MS Carb Question
Dave(inMA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave(inMA) Quote  Post ReplyReply Direct Link To This Post Topic: MS Carb Question
    Posted: 06 May 2010 at 5:57pm
I noticed when we rehabbed the carb (TSX 464) on the WD45 that there was no clip connecting the float valve to the float. Also that the float could drop down far more than I am used to seeing on other MS carbs. Is it possible that the wrong float is in this carb? I'm asking because the carb starting leaking gas today after I ran the tank dry - am wondering if the float dropped down low enough that the float valve may have fallen out of its seat...... haven't pulled the carb off to check this out yet - but this seems possible to me. If not that, then perhaps rust or dirt got past the sed bowl. Thanks!
WC, CA, D14, WD45
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave(inMA) Quote  Post ReplyReply Direct Link To This Post Posted: 07 May 2010 at 5:36am
Anyone got an opinion on this crazy-sounding idea?
WC, CA, D14, WD45
Rick View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rick Quote  Post ReplyReply Direct Link To This Post Posted: 07 May 2010 at 5:54am
Dave...I bet our ol' buddy Steve Barbato can answer that question! Might send him an email...(SteveNJ).   Rick
JoeO(CMO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeO(CMO) Quote  Post ReplyReply Direct Link To This Post Posted: 07 May 2010 at 5:55am
I don't think the float could drop far enough to let the needle slip out, most likely a piece of rust or other foreign material is stuck at the needle/seat area.
 The clip is there to keep the needle from sticking in the seat,  weight of float pulls the needle down.
Edited by JoeO(CMO) - 07 May 2010 at 7:53am
Wil M (NEIA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Wil M (NEIA) Quote  Post ReplyReply Direct Link To This Post Posted: 07 May 2010 at 6:28am
May not have the float adjusted right so that when the bowl fills up that it puts enough pressure on the needle valve to shut the fuel off. As far as the little clip, most of the old carbs that haven't been touched in a long time don't have that clip.
Edited by Wil M (NEIA) - 07 May 2010 at 6:30am
"Yet there are soulless men whose hand and brain tear down what time will never give again." Anderson M Scruggs
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave(inMA) Quote  Post ReplyReply Direct Link To This Post Posted: 07 May 2010 at 6:55am
Thanks for the input!
The carb worked fine Wednesday and Thursday until I added gas late in the day. I did notice when we rebuilt the carb that the float is able to drop down quite low - about a 70* angle with the top half of the carb - seemed a lot compared to others.
I'll be checking into this today or tomorrow - will let you know what I find.
Edited by Dave(inMA) - 07 May 2010 at 7:35am
WC, CA, D14, WD45
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 07 May 2010 at 7:21am
If you ran the tank dry and the carb bowl went empty, it might have let the float drop down far enough to hang up. I have seen it happen if the float drop is excessive.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave(inMA) Quote  Post ReplyReply Direct Link To This Post Posted: 07 May 2010 at 7:37am
CTucker, that might have happened as float drop is a LOT in this carb. Floats I've seen before are designed so that they will only drop to about parallel with the carb top half - this one drops a lot further.
WC, CA, D14, WD45
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 07 May 2010 at 7:46am
I would normally set the float to be close the inlet when it is parallel with the top half. There should be a way to set the drop too.
Edited by CTuckerNWIL - 07 May 2010 at 7:47am
Dick L View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 07 May 2010 at 7:55am
Should be a tab that catches close to the pin to stop the float from going way down. Running the tank out of gas can cause some fine particals to wash out of the tank when filling which can lodge in the seat to hold the needle off the seat. It does not take much to let it leak by the needle. If the needle fell out it would empty the tank in a short time.
This page was generated in 0.270 seconds.
