Powershift Oil? In 7010 what kind do you use
Anthony View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Anthony Quote  Post ReplyReply Direct Link To This Post Topic: Powershift Oil? In 7010 what kind do you use
    Posted: 02 Jan 2016 at 6:15pm
Got the hydro leak fixed on the 7010 and drained the powershift fluid. The 7010 manual says to use Allis Chalmers powershift oil, is this just hydraulic fluid? If its not regular hydro fluid what do I need to use for the powershift?
REEDE View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote REEDE Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jan 2016 at 7:35pm
Use ALLIS  821 hyd. oil or the equivalent.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Anthony Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jan 2016 at 8:25pm
Ok, is that the same are regular hydro fluid?
ILGLEANER View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ILGLEANER Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jan 2016 at 10:19pm
Same oil as the hydraulics Anthony.
      IG
Post Options Post Options   Thanks (0) Thanks(0)   Quote Anthony Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jan 2016 at 10:20pm
Thanks a bunch IG
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jan 2016 at 11:02am
If you go aftermarket as in farm stores id stay away from TSC 303 universal hyd oil, seems very thin and a 180 didn't like it, if its a powershift id use some good stuff
Edited by DougG - 03 Jan 2016 at 11:03am
tomNE View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tomNE Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jan 2016 at 7:13pm
  I use the 303 in both my PS and PD tractors.   its better then anything that was made when those tractors were new.
skipwelte View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote skipwelte Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jan 2016 at 9:08pm
There are only two tyes of oil used in the 7000 series,  eng oil in the eng and trans/hyd oil in the trans and rear end.  the AGCO branded oil is called 821XL, most farm stores have their own branded oil-it should say on the label is it is compatable with 821XL.
Ben (MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ben (MI) Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jan 2016 at 6:10am
While not cheap I use JD Hy-Gard as the 821 equivalent since I won't deal with the local AGCO people and don't question the quality like I do the store brands.
Part time farming with a 1980 7060 and 1984 F3 hydro.
screwloose View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote screwloose Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jan 2016 at 10:45am
I'm pretty sure that any hydraulic oil bucket has a list of meets of exceeds for most equipment brands type of oil. If the bucket says in the list that it meets or exceeds allis chalmers 821 your good to go. It doesn't matter what color the bucket is or where you buy it.
GM Guy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GM Guy Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jan 2016 at 12:26am
most farm stores sell two or three grades of trans/hyd. oil.
Our local one's low grade said it met 821, but apparently a few tests and a threat of a lawsuit (I assume) later, they now have a flyer that says to only use the cheap stuff in stuff with low pressure hyd. systems.
We personally use the better stuff at the farm and home store.
I think on a powershift, I would go for the warm fuzzy feeling and go genuine Agco for it just to be cautious. lots of spendy parts in there to risk it.
Gleaner: the properly engineered and built combine.
If you need parts for your Gleaner, we are parting out A's through L2's, so we may be able to help.
Ky.Allis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ky.Allis Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jan 2016 at 4:36pm
I'm confused I have been using "Xtreme" hyd. oil (from TSC) for several years in my 200 with no issues. It plainly states on the label it meets specs. of AGCO PF821 oil. A while back an employee at TSC told me "Xtreme" was no longer available so while there I bought some called "super trac"? which says on the jug it is 303 hydraulic oil and is for use in alot of listed brands including Allis Chalmers. However it does NOT specifically say it meets specs. of AGCO PF821 fluid. I have not opened it. It was cheap. Should I use it or not?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jan 2016 at 4:51pm
That's what I put in my 180 and it seemed to thin , I wouldn't!
Edited by DougG - 07 Jan 2016 at 5:09pm
HD6GTOM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HD6GTOM Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jan 2016 at 5:09pm
I get mine from the local farm Coop, it is designed for farm tractors not lawn mowers
Orangie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orangie Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jan 2016 at 4:29am
Ky Allis, If memory serves me right 303 was the Dexron Type A Hyd oil. I don't think you should use that till you know for sure. 821 is what your 7010 needs.
7010, 7060, Two 8070's, Two R65's, 616H, and a few blue ones.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TimNearFortWorth Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jan 2016 at 8:45am
If TSC, they should also have Traveller brand on the shelf. Denotes 821 approved and I have used it for years in D-Series lineup without issues.
Traveller runs about 9-10.00 more for the 5 gallon bucket in my area vs. 303. I have never run 303 . . .
