7080 front 18.4 x 16.1
LB0442 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LB0442 Quote  Post ReplyReply Direct Link To This Post Topic: 7080 front 18.4 x 16.1
    Posted: 24 Mar 2016 at 4:30pm
It has been raining off and on today, not getting much done so I decided to make a trip to the tractor salvage yard.  Picked up a set of firestone 18.4x16.1 front turf tires for my 7080.  They look almost brand new, with wheels for $800 out the door.  I like the looks of the turf tires on the front versus the ribbed units.
JimWenigOH View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JimWenigOH Quote  Post ReplyReply Direct Link To This Post Posted: 24 Mar 2016 at 5:56pm
Price was right, and I think they'll look good too. I was going to put turf tires on my 220, but changed to 4 rib when the Tire Dealer told me the turf would be damaged easier in my no-till corn stalks.
DarrylinWA View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote DarrylinWA Quote  Post ReplyReply Direct Link To This Post Posted: 24 Mar 2016 at 9:44pm
-Nampa Tractor? Good people.
B 10 Custom. Serial # 1001 D21, First D21 built 69 #4498 and Last D 21 Built #4609. 1946 MM UTU. And 2000, 2005 Pete's. AC custom Hauling.
SHAMELESS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SHAMELESS Quote  Post ReplyReply Direct Link To This Post Posted: 24 Mar 2016 at 10:17pm
I took the diamond tread tires and wheels off the back of one of my parts 1440 combines. bolts right on and they look good too! now I guess they'll be for sale unless I put them on my 7010.
Post Options Post Options   Thanks (0) Thanks(0)   Quote LB0442 Quote  Post ReplyReply Direct Link To This Post Posted: 24 Mar 2016 at 10:18pm
Actually Nampa Tractor Salvage has just been sold, I think around 1st of Feb this year.  Went there today and the front has been all cleaned up.  The new people were just as helpful, let me walk around and check out things.  Prices on that seemed reasonable.  A lot of yards won't let you in without an escort(and not the pretty kind of escort).
Post Options Post Options   Thanks (0) Thanks(0)   Quote SHAMELESS Quote  Post ReplyReply Direct Link To This Post Posted: 25 Mar 2016 at 7:19am
gotta have someone to carry the tools and the parts!
LRWSPWI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LRWSPWI Quote  Post ReplyReply Direct Link To This Post Posted: 25 Mar 2016 at 7:49am
Man, like those wheels and tires. I'd like to have some for my 220 also. Where can you find rims that size and what's the width and offset? Sure look nice. Larry 👍
Post Options Post Options   Thanks (0) Thanks(0)   Quote LB0442 Quote  Post ReplyReply Direct Link To This Post Posted: 25 Mar 2016 at 10:18am
The wheels have an ink stamp on them of 7710 (part number?)and they are stamped 16.1x16.  Can't find a manufacture name on them.  I can find a lot of the smaller width for the 11.00x16 but I have never seen, well here anyway, these larger ones.  Figured I would pick them up while they were available.
Calvin Schmidt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 25 Mar 2016 at 10:31am
I have 18.4 x 16.1 turf tires on the front of my 220. Gives it the correct attitude! Rims are from a salvage MF 2745 and are the same as the 7080. Motor wheel supplied a lot of rims back in the day.
Post Options Post Options   Thanks (0) Thanks(0)   Quote LB0442 Quote  Post ReplyReply Direct Link To This Post Posted: 25 Mar 2016 at 1:15pm
Couldn't stand it, had to put them on.  Ran into a slight problem, the center was slightly smaller than the hub, maybe 1/16".  I used the die grinder and enlarged it.  Possibly these are a metric version of the hub.  Could be like Shameless said from a combine or possibly a baler.
The 11.00 just look girly now.
Panels came from the junkyard earlier.  I'm still working on the dash inside.
Ron(AB) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ron(AB) Quote  Post ReplyReply Direct Link To This Post Posted: 25 Mar 2016 at 1:53pm
Any plans for bigger rubber on the rear?
Post Options Post Options   Thanks (0) Thanks(0)   Quote LRWSPWI Quote  Post ReplyReply Direct Link To This Post Posted: 25 Mar 2016 at 2:03pm
Like 30.5s
Dkienzle View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dkienzle Quote  Post ReplyReply Direct Link To This Post Posted: 25 Mar 2016 at 3:06pm
We had a set on our 7080. They ride great and look awesome but don't turn worth a crap in worked ground. 7080 has dualed 20.8s on it with cast centers in all 4 wheels and just wanted to push the front end straight and not turn. They would be awesome in a hay field. BTW your 20 looks mean with um on.
Unit3 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Unit3 Quote  Post ReplyReply Direct Link To This Post Posted: 25 Mar 2016 at 7:13pm
How do they turn on the headlands/endows? Do they tend to slide sideways as you turn the wheel? I would think one would be on the breaks all the time. Still, I like the looks of them.
This page was generated in 0.057 seconds.
