Model b wont start need help
Hamblin28 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hamblin28 Quote  Post ReplyReply Direct Link To This Post Topic: Model b wont start need help
    Posted: 29 May 2016 at 5:02pm
My father in law rebuilt this tractor over a few years he had given up on it but I'm determined to get it running for him. I has new sleeves pistons carb everything, I just times the mag number 1 cylinder fires on the center mark. I know the firing order is 1243 that all checks out.
It is kinda hard to crank I see videos where they spin super easy so I'm guessing this is because of it all being new with good compression. When I had the number 1 plug out checking time I got a fire ball out of the manifold guessing fuel got to the exhaust and 2 set it off.
Fuel drips out of the carb from what looks like a pin hole not sure what that is or why it's leaking. Anyone know how to set up the carb to factory settings? I may need to try and pull start it once my tires are mounted.
Any help is greatly appreciated!
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 29 May 2016 at 5:35pm
You could have spark at TDC of number one and still be out of time IF it has the wrong magneto or the mag was assembled wrong. Maybe you should go down the line checking spark at TDC of each cylinder?
 If it was all rebuilt, was the crankshaft timed with the cam properly?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hamblin28 Quote  Post ReplyReply Direct Link To This Post Posted: 29 May 2016 at 5:50pm
I have checked tdc and spark hits right the timing may not be perfect but it hits when the center mark is dead center in the inspection hole in cyl1. All 4 cyl spark when they are too dead center. He says he marked the cam and crank and put them back in the way they came out.
I think its a fuel issue but have no clue how to set the carb on these old tractors. The carb has a hole like a over flow on the bottom and it drips whenbi crank it. Any idea what that is?
I also don't think we are getting the motor to spin fast enough cause it only spins enough to fire one cyl then it stops I think it would need to spin more feely to start. I've never ran one of these tractors this is all new to me
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 29 May 2016 at 6:13pm
Couple thoughts, check the mag shaft, to make sure it is turning, and not worn enough to open and close the points, from side play (bushing wear).
Fuel leaking from the overflow could be float level too high, initial settings of 1-1/2 turns from gentle bottoming, should generally get it running.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hamblin28 Quote  Post ReplyReply Direct Link To This Post Posted: 29 May 2016 at 6:22pm
Okay so he showed me some picture from when he was rebuilding it he says there was letters on the crank and cam gears and he lines them up is this true? Of not is there a way to check if the cam gear and crank is lined up? If I have to tear it apart how do I time them to each other? I will set the carb screw right now
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hamblin28 Quote  Post ReplyReply Direct Link To This Post Posted: 29 May 2016 at 6:24pm
The mag is good I had it off in a vise and hand spin it it sparks on all 4 points good blue sparks so thats good
Dick L View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 29 May 2016 at 8:30pm
Easy to check the cam timing by taking the valve cover off and at TDC when you get spark on number one both valves would be closed or rocker arms up to where you can get your feeler gage between the rocker pad and the valve stem.
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 29 May 2016 at 8:36pm
In that vintage there was NO factory setting for the carburetor. There is a suggested begining setting that usually is good enough to get the engine to run but needs tuning after that to take care of variations inside the carburetor and engine. I know I've written tuning procedures on this forum in the last month or two.
Gerald J.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hamblin28 Quote  Post ReplyReply Direct Link To This Post Posted: 29 May 2016 at 8:37pm
Okay well I believe it is in time. The valves are both closed when the number 1 is on tdc when it fires. I have reset the carb screw no more fuel leaking and I smell fuel on the plugs. I just don't think we are getting enough rpm to get it started. I will try some starting fluid and see what happens. If not I will wait till my tubes come in and tires mounted, then try to pull start it with the truck. I'm new to tractors so I thank you guys for all the info hopefully this old tractor will run again soon!
Bill Long View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill Long Quote  Post ReplyReply Direct Link To This Post Posted: 29 May 2016 at 8:50pm
Hamblin28, I have to admire your determination to get my favorite running.  Many others would have given up.
The crank gear and the cam gear have timing marks that must be timed for the engine to run properly.
A few thoughts.  What year is the B? - serial number by the gear shift.  If you can do it send us a few pictures.  They may help.
Seems like you fuel flow is good but check to be certain - take off the fuel line where it enters the carburetor and open the valve.  Do you have go good steady flow.  Pull the carb and be certain the float is not damaged and floating.  If that OK then be certain the valve is cutting off the flow.  Then check the float level - I am away from home and do not have my library available.  Can someone give him the proper adjustment for the float valve?  While there it would be wise to clean the carburator - can never be clean enough
We all wish you the very best.  I want to see my favorite running right.  Especially from a person who is so determined.
Remember it is a family tractor.
