Unleaded Gasoline |
Post Reply ![]() |
JWingerter ![]() Bronze Level ![]() ![]() Joined: 10 Dec 2015 Location: Kentucky Points: 71 |
![]() ![]() ![]() ![]() ![]() Posted: 17 Dec 2015 at 8:57pm |
Someone told me that today's unleaded gas causes 60's engines to...
...run hot? ...knock? Old wives' tale? Should I be attempting to compensate somehow? |
TractorTechLuke ![]() Bronze Level ![]() Joined: 15 Dec 2015 Location: North Carolina Points: 48 |
I work at a tractor dealership and we have endless cases of the gas going bad in carburetor sand needing cleaned. I'm not sure on 60's engines but unleaded ethanol gas takes longer to burn therefore the heat lasting longer which can make the motor run hotter. It hard to explain because you would thing non ethanol gas would burn hotter and it does but the heat dissipates faster.... If that makes sense. As to the knock, the only way I see the gas now could make an engine knock is if the engine had higher compression and the gas made it spark knock.
-Luke |
427435 ![]() Orange Level ![]() Joined: 18 Nov 2010 Location: SE Minnesota Points: 18637 |
Ethanol (and as a result, E10) actually has a faster burning speed than pure gas and reduces the exhaust temps. http://www.et.byu.edu/~curtis5/Ethanol%20Paper.pdf E10 shouldn't result in fuel system problems other than really old rubber and plastic parts (and they have been know to fail just because they are old ![]() By the way, crudded up carburetors were around long before E10. |
Mark
B10 Allis, 917 Allis, 7116 Simplicity, 7790 Simplicity Diesel, GTH-L Simplicity Ignorance is curable-----stupidity is not. |
One problem you may run into with E10 occurs if you have some water separated out in the bottom of your fuel tank. E10 will absorb it and your engine will run rough and lean until all the water is used up. Continued usage of E10 will keep water from building up again. E10 will also dissolve old varnish buildup in your fuel system and plug up fuel filters and needle valves etc. |
Mark
JC-WI ![]() Orange Level Access ![]() Joined: 11 Sep 2009 Location: wisconsin Points: 34259 |
Last saturday nephew gassed his v10 ford truck at the local fuel station, we got out on the road and that thing had NO power. Drove it for 35 miles and finally stopped at another station at my suggestion and dumped in injector cleaners and heet... another mile down the road and it quit limping along and ran better, but not like it did before...burned that tank of fuel up and put fuel in from another station and it was back to pulling good again. Nephew said he won't be buying gas from that station again.. and I said I quit buying there some 10-12 years ago.. I got bad gas there too... in the winter and had barely got out on the road when it was dying on me and turned right in the road and went back and bought 4 bottles of injector cleaners and heet and put them in both tanks... and then it ran alright. That station either buys rotgut gas or they have tanks that are getting water in them... Nephew stopped there instead of the Holiday station just little further down the road, because it was more convenient at that moment. Live and learn. "E10 will also dissolve old varnish buildup in your fuel system and plug up fuel filters and needle valves etc. " and composition floats... and isn't real nice to aluminum if
I remember right. |
The truth is the truth, sugar coated or not. Trawler II says, "Remember that." |
LB0442 ![]() Orange Level ![]() ![]() Joined: 27 Dec 2014 Location: Boise ID Points: 767 |
I currently have a 66 charger, 73 road runner, 74 roadrunner, 2 78 trans am's and a 74 hurst olds(in addition to the tractors). They sell either E10 or straight gas here and they all run the same on either, if the vehicle is set up correctly you will not notice a difference. I set up all my carburated vehicles with an infa red for hydrocarbons and carbon monoxide levels. About 2 years ago I bought a portable wide band O2 sensor and have been using that for set up, it's like a portable dyno. When I first started as a mechanic back in the early 80's I used to buy a lot of cars from the 50's and 60's (back when real people could afford them). Once I did get the fuel system cleaned out and running never had a problem with them. I remember when they phased out leaded fuel and they said it was doom and gloom for all the old cars as the lead was there to help lubricate the valves, especially the exhaust. I bought a few cars that did have the seats worn out in the heads, but I think that was more to age than the fuel (they were old when I got them). I have an old 56 international 300 utility tractor, 169 gas engine. I have put about 200 hours on it in 10 years, never had a fuel problem since I redid it, I just use standard E10 in it. With all that said about 4 years ago I drove my 73 Road Runner from here to Oklahoma and back, no problems at all except when I filled up one weekend in Guthrie OK. After about a block or 2 it started knocking and pinging bad, REAL bad, I unplugged the vacuum advance until most of that tank was gone. I believe this was due to way more ethanol than 10%. I think that is where a lot of the bad fuel stories come from, excess ethanol (dilution of the fuel) at certain stations like JC just mentioned.
