Best wagon roll-tarp kit
AC7060IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC7060IL Quote  Post ReplyReply Direct Link To This Post Topic: Best wagon roll-tarp kit
    Posted: 11 Jan 2016 at 11:15am
I have several 300 bushel gravity wagons consisting of DMI, EZ-flow, & parker types. Anyone on this forum recommend a good bolt-on roll tarp kit for these?
Unit3 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Unit3 Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jan 2016 at 11:31am
There is only one. I do not know the name of it off hand, but I can get it for you. It uses a spool and cable on each end, so as the tarp opens the cable is unwound. As the tarp is closed, the cable winds up. It uses a hydraulic hose instead of a knuckle or U joint between the tarp spool and crank handle shaft. You will love this when tarpping loads hooked together. When the tarp is open, have it rolled up on the left side of the wagon should you wish to unload on the go. They will NOT blow around on windy days. We have 3 of them and love them. I'll bet YouTube has them.
KY poorboy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KY poorboy Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jan 2016 at 2:13pm
Unit 3, you are exactly right. Only way to go. I have 4 of them, but I am drawing a blank on the name also. Old age hitting I guess.
Bill_MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill_MN Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jan 2016 at 2:18pm
Shur-co Shur-Lok, they make remote control electric ones too
Edited by Bill_MN - 11 Jan 2016 at 2:21pm
victoryallis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote victoryallis Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jan 2016 at 3:05pm
I like Shur co for our trucks we have something different on our cart and hate it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote KY poorboy Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jan 2016 at 3:41pm
Ok, I had to go look on the grain cart. E-Z LOCK is what these 4 are. By Agri Covers Inc.
We have several Shur - Loc and some Shur - Co tarps on our hoppers and dump trailer. But this style seems to work better for us on the cart and wagon. We still have one 2 ton also, and it has a Shur- Loc too.
That's bad that I had to go look, LOL!
wayneIA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wayneIA Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jan 2016 at 9:45pm
I think about any tarp maker has the cable style your talking about, I put a Syntex on a 400 bushel wagon, but it was the regular style with the u-joint and no cable.  Then when the tarp is cranked shut, you use the crank as a lever to tension the tarp.  They make tarp savers too for this style of tarp that prevents the wind from lifting it (usually not a problem until you get onto longer tarps).  For me the Syntex was cheaper than the Shurco, and since it was in Iowa, it was cheaper to ship also.  I have no complaints about the Syntex tarp that I bought, when you contact a company, they'll want to know the width, length, and if the lip goes out or in on the top of the wagon.
http://www.syntexindustries.com/product/Ag_Tarp.php  is the ag tarp that Syntex makes with the cable
http://www.syntexindustries.com/product/Wagon_Roll_Tarps.php  is the wagon tarp that is like a regular semi tarp
http://www.shurco.com/agriculture/products/gravity-wagons/cable-lok-gravity-wagons is the Shurco cable lock tarp system
http://www.shurco.com/agriculture/products/gravity-wagons/shur-lok-jr-for-gravity-wagons  is a cheaper style Shurco wagon tarp
http://www.shurco.com/agriculture/products/gravity-wagons/super-duty-shur-lok-for-gravity-wagons  is the better grade semi style tarp
SHAMELESS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SHAMELESS Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jan 2016 at 11:17pm
there is also a factory made metal cover that is cable run from the ground, have seen several on wagons at sales, but don't remember the name. they do seal tight!
This page was generated in 0.805 seconds.
