AC 1300 field cultivator
midwestmac View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote midwestmac Quote  Post ReplyReply Direct Link To This Post Topic: AC 1300 field cultivator
    Posted: 10 Jan 2016 at 12:16pm
There is a AC 1300 field cultivator coming up on a sale. I don't know anything about them. Any info would be appreciated. Do they do a good job? What wears out? I'm looking for one for my D-21. I don't want to put duals on it. This is a 23'   I thought it would be about the right size.
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jan 2016 at 12:42pm
It's not a heavy duty FC but it makes a great finishing tool with a mulcher mounted on the back. I have an 18-1/2' 1200 and it's about perfect for the 190XT with no duals. I'm sure the 190 would pull a slightly bigger one but this way I know we're not mistreating the old girl. The only thing we've ever had go wrong was twice, when putting it all the way in as deep as it would go, we've bent a couple of shanks when they hooked a rock just right. In hindsight, there's no reason to sink it all the way in since we chisel or plow the ground in the fall anyhow. The rubber mounted shanks really are great and never wears out the rubber. We've been using ours since the mid 1980's and other than shovels and those two shanks and an occasional hydraulic hose, that's all we've ever done to it. Oh, I did rip one of the cylinder mounts off it the very first time I hooked it up to a 7000 series. I learned to turn the flow down to the remotes after that. It's unbelievable the hydraulics of a 7000 series when you were used to an old 190.
Edited by Lonn - 10 Jan 2016 at 12:43pm
Wink
I am a Russian Bot
Post Options Post Options   Thanks (0) Thanks(0)   Quote midwestmac Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jan 2016 at 1:26pm
I bought a D-17 Series 111 on a sale 4 years ago. there was one on the sale and now that you mention it I remember those rubber bushings. The AC guys talked favorably about it. I will only be running 4 to 5" deep. I just want to go out and enjoy a day or 2 of spring field work but I will be on one of my customers ground so has to do a good job.
Thanks for the reply
Eldon (WA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eldon (WA) Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jan 2016 at 2:25pm
I watched one sell this fall on auction for around $1500.....way higher than I thought it would go since this isn't really Allis country....
ALLIS EXPRESS!
This year:
Calvin Schmidt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jan 2016 at 2:31pm
I bought a 24.5' 1300 new in 1977 and pulled it with my D-21 ll with duals back then. This spring it will go to the field for the 40th consecutive year. In the past there were years that it cultivated more than 1000 ac in a year. All original rubber mounts and shanks except for 3 that got bent on rocks. I use it now as a finishing cultivator with a double rolling crumbler and buster levelling bar mounted on the back. Trussed the frame a little to take the extra weight on the rear. MOST IMPORTANT thing to do is to lift it when your turn. Not a lot of clearance. Finally found a 1400 the same width for the first pass.
Will hook a D-21 to the 1300 and a 220 to the 1400 this spring.
farmersam5488 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote farmersam5488 Quote  Post ReplyReply Direct Link To This Post Posted: 20 Apr 2017 at 1:35pm
Calvin Schmidt, how did your 220 handle the 24.5' 1400?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 20 Apr 2017 at 2:10pm
D-21 with duals would work.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 20 Apr 2017 at 2:43pm
My 220 handles the 1400 In 5th gear with no problem. I may have to qualify my answer a little. My 220 has 20.8 x 38 radial duals with 3000 lbs of inside weights and Mexican hat duals. It weighs 17,300 lbs. It also has an industrial intercooled engine that dynos 190 hp without touching the injector pump.
Edited by Calvin Schmidt - 20 Apr 2017 at 3:42pm
JoeO(CMO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeO(CMO) Quote  Post ReplyReply Direct Link To This Post Posted: 20 Apr 2017 at 2:59pm
Originally posted by Calvin Schmidt Calvin Schmidt wrote:
My 220 handles the 1400 In 5 gear with no problem. I may have to qualify my answer a little. My 220 has 20.8 x 38 radial duals with 3000 lbs of inside weights and Mexican hat duals. I weighs 17,300 lbs. It also has an industrial intercooled engine that dynos 190 hp without touching the injector pump.
I love this monsterous machine!
Edited by JoeO(CMO) - 20 Apr 2017 at 4:16pm
McAllis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote McAllis Quote  Post ReplyReply Direct Link To This Post Posted: 20 Apr 2017 at 4:47pm
Pulled a 24.5' with my 8030. No problem.
Plowking77 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Plowking77 Quote  Post ReplyReply Direct Link To This Post Posted: 20 Apr 2017 at 7:17pm
We pulled a 33' with r 7580 for years and a 24' with r 7030 for years,, no problems except for breaking a couple shanks over the 20 plus years we used them. They were a really popular field cultivator in r area just about everybody had an A-C cultivator even the green and red guys. We still have the 33ft- I believe it's a 1350,, it hasn't left the building for quite a few years. We bought a new Klonskilde about 10 years ago,, handles the residue a little better
HD6GTOM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HD6GTOM Quote  Post ReplyReply Direct Link To This Post Posted: 20 Apr 2017 at 10:53pm
There were a lot sold in the 1970-1980's, as stated even the guys with red, green, and blue had an orange field cultivator. Very good product for their time.
Tbone95 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 21 Apr 2017 at 6:22am
calvin Schmidt, 3000 pounds of inside weights? Wow, what did you use and where did you put all of it....must be some hellacious bolts and stuff. Pic?
Dans 7080 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dans 7080 Quote  Post ReplyReply Direct Link To This Post Posted: 21 Apr 2017 at 6:49am
3 500lb per wheel. I know of a lot of 7000 series with 3 per side.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 21 Apr 2017 at 12:47pm
I bought a set of weights that had all been on a D-21 (hard to believe) 2- 1500 lbs inside weights and 2- 1100 lbs outside weights. The 220 has the 1500# inside weights. I was getting it ready to pull a deep ripper but then bought another tractor with MFD.
This page was generated in 0.184 seconds.
