Carb Gunk Cleaning Tips? |
Slim
Topic: Carb Gunk Cleaning Tips?Posted: 06 Nov 2015 at 7:23pm |
Anybody know of a good solution to cut through 20 years of carb gunk? It's on the outside of the carb. I could clean it off by hand but it would take forever. It's a mixture of gunky fuel residue and field dust and man is it tough to remove.
-Slim |
AC 1971 170 WF Gas, AC 185 Diesel WF, AC WD NF, AC '54 WD45 NF, AC 7080, AC 7030, Wheel Horse D-180 Automatic
Alberta Phil
Joined: 13 Sep 2009 Location: Alberta, Canada Points: 3955 |
Posted: 06 Nov 2015 at 7:34pm |
Acetone or laquer thinner will usually clean it up .
Dmpaul89
Joined: 06 Mar 2013 Location: Edwardsville,IL Points: 1689 |
Posted: 06 Nov 2015 at 8:35pm |
Turpentine and a wire brush. Or pressure washer
Steve in NJ
Joined: 12 Sep 2009 Location: Andover, NJ Points: 12045 |
Posted: 07 Nov 2015 at 5:19am |
Really the only way to get that kinda gunk off Carburetors is with a putty knife and some time. Some of our customer's Carbs that come in here to get rebuilt are amazing how much crud is on them from blow-by and field dust n' dirt. Its like concrete! After I get the heavy stuff off, I then use a wire brush and hot soapy water to get the rest off before they go in the tank for a soak. Distributors and drives get like that to after years of layers of blow-by n' dust n' dirt...
jaybmiller
Joined: 12 Sep 2009 Location: Greensville,Ont Points: 24901 |
Posted: 07 Nov 2015 at 6:14am |
I drill a lot of 1/16" holes in a length of 1/4" copper tubing,coiled it up like a snake then attached tubing between it an an aquarium air pump.Suspend the carb in a big coffee can or similar and fill with a liquid 'orange' cleaning solution, full strength. The more agitation the better at removing the crud. Only takes a few hours though I usually forget it's working, leave it overnight.....hen it's even cleaner !
Just be sure to rinse it off real well, get all the water out of the carb !! Jay |
