What size amp meter on B
skeeters65 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote skeeters65 Quote  Post ReplyReply Direct Link To This Post Topic: What size amp meter on B
    Posted: 19 Mar 2016 at 9:12am
Hey guys I am converting to 12v and want to order a volt meter. What size gauge do I need to order to fit in the stock B location?
Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote skeeters65 Quote  Post ReplyReply Direct Link To This Post Posted: 19 Mar 2016 at 9:46am
Looks like a 2" hole.
Answered my own question
Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 19 Mar 2016 at 2:54pm
And here I was thinking 30-30 amp...  LOL
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 19 Mar 2016 at 3:01pm
man I was thinking wire size...like 18ga... sigh...
Jay
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 20 Mar 2016 at 10:51am
The ammeter current range really depends on the charger. The original generator probably hardly did 20 amps peak, while the smallest alternator will do more like 50 and peg a 30 amp meter hard. The ammeter should have a little greater full scale than the peak current rating of the charging machine. Wire through the ammeter from the main loads, to the battery, and from the charging machine needs at least a similar current rating. 10 gauge copper is decent for 30 amps, but limits the charging current on a 50 amp alternator, and can run hot at 30 amps. 6 or 8 gauge should be used for a 50 amp alternator charging circuit. All the way from the alternator to the battery connect, probably at the starter switch.
Gerald J.
wbecker View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wbecker Quote  Post ReplyReply Direct Link To This Post Posted: 20 Mar 2016 at 11:04am
He wanted to know what size the hole is. He wants to install a volt meter.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 20 Mar 2016 at 12:39pm
A voltmeter is not very useful in my opinion, been there, had a car with a GOOD voltmeter and ammeter and the ammeter told me more than the voltmeter. Most automotive volt meters don't have the resolution or the precision it takes to be informative.
Gerald J.
