301 HP
Charlie175 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Topic: 301 HP
    Posted: 09 May 2016 at 12:25pm
What HP can a Non-turbo 301 crank out? Like say in a 180/185?
I know they are rated at 64 & 75 HP, but have read that they can run close to 100 hp? or is that wishing?
This would be a stock motor, no mods other than fuel adjustment.
Charlie
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 09 May 2016 at 1:52pm
we can adjust fuel system to get way more fuel, but unless you turn more rpm's I'd be surprised if it would exceed 90hp. 190 was 77.20, but at 2200 rpm.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 09 May 2016 at 2:23pm
I overhauled one mighty One-Ninety is all my years of wrenching. It made just barely the 77 rated HP with pretty heavy smoke and the timing set at 28 degrees and fixed. The later 185's with the pump timing advance were a lot cleaner burning, but I just don't see how one would ever get to the 100 HP number without a turbo.
WF owner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 09 May 2016 at 3:49pm
I was dynoing 82 hp. back when I was pulling in the late 70's with a LOT of black smoke.
tbran View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 09 May 2016 at 9:27pm
I did some night time dyno pulls on the 185 with the bosch injectors lately.  These injectors definitely are better naturally aspirated than the AC's.  However even here about 85-88 hp is about all one can get - one simply runs out of  air with the siamese'd runners in the head and the rpms drop sharply after the needle hits this 85 hp at 2000 rpms on an M&W dyno.  More fuel from opening the 2 roller pump yielded only about 5 extra hp over backing out the torque screw. However this is about 10 better than Doc's experience.  Busting up the fuel with a good advance really helps.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 09 May 2016 at 10:04pm
Years ago, I wanted to try and mount a large 2-barrel or mechanical 4-barrel carb ahead of the radiator and provide windshield washer fluid or methanol to it for fuel, and saturate the air going into the engine and see what would happen. I know a guy who just sprayed washer fluid into a naturally aspirated diesel tractor pulling and as soon as he turned it on, the engine died. Doing that on a turbo engine works well, but I think naturally aspirated would work too if it was run thru a carburetor to vaporize it. That way, the 100 HP number might be a reality.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 09 May 2016 at 10:23pm
Kinda like burnin brush piles around hear Tim.LOL!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 10 May 2016 at 5:18am
Thank you for the info.
Charlie
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 10 May 2016 at 6:41am
The easiest way to ad HP to a non-turbo diesel is to inject liquid propane. The heat it removes from the air to vaporize the propane shrinks the volume of air allowing more to reach the cylinders and then the lean mixture accelerates the ignition when the diesel in injected. Remember to start with a small amount and only increase the propane in small amounts until you get things working for you. Too much can produce catastrophic results.  I mentioned this to a fellow pulling a R JD about 30 years ago and after awhile he realized I was serious and not full of it. Later has was making about 110 HP from a stock R at stock RPM, although the knocking sounded like thunder.  It wasn't long before he found out why the JD engineers added a center main bearing to the 820s.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 10 May 2016 at 9:06am
....added a center main....LOL. Bet that hurt
tractormanpj View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tractormanpj Quote  Post ReplyReply Direct Link To This Post Posted: 10 May 2016 at 9:24am
Our 190XT at one time was pumping out about 125hp. It had flames coming out of the muffler!
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 10 May 2016 at 3:47pm
propane was used many years ago - however it was not kind to engines at an amount necessary to increase hp on naturally asp engines.  You engine theorist out there, would the combustion rate of alcohol cause a knock in a diesel.??? If one had as much diesel to absorb the available air during combustion would any additional fuel help or would it even burn.  Or would the substitution of alcohol to an under max fuel engine result in an increase in HP?? Just thinking out loud...
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 10 May 2016 at 3:50pm
I know from experience, a stock 7060 or 7080 will jump 60 PTO HP when spraying windshield washer antifreeze inside the air cleaner. The rate is 12 ounces in 30 seconds. It does seem that when the engine is overfueled more, the alcohol kick becomes less.
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 10 May 2016 at 4:01pm
Turboed engines like the Water/Alcohol mix much more than those without a turbo. The mix will help some with excessive timing to get EGTs down, but won't really do much for HP without a turbo to pressurize and heat the intake charge. Also It would need to vaporize somehow to get it to burn. Alcohol doesn't like to vaporize easily. I'd tried this back in the early 70s and found the propane was much more beneficial and less touchy than getting the Alcohol to start slow and then ramp up. You can easily over fuel a non-turbo diesel. to get more power you need more air. This happens when it removes the heat from the atmospheric air to vaporize the propane. Hold your hand near a propane leak sometime, you'll get frostbite.
