carburetor wont stop leaking
Redneck06 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Redneck06 Quote  Post ReplyReply Direct Link To This Post Topic: carburetor wont stop leaking
    Posted: 31 Dec 2015 at 9:17pm
Hello all,
first post here. I am posting for a friend. He has a john deere as well as a D17. I have rebuilt both carbs for him with out a problem. but now the john deere carb tsx-810 will not stop leaking. it fills up the air intake pipe and drips on the ground. I am so confused. I know the float is working and does not have any holes and I put a new needle and seat in the carb. about 5 min after turning on the gas it starts dripping out of the carburetor. is there anything else that could cause this problem beside the needle not seating in the seat and cutting the flow of gas out? thanks. I know this is not a john deere forum but this is the first one I have been able to register and post on.
thanks for the help
marc
Brian G. NY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian G.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 31 Dec 2015 at 9:28pm
Seems to me its got to be the float, the needle and seat, the float setting OR......the float is sprung and binding on the side of the carburetor bowl.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Redneck06 Quote  Post ReplyReply Direct Link To This Post Posted: 31 Dec 2015 at 9:34pm
Well I know the float does not have holes in it so it must be binding up.
Thanks
DaveSB View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveSB Quote  Post ReplyReply Direct Link To This Post Posted: 31 Dec 2015 at 9:36pm
Make sure the seat is screwed tight into the body of the carb, i am not familiar with the carb that you mentioned, but I have seen the new seats supplied in some rebuild kits to not have the exact same thread pitch as  the original. This will cause the new seat to screw into the carb body and feel tight, but not fully tighten the gasket between the seat and carb body, and fuel will leak around the new seat, bypassing the needle. Good luck.
1948 C, 1953 CA, 1948 WD, 1961 D-17 Series 2 Diesel, 1939 WC, 1957 D14
WIDB View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WIDB Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jan 2016 at 1:00am
I hope someone has a good answer because I have been fighting with my WD-45 carb with the same problems.  I have rebuilt it seems to hold pressure when you blow on fuel intake with carb in hand. Install and turn fuel on and leaks.  Limp by plowing snow with the sediment bulb valve cracked a little bit.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jan 2016 at 1:19am
If it don't have a rubber tip on needle it most likely won't stop leaking.  MACK
Steve Zidlicky View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve Zidlicky Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jan 2016 at 2:29am
I am sure you probably already know this stuff but at times we all need to just stop and breathe.go back to the beginning. why did it need rebuilding. what were the problems to start with? If it was flooding before you started to work on it and you replaced all the other usual kit parts then unless you have dirty gas, the float is the only thing left that has not been replaced. Did you use a quality kit? are you sure the float is good? submerge it in a can of water on the stove and warm it up and see if any bubbles appear. if so- float leaks. also shake it and see if you can hear any gas inside it which I assume you already have done. if the float has been repaired with solder that can make it too heavy sometimes and it will not rise enough to shut off the fuel flow soon enough and will flood also. that only leaves the float level which "someone" may have already tried to work on it and failed. If the float level is good then make sure it does not rub anywhere on the sides of the bowl or bowl gasket. did you get a new float pin with the kit? don't want a floppy float. not all new needles and seats are good. check your fuel and make sure it is clean as that can mess up the newer needles. let some gas run in a jar from the drain on carb and let it set overnight and see what if anything settles out. (rust/crud).that will cause a needle to not work. you can check the fuel level by taking out the drain plug and putting a short pipe nipple in place of it with a short piece of clear tubing attached to the nipple and wire it up high enough to be above the gasket that is between the two halves. if the gas comes up in the tubing above the gasket it is too high and the float has some problem or the seat is not working. as I recall, the drain plug is 1/8 pipe thread so a pipe nipple or better yet a barbed fitting is what you use. you do not use a gasket on the fitting and only finger tight is enough. one more thing--some kits use a small hook type bent around wire that attaches to the needle and slips over the flat part of the float. if you have that be sure it is installed properly or else the float will not work either.your new kit may have had it and the old parts did not have it so it was not installed with the new needle and seat that can be a problem. did you use a proper sized seat tool or screwdriver to install the new seat? too small a screwdriver and you can get a burr in the inside of the seat and cause needle to hang up. it takes a really wide flat screwdriver to span all the way across the seat. I made one years ago using a stubby screwdriver which is not used much and filed the flat sides straight (no taper left for 1/8 inch or a little more) so they will properly FULLY fit the slot all the way to the bottom of the slot in the seat. check to see if the new seat gasket is the same thickness as the old one. if it is different that can throw off the float level.
