May 2016 at 1:17pm
Get an intercooler off a 7020, that's what I did. Really easy to adapt to a 190XT. You will also need the spacer for the oil fill neck.
