E/I Questions
 Rating: Topic Rating: 1 Votes, Average 4.00  Topic Search Topic Search  Topic Options Topic Options
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Topic: E/I Questions
    Posted: 23 Jan 2016 at 9:08am
I guess this is aimed mainly at Steve in NJ, but the rest of you can chime in on this.
I am thinking on installing the Petronix on my tractors because of the cheap junk out there, the points, condensor, rotor and caps.  Even the last set I got at NAPA was junk.  Lasted 2 months and on side of the points FELL OFF...
What are the problems with frying these systems?  I've heard the horror stories of jumping and putting chargers on them.  What is the truth on all of this?  If any of you DO jump yours, HOW do you hook up the cables, e.g. in what order do you hook up the leads?
Thanks ahead of time guys!
wbecker View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wbecker Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jan 2016 at 9:22am
The electronic ignition has no problems that I have found.
For the last 20 years or so if I think one of my tractors needs point adjustment, I remove the points and through them away, and install Pertronix. I don't think I have anything left with points in it. Pertronix is easier to install than points and after that you never need to do anything, no adjustments, no timing adjustments. I have never had any problem with charging or jumping, don't know how people come up with these problems.
Just Call Steve, order it, and don't worry.
Bill B
johnkc View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote johnkc Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jan 2016 at 9:34am
I have a hyster with a continental that I converted probably 20 years ago. It's been jumped and charged with no attention paid to the ignition system and she has never had an issue. And she sits outside 100% of the time, that reminds me, I should start her up and run her today.
I support the development of hybrid automobiles and alternative fuels as I need DIESEL fuel for my ALLIS CHALMERS!
dirtfarmer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dirtfarmer Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jan 2016 at 10:46am
I would say go for it.  Converted my D17 recently and it's the best money I've spent on it to date.  Had to advance the timing a bit and replace some fouled plugs (from running with bad points for so long).  After all that, it runs like a top.
The only thing that Pertronix warns about is leaving the ignition on and not running.  It can cause your new ignition to overheat.
Using jumper cables shouldn't hurt anything.
shane w masters View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote shane w masters Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jan 2016 at 3:57pm
put it into my D17 and WD45 after fighting it all last summer. Even had the dealer out 5 times at 150.00 a hour from the time they leave the shop to they get back. put EI in this fall after the dealer and surrounding dealers told me too. JD and caseih dealers in the area don't mess with points and condensers at all anymore. They put EI in and forget about it.
My sit out side under tarp and have never had an issue yet. the run better now than they have in the last couple of years.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jan 2016 at 4:11pm
There is only one way to hook up cables to jump any vehicle. Connect all the cables except the ground cable to the dead vehicle, then connect the last cable to the dead vehicle Ground, ANYWHERE but near the battery.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jan 2016 at 4:31pm
Charlie, that is the way I also have always done it.  Started working in my Uncle's Shell station when I was about 12.  He showed me the RIGHT way to do a lot of things.  Gave me a real lesson on my first ever Power-Glide transmission.
I guess I'll make the plunge and change over on at least two of my tractors this spring.  My worker (WD45) and my mower (C).  I honestly don't know what I would do without either one of them!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jan 2016 at 10:43pm
I've had a Pertronix in my CA for nearly 20 years now. It's been jump started, charged and still works. The directions say they are very sensitive to having a coil with the proper primary circuit resistance. I recommend you buy the matching Flamethrower coil to go with it. That way you know you have a compatible coil that won't burn the module out. With electronic ignition comes higher secondary potential. You can take advantage of that by opening the plug gaps up. I run my CA at .045 now. It never fouls the plugs anymore and has never started so well.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jan 2016 at 7:17am
Now that is interesting Brian!  I've never seen that in all the threads I've read on this issue.  THANKS!!
DonBC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DonBC Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jan 2016 at 1:26pm
The E.I. allows you to use a coil with a higher output for a hotter spark. Initially I just installed the E.I. and used my old coil but I found that the coil would get hot and the engine would start to misfire. At first I thought it was a fuel problem until I happened to put my hand on the coil. A new coil solved the problem and I can run with a wider gap on the plugs. Install the E.I. and coil, set the timing and never look at your distributor again except to remove the little plug on the side and lube the distributor shaft now and then.
