AC 180 Hydraulic PTO question
shackratt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote shackratt Quote  Post ReplyReply Direct Link To This Post Topic: AC 180 Hydraulic PTO question
    Posted: 12 Jan 2016 at 5:35am
Hello guys I am new to the Forum and I have read previous post about the PTO problems. In fact the tractor in question is one from a post on here. So here goes.  the PTO shaft can be spun by hand even when engaged and I have checked the shifting lever behind the battery box. Here's the tricky part. With the power driector lever in neutral position when you engage the PTO it will kick it out automatically. with it in HIGH or LOW it stays engaged but does not work. It looks like the tractor has been split apart and my best guess is that the coupler has fallen or was not installed. Would this cause it to kick the PTO lever out when power director is in neutral?
thanks Sam
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jan 2016 at 7:17am
Sounds like there is two problems. Behind battery box there should be a lever with no linkage to it. Move that lever should engauge the couppler, it will move hard.
 Next the pressure may have been set up too heigh that it kicks the lever out. MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote shackratt Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jan 2016 at 7:42am
Thanks for the reply Mack  I have rotated the lever in both directions without success. even while turning the PTO shaft while moving lever. As for the pressure I will check that when I get home in about 3 weeks. I am new to owning an allis but have used them a lot. Like I said before this is a tractor I bought from a member of this forum only a couple days before I had to head to work.  thanks for the advice.  Sam
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jan 2016 at 7:48am
Rotate that lever counter-clockwise while someone else is turning the PTO shaft at the rear of the tractor. If nothing happens, the coupler must not be inside the torque housing. If someone removed the PTO clutch box from the tractor without having this lever engaged, the coupler would have fallen out of place and is laying inside the housing doing nothing.
8070 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8070 Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jan 2016 at 8:08am
Is this a hyd PTO or just the use PTO if hyd and u put the PD in highor low and it does not wwork. And it jump out when PD in neutral that tell me the cupler in there. Sound like u have a bad PTO box or PD it not get oil to work in high and low but when in the other spot it go in but kick it out because the oil bye passing . If u need more info pm . Me
Post Options Post Options   Thanks (0) Thanks(0)   Quote shackratt Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jan 2016 at 6:09am
Thanks guys for all the advice. I will check when I get home. Also i forgot to mention that the PD slips in low range as well and from what i know and hear from other post, its all related. thanks again. I will update you guys when i find out what the problem is.
Post Options Post Options   Thanks (0) Thanks(0)   Quote shackratt Quote  Post ReplyReply Direct Link To This Post Posted: 06 Feb 2016 at 5:50pm
Ok guys I got home the other day and today I got the 180 out and double checked the lever behind the box. No matter which direction i put it in it can free spin by hand with the tractor running and PTO engaged.
Should that be easy to turn when engaged? I would think not. so I am guessing the coupler is not installed or has fallen into the PD compartment.
Still have the slipping problem In low range though. I will tear into it as soon as I build the Shop this week.
Sam
AC 180, TO-20, Case 580B Case 450 dozer
Post Options Post Options   Thanks (0) Thanks(0)   Quote shackratt Quote  Post ReplyReply Direct Link To This Post Posted: 08 Feb 2016 at 2:05pm
ok guys doing some more checking on the 180 I have a couple questions.
1) Why does the PTO lever Engage when you put the PD in neutral?
2) Why would low range on PD slip?
3) If the PTO coupler has fallen into the PD compartment. Is there a way to reinstall it without splitting the tractor?
Sam
Dan73 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dan73 Quote  Post ReplyReply Direct Link To This Post Posted: 08 Feb 2016 at 4:08pm
Have you tried contacting the last owner? Most of the guys in here would tell you what they did if they split the tractor.   I know if I sold something I would try to help the next guy figure out what was wrong.   You could always private message the guy in here so he isn't put on the spot just thinking out loud. Best of luck sorting it out I don't the tractor in question so I can offer any advice.
Post Options Post Options   Thanks (0) Thanks(0)   Quote shackratt Quote  Post ReplyReply Direct Link To This Post Posted: 08 Feb 2016 at 4:32pm
Dan73
When I bought it we talked and he is the one that pointed it out that the tractor might have been split. I don't think he owned it very long as he was asking on here how to repair it. Its fine. I am really curious about the PTO engaging when I put the PD in neutral. That puzzles me.  if anyone could enlighten me on that it would be appreciated. As soon as I get the shop built I will pull it in and see what can be done even if I have to split it. Thanks Sam
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 08 Feb 2016 at 4:43pm
You need to get a 600 psi pressure gauge (or two gauges) connected to the manifold down where the brake latch pawl is located. If your pressure is too high, from a stuck regulator spool (common problem) the excess pressure can force the PTO lever out of detent because the detent spring/ball/roller isn't strong enough to overcome the excess hydraulic pressure. Just get a gauge and verify pressures less than 300 psi at full throttle LOW-NEUTRAL-HIGH on the Power Director lever.
Post Options Post Options   Thanks (0) Thanks(0)   Quote shackratt Quote  Post ReplyReply Direct Link To This Post Posted: 08 Feb 2016 at 4:50pm
thank you DrAllis  I will grab some gauges and hoses in the morning and test the pressures. I still have to figure out how to reinstall the Coupling for the PTO shaft. Is it possible to do it without splitting the tractor?
sam
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 08 Feb 2016 at 5:10pm
Yes, with small hands and a helper. Requires PTO box removal.
Post Options Post Options   Thanks (0) Thanks(0)   Quote shackratt Quote  Post ReplyReply Direct Link To This Post Posted: 08 Feb 2016 at 5:33pm
thank you sir
