Magneto Kill button Issue
Steve Wilkens View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve Wilkens Quote  Post ReplyReply Direct Link To This Post Topic: Magneto Kill button Issue
    Posted: 19 Jan 2016 at 4:21pm
Have the WD up and running, but the kill button doesn't kill the engine. Before I take the mag apart, what exactly does the kill button short out? Where does the intern wiring from the kill button connect? Thanks, Steve
DougS View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote DougS Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jan 2016 at 4:38pm
Are you trying to kill it with the tab at the mag or with a switch at the console?
Post Options Post Options   Thanks (1) Thanks(1)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jan 2016 at 5:04pm
Steve,
If you're referring to the Mag kill lever on the side of the Mag, there's an insulated wire that runs up and connects to the points where the condenser connects. When you push the lever down and ground it to the Mag's housing, it grounds the points and shuts the engine down.
Now, if you're referring to a remote Mag kill switch, there were two. One was a self grounding switch with had one screw terminal on the bottom of the switch that connected to the Mag's grounding stud out the side where the lever is. The other switch used was a two terminal switch, which one side was grounded in the instrument box, and the other attached to the Mag's outside stud/lever. Pull the know out for either switch and it grounds the points shutting the engine down. If you're pushing the lever and its not shutting the engine off, the insulated wire inside that runs to the points may not be hooked up, OR it ain't in there to start off with. Or, may not be a good ground to the Mag housing to shut it down.... HTH
Steve@B&B
Post Options Post Options   Thanks (1) Thanks(1)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jan 2016 at 5:17pm
The wire from the normally open kill switch hooks here. The switch has to be grounded properly to ground this wire when it is closed.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve Wilkens Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jan 2016 at 5:26pm
Thanks guys, you all are the best, and Steve-o you gave me exactly what I was looking for, just where the internal wire connects...to the points same spot as condenser. Got it! Saved my life buddy, Steve
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jan 2016 at 12:10pm
Glad to help man!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve Wilkens Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jan 2016 at 3:27pm
Opened the mag up and the insulated wire was MIA, so just had to install one and she work like a champ. Thank again for the help.
