Rear rims for D12 III
Marlyn nwia View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote Marlyn nwia Quote  Post ReplyReply Direct Link To This Post Topic: Rear rims for D12 III
    Posted: 21 Nov 2015 at 1:03pm
Which combine rims fit a D12 III? 12"or 13" wide X 24"..... 4.75" center hole with 6 lug bolt holes?
Marlyn
Ken in Texas View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ken in Texas Quote  Post ReplyReply Direct Link To This Post Posted: 21 Nov 2015 at 11:23pm
If a D12 has the same 4.75" center hole 6 bolt hole as a D10 or my CA. Stamped Farmall A or B wheels will fit.
I run 13.6 24 rubber on 11x24 rims on my CA. using Farmall centers which are the same center as a D10.
I have a pair of 13.6x24 almost like new Goodyear Dyna Torque II 8 ply and tubes takeoffs and a set of JD 11x24 rims for sale.
See my add in the Classifide forum for pictures. They would look great on your D12
If you use the Farmall wheel centers like I did. Farmall wheel weights fit perfect
Edited by Ken in Texas - 21 Nov 2015 at 11:50pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ken in Texas Quote  Post ReplyReply Direct Link To This Post Posted: 22 Nov 2015 at 12:59am
My CA with 13.6 X 24 Firestones on 11" MF rims on Farmall A steel wheels with Farmall A weights
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 22 Nov 2015 at 5:04am
I have a set of "temporary" rims on my D-10III, centers are farmall, rims are british leyland...  Had to blow about 1/8 inch off the outside of the center to rim holes, with the plasma cutter, to get them to fit.  Could've done it with a file, but the PC was less effort...
