Help troubleshoot CA
Hubnut View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hubnut Quote  Post ReplyReply Direct Link To This Post Topic: Help troubleshoot CA
    Posted: 10 Apr 2016 at 5:32pm
Got a "new" CA.  Cleaned carb, installed new points and condenser.  Gas is new and clean.  Got her started and it ran fine for about 3 minutes, then it started to rev briefly, then slow and pop pop, rev, then pop pop.  After fighting with a bit, it wouldn't even pop anymore.  Some additional data: points were firing, plugs are little oily and maybe fouled, wires do not appear to be copper core, different carb from my working B didn't change anything, I adjusted the governor cross shaft to specs.  Any ideas?  I'll start with new plugs and wires next weekend.  Thanks.
Steve
1940 B "Lucy"
1941 B w/ Woods L59 "Flavia"
1942 B w/ finish mower "Dick"
1941 C w/ 3-point "Maggie"
1947 C SFW w/ L306 "Trixie"
1972 314H
grinder220 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote grinder220 Quote  Post ReplyReply Direct Link To This Post Posted: 10 Apr 2016 at 6:05pm
Put your old condenser back in. Had a D17 doing exact same thing after a fresh tune up. New condenser was junk, nothing is made like it use to be.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hubnut Quote  Post ReplyReply Direct Link To This Post Posted: 10 Apr 2016 at 6:29pm
Dang.  I used Agco parts made in usa, but I'll try anything once.  Thanks for the suggestion.
1940 B "Lucy"
1972 314H
B26240 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote B26240 Quote  Post ReplyReply Direct Link To This Post Posted: 10 Apr 2016 at 6:51pm
When you changed carbs to try the one from your B did you check to see if you had a good flow of fuel getting to the carb? Take gas line off carb and flow check it into a container for about 30 seconds or so.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hubnut Quote  Post ReplyReply Direct Link To This Post Posted: 10 Apr 2016 at 7:28pm
I didn't do it for 30 seconds, but about 5 seconds (both carbs).  Flow seemed to be good. However, I will try it longer.
1940 B "Lucy"
1972 314H
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hubert (Ga)engine7 Quote  Post ReplyReply Direct Link To This Post Posted: 10 Apr 2016 at 7:32pm
If you have good fuel flow then see if it starts again when cold. Could be a cracked or warped manifold that opens up when it gets hot and pulls too much air in. If it's pulling outside air it may not be pulling enough vacuum on the carb to pull the fuel mix into the cylinders.
Orange Blood View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orange Blood Quote  Post ReplyReply Direct Link To This Post Posted: 10 Apr 2016 at 8:03pm
I would be shocked if your Agco condenser is made in the USA!!
Still in use:
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hubnut Quote  Post ReplyReply Direct Link To This Post Posted: 10 Apr 2016 at 8:15pm
I got it from Sandy Lake.  It has a made in USA little sticker on it.  I just looked at the package.
1940 B "Lucy"
1972 314H
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orange Blood Quote  Post ReplyReply Direct Link To This Post Posted: 10 Apr 2016 at 8:20pm
Consider me SHOCKED!!!  Shocked
Still in use:
LeonR2013 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LeonR2013 Quote  Post ReplyReply Direct Link To This Post Posted: 12 Apr 2016 at 11:59am
Do you have a old Chebby setting around with points in it? Use that condenser, same thing. Leon R Cmo   By the way did it run all right before you started working on it? If so use that condenser.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 12 Apr 2016 at 12:11pm
Steve,
Didn't take you long to get on the tractors!  Is this Barbie we are talking about? If so that might explain it. Did you pat her on the hood and tell her she is the best one of the bunch???:)
I am the same way, new toys are meant to be played with! I chased some things like this on the WD this winter. I believe I did have a intermittent fuel flow and maybe bad fuel also problem. from the way you described it I might check the fuel system out first. These guys had me squirting some gas in the carb and that pointed me towards fuel issues.
BTW Sandy Lake is about 40 minute drive south from me. Looks like you may be ordering more stuff. Tell Brenda I said Hi! She is pretty darn good at getting you the correct parts for your old AC's.
Edited by Sugarmaker - 12 Apr 2016 at 12:14pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 12 Apr 2016 at 12:30pm
A new set of plugs n' wires is a very good start. (No pun intended) You'd be a bit surprised how a old set of plugs will make an engine run real lousy. On the fuel flow test, ya havta' go a lot longer than 5 seconds. Let it roll for a minute or so and watch it close. If you have a glass jar you can drain the fuel in, this will let you see of there's any debris in the fuel by looking through the side and the bottom of the jar. I have an old pickle jar I use for that test. Works great! Sorta sounds like Ignition though since you tried a proven Carburetor and it still acts the same. Get them new plugs screwed in that thing. And don't use Chimpanzes either! Put a real spark plug in it.. LOL!
Steve@B&B
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hubnut Quote  Post ReplyReply Direct Link To This Post Posted: 12 Apr 2016 at 6:54pm
Chris,
I talked nice to Barbie the whole time.  The other CA is Ginger.  Sandman let me change me mind on the loader wide front, so I now have two narrow front--one is a single wheel front!  I'm stoked!  I like the old Texas patina on the hood and tractor and plan to clean her real good and clear coat the original "paint."  There is a lot of the other orange too.  I like the original look.  I will get her torn down and rebuild everything and get her running good.  She will be a sleeper.
Steve, Thanks for the input.  I changed the wires tonight and will get new plugs Friday and give her another go.
1940 B "Lucy"
1972 314H
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hubnut Quote  Post ReplyReply Direct Link To This Post Posted: 16 Apr 2016 at 5:43am
Grinder.  That's what it was.  I put a different condenser in and it worked fine.  Dang.  Thanks for the help.
1940 B "Lucy"
1972 314H
Post Options Post Options   Thanks (0) Thanks(0)   Quote grinder220 Quote  Post ReplyReply Direct Link To This Post Posted: 16 Apr 2016 at 8:17am
Glad to hear it was something simple. I was fighting with my CA just a couple weeks ago. It was a fuel problem and I for the life of me couldn't figure it out. Had carb rebuilt and still wouldn't work. Took carburetor back off and ran up to AC tractor salvage and had Chester look at it, he didn't see any reason it shouldn't work then said something about the gas I was using. Well I never even gave it a thought as I just bought the gas last fall for my gleaner F combine, drained it out put new gas in and boom, fired right off. Again something so simple it will drive you nuts, and like I said before NOTHING IS MADE LIKE IT USE TO BE. All you get now is junk that won't last.
sandman2234 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote sandman2234 Quote  Post ReplyReply Direct Link To This Post Posted: 16 Apr 2016 at 9:06pm
I am glad it wasn't anything serious!!
David from jax
A proud member of the Allis Express movement!
               Northeast Florida
This page was generated in 0.048 seconds.