Good Luck!
Bill Long
Edited by Bill Long - 29 May 2016 at 8:52pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hamblin28 Quote  Post ReplyReply Direct Link To This Post Posted: 29 May 2016 at 8:57pm
He bought a remain carb and it has had sitting in it for a few years I drained it all out and put fresh in. I have not disassembled the carb yet which I probably should to clean it. The tractor was left by a family member that Owens the house before. It has sat for 20 years they got it running then it sat for some years. When they went to start it the piston has rotted so the rod went through it. Now it has all new sleeves piston everything it just needs some tlc to get it back to it's former glory.
Are these timing marks on the crank and cam visible without taking the motor back apart? I was not the one who reassembled it I am just the determined one trying to get this thing back to it's former glory
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hamblin28 Quote  Post ReplyReply Direct Link To This Post Posted: 29 May 2016 at 8:58pm
It's also a 1942 b
Stan IL&TN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stan IL&TN Quote  Post ReplyReply Direct Link To This Post Posted: 29 May 2016 at 9:04pm
Sounds like it's just flooded to me. Shut off gas. Clean or replace spark plugs. Drain carb bowl. Crank over engine with no plugs to help dry out cylinders. One other thing to check is be sure the engine has air. Too many folks have had a mouse or bird build a nest in there and the tractor will not run without air. At this point I would keep the gas off and see if it would run a few seconds on starting fluid. Then turn on the gas and see if it will run.
1957 WD45 dad's first AC
1968 one-seventy
1956 F40 Ferguson
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hamblin28 Quote  Post ReplyReply Direct Link To This Post Posted: 29 May 2016 at 9:08pm
It has brand new champion plugs, I will pull the plugs and crank it over with the fuel off then throw the plugs back in to see if it will fire on starting fluid. It is getting air and if I put my hand over the carb when a friend cranks it It trys to pull my hand through the carb haha. I need to disassemble the carb and make sure the jets are clean, is the crank and cam gear timing marks visible without taking the motor apart? Sorry for my lack of knowledge on tractors haha
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 29 May 2016 at 9:53pm
Get rid of the Champion plugs. They don't clean up after being coated with carbon from rich running for firing. The Champion vintage tractor plugs are junk.
The crank and cam gear timing is under the engine front cover. You have to take off the crankshaft pulley to take that timing cover off of most engines. And probably have to pull the radiator with the engine in the tractor.
All my engines with updraft carburetors need full choke to fire while cranking, but need the choke opened as soon as they have run a few seconds.
Gerald J.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hamblin28 Quote  Post ReplyReply Direct Link To This Post Posted: 29 May 2016 at 10:15pm
Okay well tomorrow I will check the crank and cam timing. What plugs do you recommend?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 30 May 2016 at 6:54am
No need to check the timing gear marks when the  valves are working properly as you already checked with the rocker arms and spark at that time.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 30 May 2016 at 7:10am
If it is out of time at the gears you will not get vacuum to get fuel to the plugs.
I do not have batteries in my magneto tractors. Battery costs are to high for me to keep up for as many tractors that I have that do not get used regularly. I start them all 6 volt tractors  with a 12 volt jump start hooked directly to the starter.  Before I bought the jump start I used a 12 volt tractor.
Hubnut View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hubnut Quote  Post ReplyReply Direct Link To This Post Posted: 30 May 2016 at 7:40am
Start with the easiest things first.  I would not open up the engine to check the gear marks.  You already checked that with DickL's suggestion.  Assume you are good there.  Sounds to me like the mag is not timed properly yet.  These can be tricky, but are reliable units in my opinion.  Focus on clearing the excess fuel.  Then, keeping the fuel off, I would shoot some starting fluid in the carb intake (just a shot), and get a pop.  Once she pops and you know the mag is firing in time, then work on the fuel.  I agree with others that your float is either too high or the cut-off pin is stuck open.
1940 B "Lucy"
1941 B w/ Woods L59 "Flavia"
1942 B w/ finish mower "Dick"
1941 C w/ 3-point "Maggie"
1947 C SFW w/ L306 "Trixie"
1972 314H
Leon n/c AR. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Leon n/c AR. Quote  Post ReplyReply Direct Link To This Post Posted: 30 May 2016 at 8:43am
I would not vote for tearing engine down to check cam timing at this point. I would pull the carb and clean it and check all passages and jets to be sure not gummed up . Second I would re verify TDC on compress by watching to be sure Intake opens and closes just prior to firing on #1 cylinder-both valves will be closed on tdc on next rotation also. Third if that does not work I would try pull starting tractor. Leon
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 30 May 2016 at 8:48am
If the carburetor has set a long time and had gas in it  does need cleaned. If your using carburetor cleaner in a spray can for inside passages you might as well use cold water. (NOT)   I boil any carburetor in liquid laundry soap. I use a half cup of soap to a half gallon of water.  That will softer the gunk and then your spray can of carb cleaner crap will blow it out maybe.  For one carburetor it would be cheapest way.  What carburetor do you have? Does it have the adjustable power jet?