TREVMAN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TREVMAN Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jan 2016 at 2:26pm
Lets put this one to bed...There is no magic here, no smoke and mirrors...Ive converted 11 engines with pertronix, best upgrade you can do. Points systems work, there is no argument. Points systems are a switch, they begin to "fail" as soon as they are used because of moving and consumable parts. Points only last so long and because of wear, need adjustment. A pertronix system is simply a Hall Effect box, a magnet, that builds a field and then delivers a spark then the field deteriorates and then the process starts over as things go round and round. No "transistors" or moving parts. No wear, no reason for failure except operator error(installation error). If you drive a car or truck, or have a lawn mower, rototiller, or any other gas engine built since about 1975, you are using a Hall Effect ignition system. How many have you had quit? Me, none. In fact, I'd make my own out of junkyard ignitions but its not worth it when Pertronix has done the R and D to have a unit that is installed in 10 minutes or less in many, many dizzys for usually around $100 bucks. Find a 3 ohm resistance coil(aka 12 volt coil) or buy the whole outfit from Steve the Jersey man and youre rockin. I spent 3 weeks in a coma 22 months ago after open heart surgery that was iffy, but SOME THINGS STILL MAKE SENSE, Trev.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jan 2016 at 3:34pm
Trevman!!  Great to hear from you!  Haven't seen you on here for a while.....
I remember all the troubles you were going through at the time and I've had you in my prayers ever since.
Hope you are close to 100% now!!  Have a good day Buddy!!
AC puller View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC puller Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jan 2016 at 4:06pm
Anyone have steves #?
Post Options Post Options   Thanks (0) Thanks(0)   Quote wbecker Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jan 2016 at 4:48pm
Top of the first page on this site, on the top right, "Parts etc", then look for B&B Custom Circuits.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jan 2016 at 4:56pm
The Pertronix E.I. was designed to work with the stock coil. As Brian mentioned, the Blaster coil that Pertronix offers is optional, but it does give you top performance and more "fire in the hole". The wider gap adds to that advantage which gives a much better explosion in each cylinder which of coarse leads to better combustion. Some coils that have been in service for a looong time can get hot because of the secondary starting to drop out, or its just plain tuckered out period! I don't push new coils or the optional Blaster coil. I leave that totally up to the customer when he or she purchases a E.I. kit.  I don't know what their budget is. If they ask me about a coil, I then tell them the benefits. Still up to them whether or not to make the extra purchase.
Now, for the jump starting thing. Tuck is right on with cable location. Here's the skinny on the E.I. and jump starting. Lots of times we're in a hurry, and we jump on our Tractors and we get that 'Rump" sound of a dead Battery. We jump off the Tractor and go for the jump box, Battery charger or cables. Whatever. The thing we forgot to do is TURN THE IGNITION KEY OFF. We jump the Tractor is BLAM! That spike of amperage goes through the key switch and drills that module! Internal melt down so to speak to the module. Now we go to turn the key on and YIKES! The key was already on. So we crank it anyways to try to start it, and it cranks great now, but doesn't fire. DRAT!!  Left the key on! That's why I always say, even if you're just gonna charge the Battery up because it sat for a long time, if your Tractor is equipped with an E.I. disconnect one of the Battery cables just for safety sake. You don't want to throw that money out the window that you spent on that E.I.  Be careful on what you do, and  you to will get mega years out of your E.I.   And that's the skinny on dat'.....
Steve@B&B
bb-customcircuits.com
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jan 2016 at 6:37pm
Thanks Steve!!  I'll be calling you this spring when I need to start one of my tractors!  They all start good enough now, but the D-17 is getting finicky and I've never changed the points or nothing in my 41 C.  I know that I need to find the number on the distributor, but I think I looked on the C one time and there was nothing there.  What should I do?  Thanks, Ted
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jan 2016 at 9:52pm
For the early machines, I just need to know if its 6VPG, 12VPG, or 12VNG. For the D17-on up, I'll need the Distributor number.
