8000 Series Tail lights
JimWenigOH View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JimWenigOH Quote  Post ReplyReply Direct Link To This Post Topic: 8000 Series Tail lights
    Posted: 28 Apr 2016 at 9:11pm
A previous owner had put reflective tape on the lower edge of the cab on back where the red tail light was originally. I peeled the tape off, and on the left side there was a 1"+ hole under the tape along with some screw mounting holes. On the right side there were only the screw mounting holes, no large hole for the bulb well on the back side of the light asy. I would have thought there would have been a tail light on each side, but looking in the Parts Catalog, it just shows a quantity of one. I ordered two lamp asy. P/N 71504455 and received Truck-lite lamps that looked just like the amber flashers up above. Anyone have the factory original tail light on their cab, and was there only one?
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 28 Apr 2016 at 9:19pm
Don't think mine has one....hafta look.Which side is it on?
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 28 Apr 2016 at 9:24pm
The 8000 is the same as my 6080.  On the left fender is a bolt on reflector AND red tail light.  The right side only has the reflector.  I got the reflectors from NAPA, I had to get the light right from AGCO.  Everything bolted on and fit perfectly.
This is one of the few pictures of its rear end, you should be able to see everything you need ...
Edited by DSeries4 - 28 Apr 2016 at 9:32pm
Unit3 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Unit3 Quote  Post ReplyReply Direct Link To This Post Posted: 28 Apr 2016 at 9:41pm
Without going out to look, I will say there is only one on the left side. Would have been great to have them on each side with brake lights in them.
Michael V (NM) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Michael V (NM) Quote  Post ReplyReply Direct Link To This Post Posted: 28 Apr 2016 at 10:36pm
my 8010 has just 1 red tail light,,had to replace it,, IIRC the original was branded "truck lite", I'll bet all the lights that were used were the same brand
Kevin in WA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kevin in WA Quote  Post ReplyReply Direct Link To This Post Posted: 28 Apr 2016 at 11:09pm
Yes, just one tail light is all they had.
Daehler View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Daehler Quote  Post ReplyReply Direct Link To This Post Posted: 29 Apr 2016 at 6:31am
They were truck lite. I can get the number of what you need when this evening for you. Bought mine through Napa. Only difference was it was a three wire lite with 2 grounds.
Post Options Post Options   Thanks (0) Thanks(0)   Quote JimWenigOH Quote  Post ReplyReply Direct Link To This Post Posted: 30 Apr 2016 at 5:56pm
Thanks for the information. The AGCO 71504455 light is a Truck-Lite 60 with an 1157 bulb and 3 wire pigtail, one each for stop, tail and ground. I did a search on eBay for that model light, and saw there are quite a few variants of the Model 60.
Post Options Post Options   Thanks (0) Thanks(0)   Quote JimWenigOH Quote  Post ReplyReply Direct Link To This Post Posted: 30 Apr 2016 at 5:59pm
Do you know the NAPA P/N for the reflectors, and were they stick-on or use fasteners?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 30 Apr 2016 at 9:26pm
Don't know the part number.  I took an old one with me and they had them on the shelf.  New ones were actually BOTH stick on and used fasteners!  Even though the originals did not use adhesive, the new ones were identical in every other respect.
Post Options Post Options   Thanks (0) Thanks(0)   Quote JimWenigOH Quote  Post ReplyReply Direct Link To This Post Posted: 04 May 2016 at 8:32pm
Picked up the two red reflectors P/N 71504689, from AGCO today. They cost $2.49 each. I used some stainless steel machine screws I had on hand to mount them using the existing holes, perfect fit.
