Hand clutch adjustment CA (need help)
Hubnut View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hubnut Quote  Post ReplyReply Direct Link To This Post Topic: Hand clutch adjustment CA (need help)
    Posted: 27 May 2016 at 6:10pm
I got my CA back together and test drove it today.  Everything is good except the hand clutch won't disengage.  Just had Rick C rebuild it, so I know it's just an adjustment thing.  Which way do I turn the clutch cog in the final drive to make the clutch disengage?
1940 B "Lucy"
1941 B w/ Woods L59 "Flavia"
1942 B w/ finish mower "Dick"
1941 C w/ 3-point "Maggie"
1947 C SFW w/ L306 "Trixie"
1972 314H
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 27 May 2016 at 6:19pm
When your looking down in the hole the throwout bearing need to get closer to the clutch pack. The specified setting it .050" as long as it isn't turning the bearing it will be fine the extra clearance is just to allow for wear.
GregLawlerMinn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GregLawlerMinn Quote  Post ReplyReply Direct Link To This Post Posted: 27 May 2016 at 6:20pm
Can't remember the direction of rotation; however, you can do this. Check the gap between the clutch and actuator; adjust the cog until you have 0.020-0.040" clearance. If you can't disengage then, the clutch may be froze to the pressure plate.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hubnut Quote  Post ReplyReply Direct Link To This Post Posted: 27 May 2016 at 6:41pm
Thanks guys.  Where am I supposed to measure this gap you're talking about?
1940 B "Lucy"
1972 314H
Rick View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rick Quote  Post ReplyReply Direct Link To This Post Posted: 27 May 2016 at 6:45pm
That measurement would be between the throw out bearing face and the pressure plate assembly, where it makes contact.    Rick
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hubnut Quote  Post ReplyReply Direct Link To This Post Posted: 27 May 2016 at 8:42pm
I see it now.  Thanks.  The distance is pretty wide.  I'll tighten it up tomorrow.
1940 B "Lucy"
1972 314H
