CA Clutch Installation
davefullmert View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote davefullmert Quote  Post ReplyReply Direct Link To This Post Topic: CA Clutch Installation
    Posted: 05 Apr 2016 at 1:55pm
I just split my CA because I ran out of adjustment on releasing the clutch.  Sure enough, my fingers on the clutch plate are showing lots of wear.   5 years ago when I had the tractor split before I did not replace anything except the disk.  I think that was a big mistake.
At any rate, I have a new clutch kit for the 8 1/2 inch this one requires.  Included in the kit is a new release bearing.  After removing my old one, I looks like I may need to press the old one out of the assembly. Is that correct?
Also, once I have the new parts installed,  is there some trick to setting the adjustment of the pedal or is it just a trial and error until the pedal travel is right?
Thanks for all you experts out there.
Dave
Dave Fullmer
McKenzie, TN
LeonR2013 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LeonR2013 Quote  Post ReplyReply Direct Link To This Post Posted: 05 Apr 2016 at 4:39pm
That's about it, unless you have excessive wear in the linkage. Then you'd probably want to build up the worn spots. It would make everything work together better. I don't remember what the free travel should be set at but someone chime in on that. Leon R  Cmo
Post Options Post Options   Thanks (0) Thanks(0)   Quote davefullmert Quote  Post ReplyReply Direct Link To This Post Posted: 05 Apr 2016 at 5:06pm
Thanks Leon,
So my main question is do I have to press out the old release bearing from the casting?
Dave Fullmer
McKenzie, TN
Post Options Post Options   Thanks (0) Thanks(0)   Quote davefullmert Quote  Post ReplyReply Direct Link To This Post Posted: 05 Apr 2016 at 5:07pm
I don't really see any excessive wear in the pedal linkage.  Also,  I am not sure how to remove the old pilot bearing.
Dave Fullmer
McKenzie, TN
Post Options Post Options   Thanks (0) Thanks(0)   Quote davefullmert Quote  Post ReplyReply Direct Link To This Post Posted: 05 Apr 2016 at 5:59pm
Well,  I just took an other look,  there is no way it could be pressed out so I just took a hammer to it and tapped it off the housing.  It didn't take much tapping and now the old throwout bearing is off the housing.  When the kit comes, it looks like a carefull tapping back on will do it.  I also checked the grease zerk for accepting of grease and that is OK also.
Just a matter of waiting for the parts to put it back together now.
Dave Fullmer
McKenzie, TN
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 05 Apr 2016 at 6:03pm
Rick is the go to guy as far as I'm concerned on clutches and brakes.
grinder220 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote grinder220 Quote  Post ReplyReply Direct Link To This Post Posted: 05 Apr 2016 at 6:14pm
pack grease in the pilot hole, stick a bolt or rod the same size as the hole into it, smack it with a hammer. The grease should push pilot bearing out.
Post Options Post Options   Thanks (0) Thanks(0)   Quote davefullmert Quote  Post ReplyReply Direct Link To This Post Posted: 05 Apr 2016 at 8:55pm
Do I dare use the alignment tool for that?  Or would mess up the tool?
Dave Fullmer
McKenzie, TN
Post Options Post Options   Thanks (0) Thanks(0)   Quote LeonR2013 Quote  Post ReplyReply Direct Link To This Post Posted: 05 Apr 2016 at 9:36pm
Take the end of little womans kitchen broom, cut of what you need. She'll never notice. Leon R  Cmo
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 06 Apr 2016 at 9:40am
I've made a jig to bolt to the back of the engine after installing the clutch. Then I set the fingers to the jig and put the tractor back together. Perfect free play every time.
Post Options Post Options   Thanks (0) Thanks(0)   Quote davefullmert Quote  Post ReplyReply Direct Link To This Post Posted: 06 Apr 2016 at 1:27pm
Wait a minuet, you mean the fingers them self are adjustable?  The only free play that I know of would be on the rod that connects to the foot pedal.
Dave Fullmer
McKenzie, TN
Post Options Post Options   Thanks (0) Thanks(0)   Quote LeonR2013 Quote  Post ReplyReply Direct Link To This Post Posted: 06 Apr 2016 at 7:06pm
Dave, if you have a Rockford clutch here you go. You want three threads to protrude thru. the clutch rod fork. Then check the clearance of the forks and turn the adjusting screw if needed so you get a 1/4" clearance on all of them with a tolerance .010". Measure at the end of the shift forks, and don't forget to tighten the lock nuts. Sounds easy doesn't it? Oh, you did find the inspection plate? Leon R  Cmo
Post Options Post Options   Thanks (0) Thanks(0)   Quote davefullmert Quote  Post ReplyReply Direct Link To This Post Posted: 07 Apr 2016 at 4:45pm
No inspection plate on my CA.  There is a 2 inch dia hole in the bottom of the housing right underneath the grease zerk, but I sure can't find any way to adjust the fingers once the tractor is together again.   I would think the pressure plate would be factory set to be in parallel plane to the flywheel.  Then turn the clutch pedal rod for the right clearance.
Dave Fullmer
McKenzie, TN
This page was generated in 0.260 seconds.
