C Rear Main Seal
Jhebel View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jhebel Quote  Post ReplyReply Direct Link To This Post Topic: C Rear Main Seal
    Posted: 20 Mar 2016 at 6:55am
I have a C that I am restoring, and the rear main seal drips a little bit.  This tractor runs OK, and I am tearing the motor apart anyway.  Is it worth taking off the crank shaft to replace the rear main seal, or is it alright if it drips a little bit?
Hubnut View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hubnut Quote  Post ReplyReply Direct Link To This Post Posted: 20 Mar 2016 at 7:13am
The rear main on a C does not require the crank to be pulled.  On the back of the motor, a housing holds the seal (either felt or cork).  I've used both and both seep a bit even new.  If you're pulling the motor, you might as well change the seal.  The seal is soaked overnight in motor oil, slipped into the housing, and then pressed over the rear crank shaft.  Not a hard job at all.   Good luck!
1940 B "Lucy"
1941 B w/ Woods L59 "Flavia"
1942 B w/ finish mower "Dick"
1941 C w/ 3-point "Maggie"
1947 C SFW w/ L306 "Trixie"
1972 314H
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 20 Mar 2016 at 7:28am
As mentioned the original type seal can be replace without dis-assembling the engine. Those type seals are designed to work with the spiral on the back of the crank to pull the oil back into the engine. These seals will almost always have a slight dampness around them, some more than others. I have updated many of the BE/CE engines to use the lip type seal from a D10/12 by installing a Speedi-Sleeve over the grooves and the D10/12 seal housing.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jhebel Quote  Post ReplyReply Direct Link To This Post Posted: 20 Mar 2016 at 10:15am
Is the Steiner gasket kit with the rear main seal in it good to use?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jhebel Quote  Post ReplyReply Direct Link To This Post Posted: 20 Mar 2016 at 7:03pm
I also just remembered another unrelated question that you guys might be able to answer.  The tractor has a device on the front of the radiator that does not seem very common on C's.  It has flaps that can open and close with a crank that sticks out the side of the radiator shroud.  I would assume that this is for wintertime operation because it restricts the airflow through the radiator.  Is this uncommon?
Dick L View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 20 Mar 2016 at 8:01pm
Shutters were very common when those tractors were made.