Burgie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Burgie Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jan 2016 at 2:55am
Are the pontoons on the float distorted?
"Burgie"
PatrickBeth View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote PatrickBeth Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jan 2016 at 3:38am
When all else fails, swap carburators, with my B, just cause it came with it, don't mean it's happy with the partnership... Oh my sounds like my first marriage,,,, now there's a start of a thread... Swap out carbs with a buddy and see if you and he have the same issues.
WEL(TN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WEL(TN) Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jan 2016 at 7:29am
The last couple of kits I used were junk. Throttle shaft would not allow the butterfly to open all the way. Float valve did not fit like it should in seat. The gaskets were very poor quality. Tried to save a few bucks but ended up spending more after I bought better quality kits.
One thing that drove me nuts in the past was the float binding on the bowl. It was so slight I had a terrible time finding the problem. I tried to bend the float so it wouldn't bind but only made it worse. Ended up buying a new one. Problem solved.
Post Options Post Options   Thanks (0) Thanks(0)   Quote PatrickBeth Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jan 2016 at 7:57am
I know on my B, had to port the side walls for float hitting, I work in a factory myself, know how it is... But before modifying make sure that's the problem. Unless you had the tractor new, and know how and what was done to it, or you must reverse engineer geneations of fixes, but then that's the fun of it all. Let you know, I'm running two front oil seals on my B to get it to stop leaking!
KenBWisc View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KenBWisc Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jan 2016 at 9:16am
Perhaps Norm and Steve will weigh in here.
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jan 2016 at 9:35am
The modern neoprene tipped float needles have a probability of sealing better but a reputation for sticking closed. The classic solid brass needle often doesn't quite fit the valve seat, but can be ground in with valve grinding compound. When checking for sealing, lung pressure is plenty on the fuel pipe, but finger pressure lifting the float is too much. A better test is just the weight of the float with the carburetor upside down. That will be a little more pressure on the needle than the float floating. The manual on that particular tractor or carburetor should specify a distance the float should be from the gasket deck when the needle valve is closed by the weight of the float with the carburetor body upside down.Typically the top surface of the float is close to parallel to that gasket deck, but often the specification shows a measured distance at some particular location. If that gap is too small the gas level will be too high, making the engine run rich in the transition between idle circuit and run circuit and the carburetor may overflow. The idle adjustment and high speed adjustment can adjust for float level when those are predominant, but in between the float level sets the mixtures.
As for rubbing on the float bowl walls, the float can be a bit fat, contain gasoline, be heavy from a solder repair (as mentioned above) or the accumulation of water in the float bowl can have rusted the wall and made it stick out and be rough. The pivot is often a brass pin (easily bent) in thin brass bits on the float that are easily bent and soft enough to wear over the decades to make the float floppy side to side so it can easily drag on the wall of the float bowl. The float has to be light weight to work and so is more than a bit delicate.
Gerald J.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jan 2016 at 9:51am
One thing that most overlook when putting a new seat, needle or float in a carb is how far the float drops. There should be a way to limit the drop. i have had floats drop down and wedge in the bottom of the bowl and no amount of float level adjustment or work on the needle and seat will stop it from leaking.
 If you have the bowl off, measure how far the float drops in "working position" and then compare to how deep the bowl is. The float does NOT have to drop all the way to the bottom of the bowl in order to work.  Any distortion of the width of the float can also cause the same problem though it might not be seen just by looking at it.
Stan IL&TN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stan IL&TN Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jan 2016 at 10:17am
I find it much easier to just turn off the gas when it's parked and be done with it. Just saying.
1957 WD45 dad's first AC
1968 one-seventy
1956 F40 Ferguson
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian G.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jan 2016 at 11:02am
This is something I would never have thought of....well worth checking!