Jordan(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jordan(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 10 May 2016 at 4:17pm
Would those injectors be the same as an 8030?  Cause I have a set, and a 180?
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 11 May 2016 at 10:42pm
holes are smaller on a 185 but I would bet yes they would increase hp NA.. the head on the pump would have to be good to pop close to 4000 psi... part of the atomization issue.  OF course the lines are different as well as the drip.
WD45Diesel57 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WD45Diesel57 Quote  Post ReplyReply Direct Link To This Post Posted: 12 May 2016 at 7:29am
when dad bought his 185 new in 1972 they dynoed it and it was cranking 92 at the pto before it was broke in!
1-B's, 2-C, 2-CA's,2-WF, 1-WC,1-G, 3-WD's, 2-WD45, 1-RC, 1-D17 Diesel, 1-D14, 2-D15,1-D17 row crop,1-D19 gas and All Crop 40,60,66,72,90 and 100
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 12 May 2016 at 8:34am
Yeah, well......30 degree air temps and an old M&W dyno might reflect that, but it wasn't true.
DanD View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DanD Quote  Post ReplyReply Direct Link To This Post Posted: 12 May 2016 at 9:46am
I am usually skeptical of unusual horsepower reports.  I was once at a tractor show where they had a "dyno" set up for guys to test their tractors.  Idiot running it would just crank the RPM down as far as it could go and then read the horsepower number.  I'll make up numbers here but it was stuff like a stock H Farmall at 60 HP and a 75 HP A John Deere.  Stuff like that.  I tried to explain to the guy running it how to properly ready the dyno but was call a "stupid a**hole" so I just let everybody believe their fantasies.
427435 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 427435 Quote  Post ReplyReply Direct Link To This Post Posted: 12 May 2016 at 11:07am
The old dyno's, like M&W, did not measure hp---------------they measured torque (actually, all dyno's measure torque, but the new ones with computers may tell you hp).  The dial giving the torque reading was printed with hp numbers, but those numbers were only correct at correct pto speed.
Pulling a tractor down below rated pto speed was an old trick that dealers pulled to make their customers feel good.
Plus, the numbers on the dial of the old dynos were purposely printed to give a higher reading than what was actually being measured.  Angry
Mark
GTH-L Simplicity
Post Options Post Options   Thanks (0) Thanks(0)   Quote WD45Diesel57 Quote  Post ReplyReply Direct Link To This Post Posted: 12 May 2016 at 12:45pm
Hey I didn't post this to get ridiculed this is just what they did and that's what dad always knew. you guys can believe what you want!
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 12 May 2016 at 4:43pm
Your not getting ridiculed,, just the truth
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 12 May 2016 at 4:44pm
Your not getting ridiculed,, just the truth ,these guys will kno
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 12 May 2016 at 6:15pm
The only experience with dynos is the M&W that my pump guy has. He reads pressure and gets that card with the sliding piece to read hp. I'm sure he knows the story on dyno tricks but l know him to be honest and trust him. When he built tha A pump for my 8070 he calculated the amount of fuel for desired hp. Looking for 220-240. Afer 20hrs farm use we dynoed it.Twisting the wheel it was climbing past 290 so the fuel screw got turned down. Ended up around 230.It's not tied down or pulling oversized tools so it should live.
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 12 May 2016 at 10:45pm
The 301 in stock form will not pull over 80 PTO hp.  However if the rpm is lowered to approx. 1800 engine rpm then the dial will wrap around and point to over 100 hp.  Without getting into a lot of math, this is what I look for, at WOT start the pull and watch how the pressure goes up in relationship to how the engine or pto speed drops while listening to the engine.  An experienced tech can listen and feel and tell you the hp  pretty close with the eyes closed as to watching the guage as the hyd valve is closed on the dyno.
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 13 May 2016 at 8:11am
Tim is describing the torque rise. That is what I try to enhance when setting my customer's pumps/governors. This is what pulls the equipment through the field, and calls on the torque rise in tough spots. You don't want to be constantly overloading it in the field though. That is what shortens engine and drivetrain life!
