How to measure engine bore?
CrestonM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Topic: How to measure engine bore?
    Posted: 18 Apr 2016 at 5:12pm
I was browsing engine overhaul kits and one overbore kit says it increases bore from 3 3/8" to 3 7/16". How do they measure that? Is it the OD of the sleeve? Inside diameter? Piston diameter?
Thanks
AaronSEIA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AaronSEIA Quote  Post ReplyReply Direct Link To This Post Posted: 18 Apr 2016 at 5:22pm
Inside diameter.
AaronSEIA
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 18 Apr 2016 at 5:26pm
Ok thanks! I was just curious. One of those things about engine rebuilding that I never knew.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 18 Apr 2016 at 6:10pm
It should be the Inside Diameter of the sleeve. The piston will be a couple thousands of an inch smaller.
