Wheel Weight Advice on a 185
GlenB(IA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GlenB(IA) Quote  Post ReplyReply Direct Link To This Post Topic: Wheel Weight Advice on a 185
    Posted: 03 May 2016 at 8:57am
I am thinking about purchasing a 185. The back wheels do not have fluid. The tractor has 18.4-28 tires. I would like to add some wheel weights. Would the wheel weights off of a WD45 bolt on? Would the section weights be better? Thanks!
DougS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougS Quote  Post ReplyReply Direct Link To This Post Posted: 03 May 2016 at 9:03am
Section weights would probably be heavier. WD weights might be hard to find, even if they would fit. I glanced through a few tire manufacturer's web pages a while back and they all seem to think that a 2WD tractor should be weighted 60/40 rear to front.
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 03 May 2016 at 9:22am
WD45 wheel weights are not a perfect fit.  You would need weights from a D17 Series III or newer because of the change from eccentrics to locking bolts for the power adjust rims.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 03 May 2016 at 9:30am
You'll have a lot of weights to match full fluid, which would be about 750 lbs per tire.
Play Farmer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Play Farmer Quote  Post ReplyReply Direct Link To This Post Posted: 03 May 2016 at 9:51am
Agreed. It's hard to beat fluid for not only the amount of weight but the cost per pound.
Butch(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Butch(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 03 May 2016 at 9:57am
Just to add to what has all ready been posted you WILL need a stack of iron on a 185 with no fluid if your going to do any type serious work with the tractor.  Ours has dry 18-4-28 rears, a full rack of suitcase weights up front plus the sectional weights on the back and it isnt near heavy enough although we get by with it due to our very light usage of the tractor.
Allis dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis dave Quote  Post ReplyReply Direct Link To This Post Posted: 03 May 2016 at 10:24am
If you're just doing light work or haying that you'll probably be ok with no weight. A 185 only weighs 6700lbs, so you won't do much pulling without some weight. It all depends on what your plans are for the tractor.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Skyhighballoon(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 03 May 2016 at 10:33am
I have 18.4X30's on my 180 filled with CaCl to the valve when it's rotated to the top.  It's just enough for tillage work (4X16's 74 plow, 13' 1200 FC, 12' Allis KT HD disc).   If I go to the creek with the loader bucket on and dip a bucket of gravel out, I hardly have any traction left in the rear.   Mike
1968 Gleaner EIII w 10' & 330
1969 180 gas
1965 D17 S-IV gas
1963 D17 S-III gas
1956 WD45 gas NF PS
1956 All-Crop 66 Big Bin
427435 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 427435 Quote  Post ReplyReply Direct Link To This Post Posted: 03 May 2016 at 11:28am
What are you planning on using the 185 for??
Mark
GTH-L Simplicity
Post Options Post Options   Thanks (0) Thanks(0)   Quote GlenB(IA) Quote  Post ReplyReply Direct Link To This Post Posted: 03 May 2016 at 12:30pm
I will be pulling a 14 foot disc, 6 row planter, and hay equipment. I am trying to decide whether to pump chloride into those tires with immaculate rims.      Yes, there would be no spinning with 750 pounds per tire with fluid!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougS Quote  Post ReplyReply Direct Link To This Post Posted: 03 May 2016 at 12:47pm
In all honesty you'd be better off putting duals on that tractor for your planned uses. You'd have less soil compaction too.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 03 May 2016 at 1:21pm
Methanol alcohol is best fluid. Doesn't rust the rim like calcium will. Some people like beet juice. JMHO, Tracy
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 03 May 2016 at 1:30pm
No matter what you put inside the tires for weight, the first time you have a flat all is lost and you have to pay to have it replaced. Cast I weights will last forever. As mentioned Duals would do you better in the long run and they are easy yo remove when not needed.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 03 May 2016 at 9:12pm
I don't have anything to poke holes in my tires so I prefer chloride but have found it a good practice to replace cores at least every other year if not every year.They get ate up and start leaking and if they go too long you're digging them out in pieces.
ILGLEANER View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ILGLEANER Quote  Post ReplyReply Direct Link To This Post Posted: 03 May 2016 at 9:18pm
Got a 185 in the shed Dad bought new. Never had fluid in it. Rims are perfect. 1 set of rear wheel weight. Pulled 15' disc when it was new, 6row planter, 8 row planter. 2 200 bushel wagons to town thousands of times. Don't ruin your rims.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Skyhighballoon(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 03 May 2016 at 9:19pm
x2 - every other year for me...cheap maintenance item...no issues so far.   Mike
1969 180 gas
1965 D17 S-IV gas
1963 D17 S-III gas
1956 WD45 gas NF PS
hillmonkey View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote hillmonkey Quote  Post ReplyReply Direct Link To This Post Posted: 03 May 2016 at 9:24pm
put a set of pie weights on the inside and a set of solids on the outside. Oh and post sum pics.
jiminnd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jiminnd Quote  Post ReplyReply Direct Link To This Post Posted: 03 May 2016 at 10:44pm
My 185 has 30 in rears, I have WD weights on it, maybe not perfect fit but will work.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Play Farmer Quote  Post ReplyReply Direct Link To This Post Posted: 04 May 2016 at 5:29am
I filled my 7000 tires with water. I have no plans to use it in the winter. After a discussion with my local tire guy we decided for how I'm using I'll fill them in the Spring and drain them in the Fall.
Its cheap, easy, and effective, and rust shouldn't be an issue.
It may seem like a bit of a pain to do this every Spring & Fall, and it may turn into one, but so far its a non issue. I hooked up the garden hose while I was doing some other maintenance stuff and let them fill.
Total cost - $10.00 for the fill valve.
Total weight - around 750-800# per tire.
I considered used antifreeze but didn't want to get into any disposal issues if I ever did have an issue. Used antifreeze is also pretty cheap and easy to get ahold of. Just check with your local boneyard.
Edited by Play Farmer - 04 May 2016 at 5:31am
This page was generated in 0.168 seconds.
