190xt air cleaner above hood vs below
Allisray View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allisray Quote  Post ReplyReply Direct Link To This Post Topic: 190xt air cleaner above hood vs below
    Posted: 21 Jan 2016 at 11:22am
Hello,
Is there a reason why some air cleaners come out above the hood while others dont? I am restoring my 190xt gas and it has the air cleaner below the hood but I like the looks of it above the hood.
Thanks everyone, allisray
Richmar View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Richmar Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jan 2016 at 11:55am
Allisray:
THe air cleaner extension above the hood was an option:  If you get one, make sure the reinforcement ring is installed under hood.  If not they can damage the hood.
richmar
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jan 2016 at 12:35pm
The optional above the hood pre-cleaner was much more popular on diesel models than gassers.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allisray Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jan 2016 at 12:40pm
Thank you guys, I was wondering if gassers even had that option
Post Options Post Options   Thanks (0) Thanks(0)   Quote TimNearFortWorth Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jan 2016 at 4:01pm
Well above the hood was to reduce the dust picked up. If you install an above the hood unit, look at most 190 pics and they look to be cocked as they are not always straight up. You can rotate it either way on the mounting flange bolts through the hood and get it straighter.
