7030 no powersteering but everything else works???
bobutzinger View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bobutzinger Quote  Post ReplyReply Direct Link To This Post Topic: 7030 no powersteering but everything else works???
    Posted: 18 Apr 2016 at 6:42pm
Our 7030 lost steering today...It steers a lil bit but then its like the oil dead heads. Oil is clean and almost no hrs on it. PD, and HYd Remotes work fine as do the brakes. Any ideas on where to look first?? Steering motor maybe? I thought id hope on here see if anybody else ever had this issue. Thanks Bob
B,B with snap co,2-C,CA,WC FLAT TOP,WC,ED 40,2-WD,2-WD45,2-WD45D,D10,D12,D14,D15,D15II, D17,D17D-S1,D17D-S3,D17IV,D19D,180,185,190Xt III,200,7000,7010,7030,2-7060,7060PS-Cummins,7080,K2D,F2D,F3D,2-M2D
Jwmac7060 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jwmac7060 Quote  Post ReplyReply Direct Link To This Post Posted: 18 Apr 2016 at 8:17pm
Orbital motor behind the dash...have fun with that..ID rather take an a$$ beating than change one of those
Jack(Ky) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jack(Ky) Quote  Post ReplyReply Direct Link To This Post Posted: 18 Apr 2016 at 8:49pm
I think it has a priority valve so the steering and brakes get first dibs for hyd pressure. They are supposed get pressure before anything else. I don't think the orbital motor would go out all of a sudden unless something broke which is unusual.JP
'59 D14 '68 170 Diesel '81 7020 40 All Crop
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 18 Apr 2016 at 9:49pm
I would say the gear pump split a gear. First, I would remove the flow divider spool and check for stuck spool or foreign material in orffic.    MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote bobutzinger Quote  Post ReplyReply Direct Link To This Post Posted: 18 Apr 2016 at 10:09pm
Where is the flow divider spool located Mack?
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 19 Apr 2016 at 7:52am
Remove big nut on bottom of gear pump. Behind nut there will be cap, shim, spring , orffic plate, then spool should come out.     MACK
Lynn Marshall View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lynn Marshall Quote  Post ReplyReply Direct Link To This Post Posted: 19 Apr 2016 at 8:18am
Post Options Post Options   Thanks (0) Thanks(0)   Quote bobutzinger Quote  Post ReplyReply Direct Link To This Post Posted: 19 Apr 2016 at 7:03pm
Update: After setting over night, it will work properly for about 2 hours and then starts this issue of not wanting to turn. If you turn it real slow it will but if you crowd it at all the steering wheel wants to fight back. I dont know if any of this makes a difference but, after 2 nights of trial and error and the fact that it works perfect for 2 hours or so i thought i would add this just so all the details were posted. I thought maybe this is something spawned once the oil gets nice and warm. Thanks for the help so far guys we really appreciate it. Bob
Adam Stratton View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Adam Stratton Quote  Post ReplyReply Direct Link To This Post Posted: 19 Apr 2016 at 7:44pm
Do you have easy access to another similar tractor or a 2 way cylinder with similar ports? I had a steering cylinder fail on a sprayer and it acted a lot like you describe. I found that out after having the orbital rebuilt...
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 19 Apr 2016 at 9:58pm
Are you sure it is full of oil?  Screw the bottom sight glass out to make sure it is full.
Go to your local Ago dealer and buy the left side trans. Filter. When you replace it, make sure there is a screen in inside end of filter. Take it out and put in new filter.     MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote bobutzinger Quote  Post ReplyReply Direct Link To This Post Posted: 20 Apr 2016 at 9:43pm
I took out sight glass full of oil. About 40 hrs on the oil (821) and the filter. I changed the filter again. Doesnt have much steering at all now after 30 mins or so. I am wondering if the pump is getting weak...The pump in the middle of the 3 is the one that controls the power steering correct? Thanks again Bob
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 20 Apr 2016 at 10:17pm
Yes, it is the middle pump. Sounds like time to pull pumps.      MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 21 Apr 2016 at 9:09pm
Had the problem with my 7030 today. Pulled pumps, gear pump had a deep grove all the way around where foreign material went are. found pieces of cast aluminum in flow divider.
 Hope your luck is better than mine.     MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote bobutzinger Quote  Post ReplyReply Direct Link To This Post Posted: 21 Apr 2016 at 10:46pm
I doubt we will fare better... Luckily we have a few spares from now 6 generations on the family farm and always using most all orange unless we couldn't pass up a deal on another color. The 7030 is dads baby...(one of several of the tractor species...) It chucked a rod back in the day and we had a 3750HI on a stand from when the 7580 when the rear end let go... so he stuck it in there, cut the cab down, nicely not just hacked it off... and went to town playing with it. He loves it. He will get the old White 4-150 out that we put a 318 Detroit in when the kitty let go for a 3rd time and play with it some on the finisher and Drop the 7080 onto the chisel to take the 7030's spot. Thanks for all the help. I hope to get a chance in a few days to pull the pumps.
Is the pump rebuild able or are the throw-away's? Thanks Bob