Steve in NJ ![]() Orange Level Access ![]() ![]() Joined: 12 Sep 2009 Location: Andover, NJ Points: 11950 |
From what I've read and experienced myself, the E10 plays havoc with small engines making the valves stick due to the lack of lead. I've had situations with my small equipment with all of a sudden running badly. I usually add a dash of sea foam to the fuel tank along with the dry gas that's already added, and once that sea foam starts to work, the engines run great again. Its just every once in a while. I thought originally I had water in the fuel tanks, but didn't find any in all the tanks. My Honda HT rider with liquid cooled engine has the same issues once in a while. Dump the sea foam in and viola! Runs nice n' smooth and responds like it should again. Maybe we have a higher amount of E10 in our fuel round' here. I don't know...
Steve@B&B |
darrel in ND ![]() Orange Level ![]() ![]() Joined: 22 Nov 2009 Location: Hebron, ND Points: 8691 |
I'll run E10 til the cows come home in the vehicles and stuff where it gets used up reletively fast, but I don't like putting it in tractors and such where it may not get freshened up for 6 months to a year or so. Probably would make a difference if they sat inside, rather than outside, though. What happens, is that every day when the tank warms up, the expansion pushes air out of the tank. Then the cool of night comes along, and high humidity air gets sucked back into the tank, and the ethanol takes the moisture out of the new air brought into the tank. After this gets repeated over and over, the ethanol gets so saturated with water, it let's go of it (in the tank) and keeps on loading up on more moisture night after night, and depositing more water in the tank. Just my 2 cents worth, Darrel
DougS ![]() Orange Level ![]() ![]() Joined: 03 Nov 2011 Location: Iowa Points: 2490 |
You can always go to your local airport and get some 100LL. When you see how much it costs you won't be filling your 500 gallon storage tank with it or anything. The "LL" means low lead, but it has a considerable amount of lead in it.
corbinstein ![]() Orange Level ![]() Joined: 31 Jul 2014 Location: Oklahoma Points: 796 |
+1 on what darrel said. My 2 strokes,small engines Studebakers and tractors only get Non-Ethanol as they sit around too much. If it gets run every day, I'll dump the E10 in. Also from what I understand is that the ethanol eats the rubber in the older systems.
I'll consider Non-Ethanol cheap insurance, especially when 2 of those 2 stroke engines are aircraft and it's my tail if they konk out mid-air or on takeoff.
Dave H ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: Central IL Points: 3563 |
I always get a kick out of folks adding Heat to E 10. The fuel is already 10% alcohol and if you look at the MSDS for heat it has a high content of alcohol. Think the label also states that.
Ted J ![]() Orange Level ![]() ![]() Joined: 05 Jul 2010 Location: La Crosse, WI Points: 18923 |
This is a great thread! I have been wondering about this and as such, have been burning 100%-no ethanol gas in my tractors and things that sit over the winter, without being run.
So as I understand so far, ethanol gas is OK to burn in our 40s thru 60s tractors? BUT....what about when I leave them sit over the winter without being run, like my grass cutting C and one WD45 I don't use all winter? I've seen where the gas separates and then evaporates, thus creating problems. Should I use ethanol, or stay with the 100% (I call Ethyl)? Does Sta-bil work with ethanol gas? This is more worrisome than the oil controversy..... ![]() |
BrianC ![]() Orange Level Access ![]() Joined: 16 Jun 2011 Location: New York Points: 1619 |
I tested some E10 fuel and found it to be 14% percent ethanol by volume.
