Allis C Steering Box Adjustment
KevinON View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KevinON Quote  Post ReplyReply Direct Link To This Post Topic: Allis C Steering Box Adjustment
    Posted: 02 May 2016 at 6:54am
Are there any tricks to adjusting up the steering box on an Allis C? There is still lots of set screw left on the right hand side of the box, but it doesn't want to turn in. I see that there is a slotted stud on the left hand side of the box that looks like it changes the pitch of the crank gear??? Thanks.
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 02 May 2016 at 7:30pm
If you have 2 adjustments, You have a GEMMER steering box. It would be best to have a service manual and follow those instructions. It's not just a simple deal of turning the one screw like a ROSS. They have to be in sinc with each other on the GEMMER.
Injnray View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Injnray Quote  Post ReplyReply Direct Link To This Post Posted: 01 Nov 2017 at 8:55am
So on the Ross type with 1 adjuster, simply turn it to reduce freeplay?
Clockwise I am guessing?
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 01 Nov 2017 at 1:45pm
I have the service manual on line at:
http://geraldj.networkiowa.com/Trees/Allis-Chalmers-G-B-C-CA-Service.pdf
Gerald J.
Dick L View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 01 Nov 2017 at 6:46pm
If your lucky! All I have tried to adjust didn't help as the pall/pin inside was wore down. I made up new palls.
[IMG]https://media.fotki.com/2vBU9zdVxevZ4.jpg[/IM
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 01 Nov 2017 at 7:02pm
Dakota Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dakota Dave Quote  Post ReplyReply Direct Link To This Post Posted: 01 Nov 2017 at 8:19pm
If you have a slotted screw on the left sid elf the box it's a gemmer box and there is no pin inside. Two of the nuts on the left side are eccentric sleeves in addatuion to the slotted pin. Download the service manual you'll need it. If when you adjust it up it gets real tight off center you'll need to disassemble and weld up the comb gear. It only has three teeth and it's not to bad. Just weld the center one up and angle grind it to what loo match the end teeth.
wfmurray View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wfmurray Quote  Post ReplyReply Direct Link To This Post Posted: 01 Nov 2017 at 8:42pm
I worked on one for a guy one time.It had the comb gear and was wore in center.Used four and half inch side grinder and ground teeth on each end so it would not bind  right or left and not loose in center.Guy was happy said he could not keep it in road in high gear before.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 01 Nov 2017 at 9:05pm
That would be the Gemmer that Kevin has. I have pictures of the gemmer some where but couldn't find them tonight for some reason. an old age thing I suppose.
