Brush hog blades
cosborn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cosborn Quote  Post ReplyReply Direct Link To This Post Topic: Brush hog blades
    Posted: 12 May 2016 at 7:49pm
I broke a blade on my Sun master rotary mower by Sunflower industries, modal ca-160d and am having trouble finding a replacement.
Any suggestions?
1949 "C" vin #c71215, 1939 "B" Wide front, WD45 nf, WD45 wf, 1941 "C" work in progress. Wd wide front
Ray54 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ray54 Quote  Post ReplyReply Direct Link To This Post Posted: 12 May 2016 at 9:31pm
I broke a blade on a Bushhog, the  price on line or the local Bushhog dealer was about the same no shipping from the local dealer. This mower is old and I thought I mite have trouble but  was very easy. But Bushhog is still in business which helps too.Good luck.
Edited by Ray54 - 12 May 2016 at 9:33pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 13 May 2016 at 5:01am
Take a good blade and go shopping at TSC. Should be able to match it up, if they have it in stock.  If not, take measurements and go on the innernut to Shoup or tisco...
Stan IL&TN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stan IL&TN Quote  Post ReplyReply Direct Link To This Post Posted: 13 May 2016 at 7:32am
Buy two sets. If it broke once then it will again. I always keep a spare set sharpened and hanging on the wall just in case.
1957 WD45 dad's first AC
1968 one-seventy
1956 F40 Ferguson
SHAMELESS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SHAMELESS Quote  Post ReplyReply Direct Link To This Post Posted: 13 May 2016 at 9:12am
a lot of farm stores are starting to carry generic ones, if you know the size you can check locally first, if close, maybe a machine shop can cut one down to size? I had an old Sunmaster, and found new blades for it years ago, but the rest of the mower wore out/broke before I could get them changed.
Creek Jenkins View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Creek Jenkins Quote  Post ReplyReply Direct Link To This Post Posted: 13 May 2016 at 11:09am
Sunmastr is now owned by Art's Way, they still sell parts but can be a bit pricey. The original blades on mine were really soft, they bent easily when hitting small rocks or wood chunks, I bought a new set, can't remember where.. New blades are really hard, been running for grass cutting 3 years now haven't bent one yet on the occasional rock or stump. They are a bit strange as no center hole, just two holes either side of center.
ASAP Tractor parts has a blade that looks like mine, for a 60" deck:
•Replaces Arts-Way OEM nos R66103
•Length: 21-5/8"
•Rotation: CW
•Width: 3"
•Thickness: 3/16"
•Bolt Holes Diameter: 1/2"
cheers,
Creek
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 13 May 2016 at 11:48am
Agri-Supply would be my first place to try. if you go to TSC they'll tell you Tough $hit Charlie