Something like this could cause one to pull one's hair out!  LOL
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jan 2016 at 11:12am
Years ago when I first got my CA I went through the carb and it was fine for a short time and kept overflowing and not running right. What I found was there were hard crusty debris inside the metal fuel line after the sediment bowl that engine vibrations were causing to come loose. I fabbed up a new steel line and haven't the carb apart in 15 years or more. Might be something as simple as you're getting contamination in the carb that's after your filter.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jan 2016 at 11:14am
I have also run into the non Viton tipped needles not willing to seal and have given them a gentle tap with a tack hammer and punch on the seat with good results.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jan 2016 at 11:23am
The Viton needles work great in sealing off the fuel from the seat. The problem that plaques the Viton needles is dirt. The slightest tiny piece of dirt or debris will stick fast to the Viton needle and cause the fuel to seep through. Another thing that is greatly overlooked is make sure the vent in the top half of the Carburetor is open. We just had one of the family here pull his hair out with the same drip, drip problem, and it turned out there was a resident that made a home in the vent port. Cleared the vent port out and Viola! No more drip. If the vent is open, check the fuel inlet where the 90 degree fitting screws in. You can't believe the crap, debris, & rust that collects in the unused portion of the threads as well as the rear of the inlet cavity. If you didn't run a bore brush inside and out of that bore, you're sure to come out with a lot of crap. On all my rebuilds that I do for our customer's, even after I glassbead inside that bore, I still run the bore brush in and out and make that bore shine! The rust dust, debris and crap that comes outta' there is amazing! Even after glassbeading. All that muck in there gets stuck to that Viton needle causing havoc. If it still has the drip issue, I would head to the fuel tank to see what it looks like in there in the debris and rust department....  HTH
Steve@B&B
DaveKamp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jan 2016 at 3:46pm
And the last possibility...
Many years ago, I had the same situation occur with an antique marine carb... it was on an inline eight Pontiac (Super Chief), an updraft Schebler. Guy was pulling his hair out just the same, so I bent a piece of tin, clamped it to my bench, and put a small fuel tank on the shelf above, turned on the gas, and sure enough, it leaked.
I made a fitting to thread into the bottom, to a clear plastic tube, to visually see EXACTLY WHERE the float level was set, and it was perfect... I disconnected the fuel line (with level up) and blew into the line, and the needle valve was sealed wonderfully... SO... whatever was 'leaking', wasn't the needle and seat.
So I took the carb apart, and cleaned it out good, then started shining a bright light in there, looking for a reason. I sprayed some carb cleaner into it, and wiped out the bowl, then took my air nozzle, blasted it from various angles, and found carb cleaner appearing in the bowl.
What had happened, was that moisture had accumulated in the carb sometime, and frozen.
Cracked the carb casting somewhere.... somewhere invisible, so the end result... was to replace the casting...
Mpat70 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mpat70 Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jan 2016 at 6:49am
I have a D15 series 1 and it takes forever to heat up to where it will remain at idle. Then when I put it in gear and throttle up its starts popping and dies. If I increase throttle very slowly it will act close to normal. Any ideas as to why
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jan 2016 at 7:29am
You need to start your own thread.  You'll get some answers that way...
Ngrant View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ngrant Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jan 2016 at 11:23am
Originally posted by Redneck06 Redneck06 wrote:
Hello all,
thanks for the help
marc
My Cockhutt 50 with the 262 Allis Engine did the same and would not run well. I cut an old carburetor to put over the float to make sure there was no binding of the float and also important, opened the carb bowl vent hole. If it does not get atmospheric pressure in the bowl, it will never un well and may overflow. Seems to work very well now.
kenney58 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote kenney58 Quote  Post ReplyReply Direct Link To This Post Posted: 02 Feb 2016 at 11:13am
Were you able to correct the problem on the carb? I am dealing with the same issue on a late model D15 carb and cant seem to figure it out.
I can see no way for gas to get into the choke plate and hose area from the bowl except thru the power jet area, but Agco want close to $200 for power jet and power jet needle.
My float is not binding anywhere and tractor runs well when running. It only fills the location up with fuel after it sits for a few hours not running.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mpat70 Quote  Post ReplyReply Direct Link To This Post Posted: 02 Feb 2016 at 3:01pm
On my d15 I ended up taking the carb completely apart again and doing a thorough cleaning, and I mean thorough white glove cleaning and after I put it back together all was great. I had build up which wouldn't allow the needle to close properly. Hope this helps
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 02 Feb 2016 at 5:31pm
A leaking needle and seat will do this. With the carb off and turned upside down, you should not be able to blow air into the inlet with lung pressure. This may not be the best test, but if you can move any air this way, the seat and needle aren't sealing up and need cleaned or deburred or replaced.