Edited by Dick L - 30 May 2016 at 8:50am
dave63 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dave63 Quote  Post ReplyReply Direct Link To This Post Posted: 30 May 2016 at 8:52am
I had a hard time starting my C after rebuilding it.   One simple thing that took me awhile to figure out.   I installed a good used exhaust manifold that I got my hands on and didn't put the steel plate on it.   The screw holes were open and it would not run until I put screws in those holes.
Another note, Allis Chalmers published a wonderful service manual.  No one should be with out this manual.   you can get one from any AGCO dealer. Do not waist money on an IT manual.
The universal answer to all questions is yes, how much do you want to spend?
Post Options Post Options   Thanks (0) Thanks(0)   Quote dave63 Quote  Post ReplyReply Direct Link To This Post Posted: 30 May 2016 at 9:07am
It was hard to get my C running by hand cranking.  I had no one to crank for me.  If you have another belt pulley tractor you could belt it up and crank it over through the belt pulley.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 30 May 2016 at 10:11am
Used to be able to download vintage AC tractor service manuals from www.grandpastractors.com but its been hacked. I have manuals downloaded for B, C, G, CA, and WC and can e-mail them unless there is an attachment size limit for e-mail. I suppose I should make a web page for them, or at least a file folder on line. I have one shop manual that covers B, C, G, and CA in one manual from AC, and separate manual for G only, a G parts book, a military B manual, and a WC manual in 9 pieces about 9 MB each.
As far as plugs, any brand but Champion.
Gerald J.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hamblin28 Quote  Post ReplyReply Direct Link To This Post Posted: 30 May 2016 at 10:46am
I have varified timing I know it won't be perfect till I can fine tune it when it's running but I find the fire mark in the inspection cover then slowly crank. The magneto pops and fires the number 1 spark plug on the center mark. I've gone down the line and done this with all 4 cyl to make sure they spark on tdc and they do. I think I need to pull the carb and disassemble and clean it really good then find a post about the float adjustment to make sure that's all in order. He had bought that car as a rebuilt used one so who knows if it was ever adjusted to factory spec. Last night I got a pop through the exhaust with starting fluid but I don't think it's spining fast enough to get it running since the rings haven't sat yet. I will get it running one way or another haha
WF owner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 30 May 2016 at 12:52pm
It's been a while since I did it, but there should be two timing marks on the flywheel of a B. One is TDC and the other is FIRE. The fire mark is for the impulse of your mag when turning it over slowly. Make sure you have the FIRE mark timed correctly.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hamblin28 Quote  Post ReplyReply Direct Link To This Post Posted: 30 May 2016 at 12:55pm
From what I've read the "fire" mark is when the piston is 30 degrees out then the "center" mark is too dead center and when the number 1 spark plug should fire. That's how I have it times to fire on top dead center
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 30 May 2016 at 2:20pm
You absolutely don't want the impulse to fire when cranking before top dead center. That makes for really hard cranking because the combustion will turn the engine backwards and break your cranking arm or hand. The impulse mechanism in the magneto has two jobs, one is to delay the spark for safe cranking, and the other is to spin the magnet past the coil much faster than the shaft is rotating to generate more voltage in the magneto coil so there is enough for ignition. You want the spark before top dead center when running to allow for the delay of the combustion getting up to full pressure.
Gerald J.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hamblin28 Quote  Post ReplyReply Direct Link To This Post Posted: 30 May 2016 at 2:30pm
I have it set to fire at the center mark on the fly wheel which is too dead center from what I've read that's correct untill I get it running to fine tune the timing.
Just to make sure i have this right , fire is when the piston is 30 degrees off of top dead center. The spark plug should fire on the "center" mark which is top dead center right?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 30 May 2016 at 3:50pm
When cranking you want the spark slightly AFTER top dead center, otherwise it will kick back and break your cranking hand. When running you want the spark 30 or so degress before top dead center else the engine efficiency is very very poor, no guts. Engines with distributors use centrifugal advance to vary the timing with the engine speed for better fuel economy and engine performance. Automotive engines add vacuum advance for part throttle operation because that gives better performance. I changed a car engine from dual advance to centrifugal advance once and with centrifugal only it performed great at full throttle but was doggy at part throttle. I went back to the dual advance as soon as I could acquire a new original distributor.
Gerald J.
This page was generated in 0.110 seconds.