Just on batch one time. About the daily humid air moisture cycle. Traditional advice is to leave the tank full, that way less humid air get into the tank. Assumption is less water will condense out. How about not having the tank full, and just get a non-vented (sealed) gas cap for storage times? Remember gas caps with a thumb screw vent on them? Just yesterday I went to two marinas and asked about ethanol and where to get non-ethanol gas. They both say they do a good repair business fixing ethanol related problems. I was talking to mechanics old enough to remember regular gas. They all said as soon as the ethanol gas came to be, numbers of problems skyrocketed. Immediate problem was rubber parts ongoing problem is corrosion. Ditto at the local mower repair shop. He showed me a carb fuel bowl with those tan "grains of sand" or "termite poo" in it. I said I remember that from the "60's. He said yes but now it is way more frequent. In addition there is jelled fuel substance in the carbs also. And I couldn't get him to part with his cat 0 cultivator, darn. I got question about using 2 stroke oil in 4 strokes. A 50-1 ratio will lubricate a two stroke engine. Is there any benefit or harm to running 4 cycle with about 100-1 ratio? |
Stan IL&TN ![]() Orange Level ![]() Joined: 13 Sep 2009 Location: Elvis Land Points: 6730 |
Brian my take on 2-stroke oil is this. The EPA pushes for less and less oil. This is good for the air but is bad for the life of the engine. 2-stroke oils are better now but I still run 30 to 1 in everything I have that is 2-stroke. I have an Echo line trimmer from 1986 and one from 1985 that both run as good as the day they were bought. I bought a new one a few years back and it said to run 40 to 1 in it. It get the same as all the rest. 30 to 1.
As far a gas engines I keep the tanks full to the top and give them a good dose of treatment for over the winter months. If I can shut off the gas, I drain the carbs.
1957 WD45 dad's first AC
1968 one-seventy 1956 F40 Ferguson |
Jwmac7060 ![]() Orange Level ![]() ![]() Joined: 04 Jan 2014 Location: Indiana Points: 929 |
We offer 91 octane with no ethenol...it runs u about .30 cents more than E10....we sell a bunch of it to guys with antique tractors..small engine guys..and boaters
Clay ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: Udall, Kansas Points: 9720 |
My 1998 Lincoln Continental specifies Premium gasoline. When I use non-ethanol regular unleaded gasoline, I get the same fuel mileage. When I use 10% ethanol the mileage drops by 3 MPG. I have run this test several times, to confirm the results.
In my 1994 Mazda B4000 (4 ltr) ethanol gas will ping while accelerating (This also happened after installing a new MAP and complete tune-up). It is also hard to start after it has been run on a hot day and then started again with in a few minutes of shut down. This is due to the vaporization of the ethanol in the fuel system (otherwise known as vapor lock). When non-ethanol gasoline is used, no pinging, no vapor lock on hot days and fuel mileage increased by 1.2 MPG. My Stihl chainsaw is very hard to start when using ethanol fuels. My Stihl dealer said that I should use non-ethanol fuel. He was right. No problem with starting the saw when using ethanol free fuel. My D-17 will run on ethanol fuel but is more difficult to start on ethanol and does not have as much power in the field. When fueled with non-ethanol gasoline, the tractor has more pulling power (plowing) and starts easier. Some aircraft can burn MoGas but no ethanol is permitted. There have been some studies of aircraft utilizing ethanol fuel. Ethanol will attack the fuel systems in most aircraft and vaporization at higher altitudes is a big problem. Fuel injected aircraft engines are notorious for difficult hot starts. I could only imagine how difficult ethanol enriched fuel would be in a hot start scenario. Keep your ethanol. Grain should be used for food, feed, industrial and drinkable alcohol. Just keep it out of MY gas tanks.
That's a bit much of a drop. E10 has 4% less energy than straight unleaded. This should result in a 4% drop in mileage. EPA has pretty much confirmed this to be the case. You should be seeing less than a 1 MPG decrease. |
Brian Jasper co. Ia ![]() Orange Level ![]() Joined: 11 Sep 2009 Location: Prairie City Ia Points: 10508 |
This is probably the only time I'll agree with Mark on anything, be he's right about the ethanol comments he made. If you're running gas powered anything with ethanol blended fuel, fill the tank when finished with each use. Displacing the air with fuel will greatly reduce condensation in the fuel.
