Hydraulic fluid
one54dodgetruck View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote one54dodgetruck Quote  Post ReplyReply Direct Link To This Post Topic: Hydraulic fluid
    Posted: 16 Mar 2016 at 11:35am
Do we have any guys that specializes in different oils? Was in the green tractor store picking up parts and was talking with the counter guy about cenex supplying jd hydraulic fluid. He said jd stopped getting it from cenex a while ago. At one of their conventions he said they were told that quick lift was the worst in a jd causing brake and clutch failing. I don't belive this guy, so what's the best hydraulic transmission oil with the best additives for your money?
2 WDs
B
B112
D14
D15 shuttle
180
185
7040
Hd7w
D14
D15
185
7040 pd
Post Options Post Options   Thanks (0) Thanks(0)   Quote one54dodgetruck Quote  Post ReplyReply Direct Link To This Post Posted: 16 Mar 2016 at 11:36am
Ps I've mainly used orilliys premium hydraulic transmission fluid with no problems, but it's been in little tractors.
2 WDs
B
B112
D14
D15 shuttle
180
185
7040
Hd7w
D14
D15
185
7040 pd
CAL(KS) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 16 Mar 2016 at 12:03pm
we have been using Cenex quicklift HTB since 1992, dont know prior to that.
   ZERO clutch, brake, hydraulic issues
3020 JD was main  feed tractor from 1992 until replaced in 2008 with Rt100.  We do run Agco fluid in RT100 with CVT but everything else is HTB
Edited by CAL(KS) - 16 Mar 2016 at 12:06pm
NEVER green View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote NEVER green Quote  Post ReplyReply Direct Link To This Post Posted: 16 Mar 2016 at 1:08pm
    Says on side of pail,Cenex HTB has twice the gear load carrying ability, and four times the copper protection of OEM oil.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 16 Mar 2016 at 9:54pm
If JD don't use it any more, i'm sure it is not any good now. lol         MACK
michaelwis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote michaelwis Quote  Post ReplyReply Direct Link To This Post Posted: 16 Mar 2016 at 11:07pm
Used HTB for as long as I can remember..
What was your question.?
Lol
Just drained systems of four tractors went through quite a lot
WD WD45 DIESEL D 14 D-15 SERIES 2 190XT TERRA TIGER ac allcrop 60   GLEANER F 6060 7040.and attachments for all Proud to be an active farmer
Post Options Post Options   Thanks (0) Thanks(0)   Quote one54dodgetruck Quote  Post ReplyReply Direct Link To This Post Posted: 17 Mar 2016 at 12:00am
Cool. Just wanted to make sure no one else is having issues with quick lift besides mother deere. I'm working on a 4240 jd with the pto slipping, and just got done with a 4020 powershift that I had the clutches out and put quick lift in.
2 WDs
B
B112
D14
D15 shuttle
180
185
7040
Hd7w
D14
D15
185
7040 pd
HD6GTOM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HD6GTOM Quote  Post ReplyReply Direct Link To This Post Posted: 17 Mar 2016 at 12:10pm
The guy is probably feeding you *^&*%. Those oils are made to JD's specks. So if there was a problem it would have been with JD specks. Quality control is next to none. I've been in the blending plant years ago.. You could have eaten off the floor anywhere in the building.
