530 Header
Tncropsman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tncropsman Quote  Post ReplyReply Direct Link To This Post Topic: 530 Header
    Posted: 21 Nov 2015 at 8:58pm
I've got a pretty bad shake on my 530 head. It's on an R62.
Here's what I know:
Stabilizer arm is not broke or cracked.
Tie rod on stabilizer is tight & greased
Wobble box is greased and all bearings are tight.
Just put in a new sickle drive head. (Broke this week)
This head has an SCH cutter system on it.
Am I missing anything? It's driving me nuts.
Thanks
Clay
wayneIA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wayneIA Quote  Post ReplyReply Direct Link To This Post Posted: 22 Nov 2015 at 7:50am
Mine started to shake one time, found the lockout plate on the variable speed header drive came loose and was speeding the head up while speeding the reel up too.  Most likely not your problem, but would be an easy fix if it was though.  I don't know either how the new reel speed controls work, mine is the old on head pump for the reel.
tbran View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 22 Nov 2015 at 8:46am
as stated, check speed, then take off chain to auger to see if that is it, that will leave only wobble box. There is NO allowable play in any part of wobble box - 0 . Worn guards and sections can cause increased load on the drive.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 22 Nov 2015 at 9:21pm
What ever caused sickle to break last week is most likely causing the shake. With new sickle, did you readjust hold downs and ware plates? Make sure there is no loose movement between wobble box arm and sickle.   MACK
SHAMELESS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SHAMELESS Quote  Post ReplyReply Direct Link To This Post Posted: 22 Nov 2015 at 10:07pm
out of time
KY poorboy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KY poorboy Quote  Post ReplyReply Direct Link To This Post Posted: 22 Nov 2015 at 10:13pm
The last 530 I had was acting the same way, then it also broke the knife head off. After checking everything out and repairing the knife, it still did it. We had put all new sections on it and only been over about 150 acres. After a lot of looking, I noticed the cutting edges of practically all the guards were very dull. I had called myself looking at them when we replaced the sections, guess I didn't have my glasses on. Lol. Put all new guards on it, and cured the problems.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tncropsman Quote  Post ReplyReply Direct Link To This Post Posted: 23 Nov 2015 at 4:59am
How do you "TIME" it??
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 23 Nov 2015 at 5:32am
The sickle section point should travel from the point of one guard three inches to the point of the next guard. If it's a double section type sickle (kwik-cut...tiger-jaws, etc) if obviously goes thru double the amount of points but still three inch stroke. If sickle register (time) is off, the sickle head has the threaded ball joint to change for correction of timing stroke.