The only fuel problems I ever see here in the dealership are the vehicle owner put the wrong fuel in the tank or put DEF in their fuel tank. I have been putting Stabil in by CA and Oliver because it takes a year or more to use a full tank of fuel in either of them. The CA's carb was last apart when the engine was overhauled 15+ years ago. Nothing but ethanol fuel has been used in it. One time I put E85 in it just to see how it acted. All it took was adjusting the carb. |
DSeries4 ![]() Orange Level ![]() ![]() Joined: 12 Sep 2009 Location: Ontario, Canada Points: 7454 |
I've never had any major problems running unleaded gas in the older engines from the 60s or prior. As mentioned above, the bigger problem has to do with the ethanol in today's gas.
banjerpicker ![]() Silver Level ![]() ![]() Joined: 26 Apr 2015 Location: Tennessee Points: 188 |
Eh, I've heard yes and no on the lead. I know they have substitutes. Ethanol, from what I hear, is worse as it can corrode and pit some of the metals used. Not sure if this is true. I know it caused nothing but problems on every lawnmower I've ever used. Trashed the motor on one almost did the second. Problems went away with a little carb cleaner and ethanol free fuel.
tadams(OH) ![]() Orange Level Access ![]() ![]() Joined: 17 Sep 2009 Location: Jeromesville, O Points: 10695 |
Explain why in the old engine you adjusted the carb so the tailpipe was gray, with this E-10 gas all exhaust pipes are black and that is computer adjusted fuel systems.
Tom |
HD6GTOM ![]() Orange Level ![]() ![]() Joined: 30 Nov 2009 Location: MADISON CO IA Points: 6627 |
Many hundreds of hours of testing in the 1970's when ethanol came out shows these myths to be untrue. Congress mandated all engines being sold in the US capable of running 10% eth. If these engines are not running on 10% you need to be complaining to the engine MFG's not complaining about the gas. Or better yet take the mowers back where you got them after a few hundred returns they will get the message.
nanuk ![]() Silver Level ![]() ![]() Joined: 22 Aug 2013 Location: Saskatchewan Points: 258 |
years ago, when we had a moron for a Prime Minister, he made the moronic comment about lead bullets, saying "We got the lead out of gas, time to get it out of bullets" So, I did some research about lead, and during a discussion with a fuel expert at the local aviation company, I asked about 100LL, and his comment was 100LL has about 4X the lead that leaded regular had. and MORE lead is released into the atmosphere from Canadian aviation per year than all the lead from bullets and shot combined. the numbers were staggering |
AC7060Pd 1975
JimWenigOH ![]() Orange Level ![]() Joined: 12 Sep 2009 Location: NC Ohio Points: 1168 |
The main issues I have with ethanol blended fuel is corrosion in the fuel tank and that it vapor locks easier. I had to reroute and add some insulation to the fuel lines on my K2 so it would run when the outside temps are warm/hot.
Chalmersbob ![]() Orange Level ![]() Joined: 11 Sep 2009 Location: Pennsylvania Points: 2122 |
I don't have any problems with the ethanol. I have a 30 year old Homelite weedwacker and it sits all winter and starts in the spring on last years gas. The fuel line on my newer Troy-bilt WW did have to be replaced because the got brittle and broke. I have a B that sat for 2 years without running and it started right up and ran fine. my Lawn tractors are the same. No problem starting or running. I read particularly in the JD magazines how bad this fuel is and how it blocks up carbs. I don't see it happening. Bob
4 B's, 1 C's,3 CA's, 2 G's WD, D14, D15, B-1, B10, B12, 712S,
Bob, the B that started right up after 2 years. What were the conditions? Did it sit for 2 years with the same E10 gas in it, was there gas in the carb bowl for two years? What gas do you use and do use treatment stabilizer.
Yes, it sat for 2 years with ethanol gas in the tank and carb. After I drove it 10' out of the shed it stopped. I forgot to turn the gas on. Started right up and ran fine, I then added some gas for the day. I do not use Stabil. Bob
weiner ![]() Orange Level ![]() ![]() Joined: 19 May 2012 Location: Cadillac, Mi. Points: 4304 |
Maybe I`m way over doing it but every thing I have that sits for any period of time get Stabil, carburetor cleaner, and Marvel Mystery Oil, 1 ounce per gallon of gas. My 2 cycle engines also. To my 1952 Super C, I do the list above, plus I add a lead additive. I say better safe than sorry. I`ve done this for more years than I care to remember.
Real heros wear dogtags, not capes.
Post Reply ![]() |
