Bush Hog Squealers good or bad
C. Burnett View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote C. Burnett Quote  Post ReplyReply Direct Link To This Post Topic: Bush Hog Squealers good or bad
    Posted: 06 May 2010 at 9:02pm
Are these cutters worth the money?
Thad in AR. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Thad in AR. Quote  Post ReplyReply Direct Link To This Post Posted: 06 May 2010 at 9:41pm
I have one and really like the way it cuts but it's falling apart. Not very heavy duty for rough country.
Eldon (WA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eldon (WA) Quote  Post ReplyReply Direct Link To This Post Posted: 06 May 2010 at 11:07pm
I bought a used 7' last year, wasn't really impressed with it.  I'd take a LandPride instead....but my JD MX8 is the killer!
This
or this?
Edited by Eldon (WA) - 06 May 2010 at 11:11pm
ALLIS EXPRESS!
This year:
DonDittmar View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DonDittmar Quote  Post ReplyReply Direct Link To This Post Posted: 07 May 2010 at 5:59am
Have a Razor back, which is a cheaper line built by Bush Hog. Not Impressed. Dads Woods finish mower has just as heavy deck.
1968 D15D,1962 D19D
Scott(SC) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Scott(SC) Quote  Post ReplyReply Direct Link To This Post Posted: 07 May 2010 at 6:24am
I bought a Razorback slightly used, it hadn't even dulled the original blades. It never did dull those blades before the gears rounded off and stopped meshing. I had an Economy brand 5 ft next to it that had lasted pretty good for a cheap one: it's on it's second or third set of blades and the gearboxes looked identical. I was not impressed with the service I got from the Razorback.
Jim Lindemood View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim Lindemood Quote  Post ReplyReply Direct Link To This Post Posted: 07 May 2010 at 7:34am
I have a 5' Squealer that I run behind a 5030 to keep trails open through the back hills. Not real heavy work - it does a great job for me. The 5030 is basically my wife's tractor. She uses it with the squealer along some of our fence rows and around the barn area - Does just fine for her. I have also used it on some of the open areas in the back woods- smaller patches - again not real heavy trash. For what we do with it - paired to the 5030 - it has done a great job for us. Had it 5 yr's now - no problems. Did replace shear bolt after mowing a decent size rock - not hurt the mower at all.
Osage_Orange View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Osage_Orange Quote  Post ReplyReply Direct Link To This Post Posted: 07 May 2010 at 9:02am
It depends! I have two: A Bush Hog Model 307 (7 foot) pull type.....it is a heavy duty (has a slip clutch) machine and I use it for all "real" brush hogging.  Also have a 6 ft 3-pt Squealer.........I use it for trimming up close to trees in the woods.  It does a good job, but I really baby it.......Use grade 2 bolts for shear pins instead of grade 8.  The owner's manual says not to cut sprouts larger than 1" diameter.  If I were only going to have one machine, I would opt for a heavier duty one than the squealer........FWIW..........O_O
Edited by Osage_Orange - 07 May 2010 at 9:04am
R Aiken View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote R Aiken Quote  Post ReplyReply Direct Link To This Post Posted: 07 May 2010 at 10:22am
Most everything is worth the money, just depends on how much money.
I have a Bush Hog like Eldon's second picture. I got it a few years ago for $50 or less at an auction.  It has a slit and a ding on top and a bad U joint. But for some reason it has new blades, stump jumper, shafts, and gears.
Dave A View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave A Quote  Post ReplyReply Direct Link To This Post Posted: 07 May 2010 at 4:52pm
Had a woods D80 work a lot better that the landspride we have at work. Could mowe  at a good clip with my old Case
Play the game for more than you can afford to lose... only then will you learn the game.
Winston Churchill
Hudsonator View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hudsonator Quote  Post ReplyReply Direct Link To This Post Posted: 07 May 2010 at 6:29pm
My squealer is 17 years old.  SQ72 pull type.  For a WD or WC, it was a perfect match.  I have done more with it than it was supposed to do, but the tractor's hp and the slip clutch option I ordered kept both from tearing up.  I've used it to cut down trees dang near 6" through, by slowly backing it up onto the tree trunk and lettin' the chips fly.
When I began pulling it with the JD 5410 and forgetting to keep the slip clutch serviced (It rusted up) - the gearbox grenaded.  $300 for a 65 hp heavy duty gearbox.  I freqently bend the pto shaft tubing, but can't blame that on the machine itself.  It usually gets bent while being backed off into ditches etc.
For the money, I won't complain.  Pay attention to the hp rating of the gearbox, as not all Squealers are the same.  Anything less than a 40 hp gearbox will not last if subjected to more hp than its rating.
There isn't much a WC can't do.
WD's just do it better.
This page was generated in 1.575 seconds.
