201 WD Cylinder Head - short vs tall
ACWD1953 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACWD1953 Quote  Post ReplyReply Direct Link To This Post Topic: 201 WD Cylinder Head - short vs tall
    Posted: 19 Mar 2016 at 11:51am
My 1953 WD has a cracked cylinder head.   Luckily I also have a 1952 WD parts tractor (non-running). The 1952 cylinder head is taller than the 1953.
Can I use the shorter cylinder head? Assuming that I have to use the shorter pushrods and mounting hardware.
Plan B: If I can't switch the heads and I have to rebuild the 1952 (complete engine) will it fit on my 1953 tractor? Transmissions are different.
Thanks for any help,
"Depressed in Michigan"
Tom
1953 AC WD, 1952 AC CA, 1957 Oliver Super 55
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 19 Mar 2016 at 12:48pm
Should bolt right on. Push rods are the same, rocker arm stands are different. The blocks are the same. Either one will bolt to either tractor.
http://www.allischalmers.com/forum/forum_posts.asp?TID=40298&title=wd-head
Edited by CTuckerNWIL - 19 Mar 2016 at 12:49pm
This page was generated in 0.227 seconds.
