WD45 PTO
Isonm View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Isonm Quote  Post ReplyReply Direct Link To This Post Topic: WD45 PTO
    Posted: 19 Dec 2015 at 9:44pm
I have one of the WD's made at the end of the model run which was fitted with a WD45 rear end.  Serial number is WD but it has the curved shifter and a WD45 rear end.  My problem is with my PTO.  It is always on and will not disengage.  Any help, suggestions, etc. would be appreciated.
dads45
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 19 Dec 2015 at 9:57pm
First thing to check is set screw on lever going into PTO box. Could be loose or gone. If not that, not hard to drop box and look inside.     MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote Isonm Quote  Post ReplyReply Direct Link To This Post Posted: 19 Dec 2015 at 10:07pm
Thanks.  Have checked and set screw good.  I guess I will have to drop it and take a look as suggested but I hope the problem will be obvious since I am not sure what I will be looking for.  I see the pictures in the manuals but not sure what would be causing the problem.  Probably a good thing to get inside and get an education anyway.  Thanks again.
dads45
AaronSEIA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AaronSEIA Quote  Post ReplyReply Direct Link To This Post Posted: 19 Dec 2015 at 10:15pm
See if someone can post a picture of where the arm should be with the PTO disengaged. I've seen the set screw come loose and the shaft gets off enough that it won't work right.
AaronSEIA
Post Options Post Options   Thanks (0) Thanks(0)   Quote Isonm Quote  Post ReplyReply Direct Link To This Post Posted: 19 Dec 2015 at 11:35pm
Good idea.  I will check out if I can turn the shaft with the set screw loose to see if it will get to a position where it will work or if I do have something going on inside the PTO.  Thanks.
dads45
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 20 Dec 2015 at 3:56am
See pages 238,239,and 240 of the attached link.
The Gear item 7 slides on the shaft to engage and disengage the PTO.
It may be seized to the shaft,
Gary
http://www.grandpastractor.com/manuals/ac/WD-WD45/wd45-parts-book.pdf
ac45dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac45dave Quote  Post ReplyReply Direct Link To This Post Posted: 20 Dec 2015 at 7:08am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Isonm Quote  Post ReplyReply Direct Link To This Post Posted: 20 Dec 2015 at 8:11pm
Thanks.  Very informative, good exploded view, and parts listing.
I noticed you are located in Peterborough, ON. and have to say I spent a week in your fine town taking a strip canoe building class from Ted Moore at Bear Mountain Boats.  Enjoyed the city, the lift  lock, and had a nice time altogether.
Again thanks for the link and info. on my PTO problem.
dads45
j.w.freck View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote j.w.freck Quote  Post ReplyReply Direct Link To This Post Posted: 22 Dec 2015 at 11:27pm
when pto box is off.ck the detent ball and spring.see if it will engage with a positive click.....
Post Options Post Options   Thanks (0) Thanks(0)   Quote Isonm Quote  Post ReplyReply Direct Link To This Post Posted: 23 Dec 2015 at 7:18pm
Thanks.  warmer tomorrow, maybe I will pull it and take a look.  Nice to have an idea of what to look for as I have never been inside it.
dads45
grateful1micelf View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote grateful1micelf Quote  Post ReplyReply Direct Link To This Post Posted: 27 Dec 2015 at 11:24am
http://www.allischalmers.com/forum/forum_posts.asp?TID=112844&KW=wd45+pto&PID=910787&title=erics-1955-wd45#910787
not sure if i posted that link correctly? but there are some pics and a lil info on this thread, that is stuff i found foolin' w/my pto and hyraulics. just may give you an idea of what the guts look like. your issue is different than mine was, but hope it still helps you and hope you find your problem. mine was obvious Ouch
eric
1955 WD45 (1st and only tractor i've owned..for now)
